My craiglist find 34 Willys delivery
Discussion in 'The Hokey Ass Message Board' started by abone1930, Jul 24, 2012.
  1. 1971BB427
    1971BB427
    from Oregon
    Both great axles, but I'd run the drilled I beam for sure! I've got one of each in my two cars, and I like the drilled I beam one much better! Blocks aren't an issue, as long as you don't get crazy with thickness.
  2. abone1930
    abone1930
    How about centering the front axle or pushing it forward an inch or so?
  3. benji2714
    benji2714
    We never tried that. Just put them where they naturally set. The Bizio truck axle is set forward. Two friends have stretched the body and ch***is to get a longer wheelbase . one is 106 and the other is 108 in. Mine is 100 in. one is pro-street and handles good (106) the other (108) isn't finished yet. I guess it's depends on what you do with the car. Sedan Deliveries are very cool. Had a chance to buy "Catch Me If You Can" once but had 3 Willys already. I was standing on thin ice if ya know what I mean. It's in California now.
  4. 1971BB427
    1971BB427
    from Oregon
    It usually looks better if it's slightly forward as the front gets higher. Doesn't take much, so maybe 1"- 1.5" forward will make it look better.
  5. abone1930
    abone1930
    Yea I would luv to own Catch me If ya can :D Way out of my buget though. But Im on way to building one though. Ill never forget clicking on craigslist and Finding this panel within 4 blocks of where I am working. And for a poor mans price to boot :D
    Does anybody know the correct length of a rear spring on a willys?
    I am having a ruff time trying to buy some spring for the rear. Useing speedway on front though.
    kidcampbell71 likes this.
  6. abone1930
    abone1930
    Well I got me a Mickey Thompson pan for the motor , little by little :)
    Deuces likes this.
  7. 1971BB427
    1971BB427
    from Oregon
    Nice! Been a long time since I've seen quality cast aluminum oil pans!
  8. abone1930
    abone1930
    I wanted a EELCO but I settled for this, which still wasnt cheap, but I thought it would go with what I am shooting for. Got my material for ladder bars, cut them , but had not started yet on the build of them. No time. There 1.25 x .187 sq, tubeing, will be about 60" long when done. Puts right about the trans mount area. Still debating quater eliptics or parallel leafs? Car want really see any dragstrip duty, might though, mostly sunny satarday thing.
  9. abone1930
    abone1930
    Messing around last night with a parachute a friend brought by. I think the bigger one is what I was shooting for, this one is too small I think? I think I need to lift the back of the panel up some too?
    Yes I still have the orignal steel back door too :D
  10. abone1930
    abone1930
    starting on it again, hope the honey do's don't kick in again, and kids, I might get something done :)
    Deuces and kidcampbell71 like this.
  11. elgringo71
    elgringo71
    Any updates or new pictures of this one? Will it be at the roundup?
  12. abone1930
    abone1930
    Want be at the round up with it, going to be awhile for this one , putting up my new car lift this weekend :) not going to run these front wheels, will be the steel chrome runner slots up, got to redrill rotors :)
  13. abone1930
    abone1930
    Deuces likes this.
  14. abone1930
    abone1930
    Deuces likes this.
  15. abone1930
    abone1930
    I emptied my garage to put lift up, it's usally packed :)
  16. elgringo71
    elgringo71
    It's looking great
  17. rfraze
    rfraze
    I am having a ruff time trying to buy some spring for the rear. Useing speedway on front though.[/QUOTE]
    Anybody know the answer to this question? Dimensions? Replacements?
  18. Torkwrench
    Torkwrench
    Anybody know the answer to this question? Dimensions? Replacements?[/QUOTE]
    If you are talking about stock original springs check with St. Louis Spring, in St. Louis Missouri.
    http://www.saintlouisspring.com/
    They make springs for just about anything, so they should have the correct measurements.
  19. I have a copy of the length of all Willys front and rear springs from before the Model 77's up through the 441-42 vehicles.
    It list all Willys rear springs from 1933 up through 1941-41 model year as 46" from eye to eye, number of leafs, center bolt placement, and arch in inches. I have a set of '39 rear springs as well as a 1936 set of rear leafs, and they are both 46" long. There are minor differences in the placement of the spring center bolt, number of leafs (6 is the most comon), and arch. They are all 1-3/4" wide. The front spring are another matter as they are all somewhat close in length, but many are an inch or in some cases up to 6" difference in length. Smallest front ones on the list are about 30" long (early model 77's), up to the 440-441's which are listed at 36-1/4" eye to eye. '37-'38 show as 33" eye to eye... again it varies a bit as to center bolt placement. g-willys
  20. rfraze
    rfraze
    g Thanks. I mean Thanks g.
  21. abone1930
    abone1930
    So are the model 77 rear springs are the pad locating bolt center in the center of the spring? If not, how much offset?
  22. Interestingly enough the Willys factory was never noted for consistently putting the wheels in the center of the fender opening. We street rodders are more apt to do that for looks and balance. All that being said the factory listing that I have shows that the rear spring center bolt for the model 77's all the way up to the 37-38 model year to be located the same. That distance would be from the front spring eye(center) to the center bolt as 22-1/4" and the long end is listed at 23-3/4 " from the center bolt to the rear spring eye center. It went to 23" & 23" (or dead center) in 1939...can't find my next page, so unsure of the exact locations for the model 440, and 441-442.
    *** Of note, would be that the springs are measured as follows: from the center of the front spring eye, along the arch of the MAIN leaf to the center of the rear spring eye...Not from one spring eye center to the other, like a bow string. That type of measurement would tell you the spring arch, but would be less in length than 46 inches.
    g-willys
  23. Barn Find
    Barn Find
    from Missouri
    Always one of my favorites.
  24. marshall
    marshall
    from tacoma/wa.
    Did you ever get this done?
  25. He sold/traded it away a few years ago
