Projects My beater '57 Chevy
Discussion in 'The Hokey Ass Message Board' started by choppachris, Jul 24, 2013.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Alan lives in Easley,South Carolina. HRP
  2. Willy_P
    Willy_P
    On the 4 vs 2 hole on the spindle plate my understanding from the trifive site is that 55 had the 4hole and was supposed to aid factory ***embly. 56 and 57 changed to 2 hole and all are interchangable. Mixing them would be OK, depending on your OCD level. I am working on mine today and have one 2 and one 4 hole, but the Wilwood caliper should distract most people.
  3. Here's a setup on my race car.
  4. choppachris
    choppachris
    Those look beefy! I've got all my shift linkage hooked up as of this past weekend. The linkage from my Hurst shifter to the Saginaw 4 speed was three straight rods, the shifter was actuall spaced about 4" off the left side of the transmission to make it reach without bends. I made some bends to get it back against the transmission, but the rods are short to begin with and the shift tabs on trans were on upside down to reach. Sooo, I have backwards gears. I can live with it for now in order to save the $120 or so i'd have to spend on correct linkage and spend that on something else I need to get it roadworthy.
    Tonight i'm looking at my steering, had alot of play in the steering wheel and I believe I adjusted the box too much, was binding up when I turn left now..Gears might be too far gone to adjust the play out. All my balljoints and tie rod ends are very good, no slop.
    It's looking better with 1 1/2 coils cut off the front. I'll take pics soon as I roll it outside again, can't get far enough back to get a good pic. Rear springs were probably sagging a little, so with the front springs cut it sits almost level, front raked down just the slightest and almost zero fender gap over the 205/75r14.
  5. choppachris
    choppachris
    Oh and I learned a trick, I loosened the upper ball-joints using my old heat gun. 2-3 minutes of hot air on the upper spindle arm and it pops loose from the joint when under pressure. I loosened the ball-joint nut and left a floor jack just about touching the lower control arm. No pickle-fork destroying the ball-joint boots, and no BFH beating the heck out,of it. :)
  6. choppachris
    choppachris
    Pic in the garage
  7. choppachris
    choppachris
    Turns out my problem with the steering not turning left is the tie rod near the pittman arm is hitting my header.. After some research I have found this has happened to others with old headers.. Lowering the car likely amplified the problem for me. I'm either going to have to modify my header, or replace them at this point.
  8. choppachris
    choppachris
    Just finished painting wheel details, polished wheels, and installed new lug nuts and oval washers.
  9. choppachris
    choppachris
    Gave it a bath, might sneak it about a block and a half down the street to the hotrod meet tonight.
  10. n847
    n847
    Looks good man!
  11. choppachris
    choppachris
    I need new tires asap, they will be blackwalls, no raised white letters. One piece at a time, like Johnny Cash. I made it to the car meet tonight, first time really driving the car any distance. It did great on the way there, and about half way home. It shut off at a red light, no more spark. Had to pull it home, luckily only about 2 blocks away. Checked and theres no fire, everything is still hooked up, no apparent broken wires to coil or dist.. Bad coil maybe. It was still cool to finally get it out.
  12. dynaflash
    dynaflash
    from South
    You figure out the spark issue yet? What was it?
  13. choppachris
    choppachris
    Yeah, the module in the Mallory Unilight distributor went out. I have a new "Ready to Run" HEI distributor on the way. It has a small cap and uses an external coil, will look like original equipment. :)
  14. deprice
    deprice
    picture of my 57 210
  15. dynaflash
    dynaflash
    from South
    Here is my 57 Two Ten
  16. wade57
    wade57
    from BC Canada
    Nice beater you got there
  17. sololobo
    sololobo
    good times ahead, loves me them 57's. you can get all your missing trim from a bunch of tri five repop sellers. enjoy bro, she's a cl***ic ~sololobo~
  18. Blue One
    Blue One
    from Alberta
    I think I like the primered version better than the painted ones that have been posted. :)
