Projects My Deuce Coupe Project
Discussion in 'The Hokey Ass Message Board' started by Jimmy Tee, Aug 15, 2009.
  1. Stovebolt
    Stovebolt
    Jim,
    The firewall looks great in it's rightful place.
    Two things:
    Are you going to fit a cowl vent, and isn't it time for Part 2 - the body chapter???
  2. Jimmy Tee
    Jimmy Tee
    There will definitely be a working cowl installed. I actually have an original rusted vent which I'll try resurect.......... as for Part 2, I originally had that idea to create Part 2 for Body, Part 3 for Engine & Part 4 for Interior, but I think I'll just leave the whole build as Part 1 and keep the whole build together.
  3. X38
    X38
    Ahhh, remember whe a filled cowl was cool? Ain't the hot rod world a funny place!
  4. Stovebolt
    Stovebolt
    Part 1 Part 2 who gives a damn - I don't after all the eighth gl*** of wine I've just had means all the world can have a part of ........... I dunno
    ****** work breakups ;)
  5. ****** work breakups
    Yeah....
    Now get back to work !!
    LMAO
    Rat
  6. HeyyCharger
    HeyyCharger
    Looking nice JT!
    The Steel firewall looks the part....
    HC.
  7. Jimmy Tee
    Jimmy Tee
    Further Progress.....
    The Floor has been bolted to the Ch***is and the holes for the Master Cylinder, Handbrake Lever, Gear Shifter, Tailshaft Loop and Pedals have been cut.
    The floor was sliced at the point where it kicks up to meet the firewall. This was so that section can be extended and dropped. You can see the section that now needs to be gl***ed in. This will then be followed up with some extra fabrication at the point where it meets the Firewall to take up any gaps.
  8. Great progress, but please tell me those shiney 2nd World War Army helmets aren't going to used in the build
  9. LabRat
    LabRat
    Oz Rat , Why a gl*** floor ? Would'nt steel an wood keep em' guessing ...
  10. Jimmy Tee
    Jimmy Tee
    Not a Chance, No Billet on my Ride !!! They are just some things that Wombat has in his shop, non car related.
    Great suggestion but our Engineers require a Steeled out Body, Wood won't cut it.
    What will happen from here is that two 5mm thick steel straps, the width of the Frame Rails, will be fitted. They will run from the Firewall to the rear, along the Frame Rails. They will sandwich the floor between them and the Ch***is. The Steelout will be built off these straps. I have plans to put a Steel floor over the top of the Gl*** one, so the guessing should coninue.
  11. lorodz
    lorodz
  12. langy
    langy
    Good progress, one thing i found when cutting the master cylinder hole was that at that size its real fiddly to get the top off, I cut mine a fair bit bigger.
  13. X38
    X38
    True, you need swingin room.
  14. Jimmy Tee
    Jimmy Tee
    Thanks for the heads-up. Access has been tested and seems to work OK. It's not something that you do too often so it should be fine as is.
  15. Mr 42
    Mr 42
    from Sweden
    Awesome build really like it, Workmanship is outstanding as far as i can see.
    But the thing that worries me a bit is the rear axle mount.
    One bolt mounted in parts, that was not designed to take the forces from the rear axle movements.
    And when one wheel is higher then the other there will be a twisting force induced in the arm and bolt. Not much i agree but over time the bolt might brake.
    Maybe im only an old fart without guts, but is there a lot of expeirence in mounting a rear axle in this way? The ones ive seen befor has one mount per arm.
    Does it work? And is it safe?
  16. Jimmy Tee
    Jimmy Tee
    Lowsquire has done the same to his Ride (32 Roadster) and has had it p*** engineering. I don't think the twisting forces will be that great. Maybe I 'll carry a spare Bolt in my toolbox now that you have put the notion in my head.
  17. Mine has a similar setup and the only thing that has failed in the 10+ years of abuse is the ends of the bones. The rubber absorbs alot of the twisting.
  18. Mr 42
    Mr 42
    from Sweden
    OK No problem then, ive never seen this solution before.
    And it made me curious.
    This is the one ive seen before that uses two tabs and one bolt per arm.
    Since im not an enginer this solution "feels safer", but that's me ;-) I have no hard evidence
  19. X38
    X38
    Mr 42, I would mount them with separate bolts too.
  20. Jimmy Tee
    Jimmy Tee
    My Build has stalled somewhat.
    There is a Package from the US I've been waiting on for some time which contains essential items...... Hinged Windshield Hinges, Wiper Motors, Rear Wheels, Heater, Door/Trunk Hardware and other smaller bits. The Body Steeling Out can't continue without these items as they need to be incorporated in the process.
    Because of the size of the package I had it shipped by Container but it got lost in the LA Shipping Warehouse. It's now been located and sent on it's way...... Been waiting since November.
    I filled some time in by bending up some Copper Fuel lines for my Intake. It took a couple of goes but I reckon they turned out OK. They are symetrical & evenly spaced. I polished them up today and they look Cool. Now I'll send the Manifold off to get Hydroblasted and then decide how **** the Carbies look before I take them apart for a Reco.
  21. Stovebolt
    Stovebolt
    Nice work there Jim
  22. retro rodder
    retro rodder
    from cape cod
  23. langy
    langy
    Been wondering why there had been no updates, hopefully they will turn up soon, nothing worse than waiting for bits.
  24. Jimmy Tee
    Jimmy Tee
    Yeah Langy..... Our Dollar is at Parity with the $US so I've been going nuts with the purchases, but Shipping direct for big items is still a Big Cost Killer. This Container shipping method has worked well in the past but a slight hiccup this time.
  25. 68wagon
    68wagon
    Nice work Jim.
    great meeting you on the weekend cheers Scotty
  26. Jimmy Tee
    Jimmy Tee
    The Intake came back from the Hydroblasters, what a difference...... Looks a Million Bucks.
    I left the backing of the Eddie Meyer tag in the original cast finish to offset the polished lettering/symbols. Look's good I think.
  27. langy
    langy
    Inlet looks dead nice mate, was it vapour blasted ???
  28. HeyyCharger
    HeyyCharger
    That's one nice intake!!
    HC.
  29. sweet build, just read the entire thread. cant wait for more updates (subscribed). definately some cool pieces going into this puzzle, not the least of which that inlet manifold (it makes me very happy in the pants;):D) good luck with the rest of the build and il be at chopped this year, hope to see it in person.
  30. Jimmy Tee
    Jimmy Tee
    It was Hydroblasted.... It's Very High Water Pressure with a small abrasion/medium thrown into the mix. It's the best form of blasing I believe. Does not damage or pit the item, commonly used in Aviation parts.
