my cadillac
Discussion in 'The Hokey Ass Message Board' started by RussK, Nov 3, 2011.
  1. RussK
    RussK
    from Atlanta Ga
    Ok FNG asking a question
    Well here is my 1946 Cadillac that I just picked up. It’s been in storage for 30 years.
    I am trying to get the tires aired up to roll it off the trailer and into my garage.
    Good interior, almost nonexistent rust, and only set me back 2 grand
    The biggest problem I have with it is the engine has seized up. I filled the cylinders with diesel, then hooked a line to each cylinder and put a 140psi to each of them from my air compressor. Then refilled them with more diesel.
    I have used diesel before and had good luck with it
    Am going to let it set for a week or two and see if I can break it loose.
    It has a “49” OHV Cadillac engine in it now, not the L head it came with
    Sense it isn’t the OE motor I was thinking of what I can replace it with if it doesn’t free up. I could rebuild it but if I go that far I want more power
    SBC with a 700r4 would be the easiest, but a Cadillac motor like a 472 / 501 would be a torque monster I haven’t researched a 4 speed for them yet.
    What do you guys think?
    [​IMG][/url][/IMG]
    I corrected the year of the engine its a 49 not a 47
    car is still a 46......my bad
  2. Sorry pic didn't load for me.....
    *edit now it did* that car looks clean as hell! In my opinion keep it Caddy ! Nice!!
  3. resqd37Zep
    resqd37Zep
    from Nor Cal
    Beautiful Car. Doesn't really need much to be the perfect ride. Personally I'd keep with the original drivetrain but either way it'll be a head turner for sure. Best of luck.
    James
  4. bobwop
    bobwop
    from Arley, AL
    absolutely stick with a Cadillac of some vintage.
    You car likely has a dual-range hydromatic, so why not maintain that and find an engine that can be mated to it?
    btw, NICE SCORE!
  5. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Looks like a cool car man. i love the old caddies (pre 57). i say just go with the motor that you can afford, im swapping a 350 into my poncho because i cant afford to rebuild the pontiac motor in it.
    Have you considered some sombrero hub caps? i think they'd fit the look of your car a lot better.
  6. kzeliminator
    kzeliminator
    from chicago
    Stay caddy
    Sent from my PC36100 using Tapatalk
  7. RussK
    RussK
    from Atlanta Ga
    I have 4 of the ones you see on it (were on it when I picked it up) they are coming off
    I found 3 of the standard ones and one sombrero in the trunk, just got to make a set so I will start hunting
  8. Retro Jim
    Retro Jim
    That is one sweet looking Caddy for sure . You didn't get hurt at all on the price at all .
    OK , here is what I would do if it was mine . I would pull the engine , pull the oil pan and remove the crank . Then pull the heads and bang the pistons out if possible . Even if the pistons break you will still need to buy new pistons anyway since you will have to get the cylinders re-bored . In the end I would do my very best to keep that Cadillac engine in there ! If not go with another Cadillac engine from that time frame . Please don't stick another brand of a GM engine in there ! :eek: That car deserves to have a true Cadillac engine under that hood ! In the end that is one great looking Cadillac you have ! A true time piece ! Keep us posted on what happens with the engine .
    Just my opinion !
    Retro Jim
  9. VonKool13
    VonKool13
    They didn't make an overhead Caddy motor till 49', but either way keep it Caddy, and I would keep an auto in that big Luxury Yaght. I know I wouldn't want to be bangin gears in a luxury sedan.
  10. lexington
    lexington
    I know where there is a 41 flathead and trans that run good. If your interested let me know. I sold the engine to another guy but I know he still has it.
  11. PRB
    PRB
    from Az
    Sweet score. Really looks clean.
    If you don't go stock OE doesn't much matter. A Caddy lump would be cool if it's affordable for you.
    I've been putting SBC's in cars for 44 years now for a reason ....inexpensive reliable HP.
  12. Sandwich shop owner down the street from me, drives a 61 Cad CDV with a SBC. But there are adapters, for the Cad motor to mate to a 700R4. I won't build a car without OD.
  13. KustomCars
    KustomCars
    from Minnesota
  14. PRB
    PRB
    from Az
    What he said with the OD....what does that car weigh?
  15. MotorCityDeuce
    MotorCityDeuce
    Listen to Retro Jim, good advice!
  16. X1000000000 on keeping it all Caddy. awesome score as well,.. what about a mid fifties 365/390 with factory duals or triples? very cool,...
  17. RussK
    RussK
    from Atlanta Ga
    I will post a pic and get the # off of the engine. I know some one on here will know what it is
    thanks
  18. terryble
    terryble
    from canada
    What a beautiful car! But there is no "47" OHV Caddy engine they are all side valve motors.
  19. scoobyscooter
    scoobyscooter
    drop a late model cad 500....even bone stock that motor's got power to spare
  20. hombres ruin
    hombres ruin
    Exceptional caddy and awesome avatar
  21. boomosby
    boomosby
    500 with t56, if you want to embarr*** a few people ;DDD
  22. RussK
    RussK
    from Atlanta Ga
    the motor is a 49 OHV , my bad
  23. Master of None
    Master of None
    I'm running a 472 Caddy motor from a 72 in my mother's 47 caddy.
  24. RussK
    RussK
    from Atlanta Ga
    What all did you have to do to put it in? And what trany are you running?
  25. Master of None
    Master of None
    My mothers 47 is a series 75 so its the biggest next to the limo. Right now I took the entire drive line out of the 72. The ****** is a turbo 400. Not sure what ratio the rear axle is but it is a exposed drive shaft. Had to make my own mounts obviously,but it all seems to fit well. For a front end I went with a fat man Fab stub(mustang II style) so I did remove any factory frame clearance issues. But the rest of the frame is original.Hope to have it on the road by May of this year.
