Projects My Deuce Coupe Project
Discussion in 'The Hokey Ass Message Board' started by Jimmy Tee, Aug 15, 2009.
  1. Jimmy Tee
    Jimmy Tee
    Some more work done....
    I took my other engine block down to get machined. It's a virgin block, but does have some water damage in a bore and ***ociated valves, so definitely one sleeve required. Let's see how the rest of it checks out.
    The Body continues to move along. The heater is mounted, the steering column is awaiting an appropriate sized Conrod to finish off the mounting and the Battery tray is in place.
    I fitted the rear Firestones so that the cycle guards can be fabricated. At least it now looks like a Hot Rod. Obviously sitting a little high in the rear at the moment, but I'll see how she looks fully loaded before I go playing around with the rear spring.
  2. Great to see some progress
  3. fartman
    fartman
    from adelaide
    looking sweet.
  4. langy
    langy
    Great stuff Oz, good to see it progressing after the unfortunate setbacks
  5. Roger53
    Roger53
    Went back and did a reread of the whole thread. What ya have to go threw to build a down under is just a kick in balls. But on the flip side your going to have a safe car. Some of the stuff on this side of the world makes just wonder what the hell where they thinking. WHAT AN *** HAT TO THE GUY THAT SCREWED YOU ON THE MOTOR! You can only hope he gets the same many times over. Roger
  6. Hot Turkey
    Hot Turkey
  7. resto-rodder
    resto-rodder
    Very nice detail work on the whole project! I like the firestone bias ply tires and the profile of the car in the picture taken from the rear.
    Keep up the good work!
  8. scooterford
    scooterford
    Hi, can you give me your engineers name.
  9. Jimmy Tee
    Jimmy Tee
    Rowan Carter is the man. Very Knowledgable and Practical. Works out of Richmond, Vic.
    PM me if you need his details.
  10. Jimmy Tee
    Jimmy Tee
    Here is the end of year update. I have two fronts open now..... The Body Construction Front and the Engine Building front.
    Body Construction Front - Steering is complete, Steering wheel fitted and Dash installed..... not much left before she comes home now.
    Engine Build Front - The second Block I had ended up being No Good either. A crack between one of the Inlet & Outlet Valves was the issue .... Certainly fixable, but costly and no fix is guaranteed. So the hunt went out for another Block. Lowsquire came up with one and this one proved good.
    It was cleaned, bored, surfaced and ported. Crank was linished, Flywheel had a new Ring Gear fitted, Pressure Plate was reconditioned and the Rotating ***embly balanced.
    It should be all ****oned up by New Year and then I'll have it run up on the Engine Dyno in the new year.
    Special thanks to Flatoz, for coming through with that single Valve Guide.
  11. captain scarlet
    captain scarlet
    from Detroit
    Looking good. The steering wheel and instruments look cool.
  12. chopt top kid
    chopt top kid
    Keep up the good work!!!
  13. brigrat
    brigrat
    from Wa.St.
    Nice build, nice steering wheel! Still looking for another.................
  14. Jimmy Tee
    Jimmy Tee
    Cheers mate...... You did a great job with restoring this one... Everyone that see's it loves it.
  15. Jimmy Tee
    Jimmy Tee
    Well, the loooong drawn out saga of my Engine build is nearly complete.
    Here she is, all ****oned up and ready to go onto the Dyno.
    She remains unpainted, as the colour of the body is still undecided.
    Before anyone says it..... the top part of the intake is now sitting the right way around, since these pics were taken.
  16. HellsHotRods
    HellsHotRods
    I just caught this thread and read of all your engine troubles. I only wish I could've told you sooner about the engine company in Fresno, CA. I have been to their place, just to check things out for myself, because their engines listed on EVILbay seemed to be too good of a deal. And when I was there, they did NOT have all the equipment to build an engine properly. I started asking them questions and they just dodged me, then they said they had to close up the doors and I had to leave. It's all a giant SCAM...the prices reflect that, you get LESS than what you pay for. I'm sorry that some people in my home state are so dirty and dishonest.
    BUYER BEWARE !!! "Shaw City Engines"
    ebay name:
    clewwho40[​IMG]( 8505[​IMG])
  17. Blackroad
    Blackroad
    from Sydney
    nice build, look forward to seeing it progress.
  18. Jimmy Tee
    Jimmy Tee
    It's been a while since my last update, so here is what has been happening.
    The car is now in my posession. A big Thanks to Wombat & Spider out at Hellbent Engineering for their fine work. Real quality work done by them.
    Whilst I was waiting for the body to come home, I made the trip up to Bendigo to get my Engine. It was put on the Engine dyno and made 147hp. Thats decent for N/A Flattie.
    Now that both car and Engine are home, I got to work on the full Mock-up of the car. Everything goes on the car now, then it's dissasembled and off to the painters.
    The Engine/Gearbox went in first.
    Next I started on the Fuel Line and Fuel Pump mock-up.
    The engine has been modified for Full Oil Flow, so I decided on locating the Remote Oil filter in a hidden position between the Gearbox and the Crossmember.
    Tail lights were next. Ive decided on these 41 Poncho lights, in keeping with the Deco theme I have for the car. They were modified to fit the flat rear panel of a Deuce.
    The Fuse Panel plate was made and installed, then came a rough-in of the wiring to all parts of the car.
  19. farmer12
    farmer12
    Great work Oz, nice to see you're still progressing! Keep it up! Thanks for the update.
  20. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    STOP!! STOP!! STOP!!!.........Your doing it all wrong! the steering wheel is on the wrong side of the car......LOL......Sorry I couldn't help myself, Nice build
  21. ESGEE
    ESGEE
    from Sweden
    Looking good, keep it up...
  22. Looking good, can't wait to see it done.....!
  23. jfreakofkorn
    jfreakofkorn
  24. Jimmy Tee
    Jimmy Tee
    Thanks all, I hope to really get it moving along alot quicker now.
    Color choice needs to be really taken seriously now and the other thing Ive been toying with.... whether I paint the Frame Black and the body in Color.
  25. Looking good, won't be long now for that first cruise.
  26. It's good to see m***ive amounts of progress & I especially love those taillights
    keep it up
  27. TheKeystoneKid
    TheKeystoneKid
    from Allentown
  28. Gojeep
    Gojeep
    from Australia
    Nice seeing it come together. :)
  29. Jimmy Tee
    Jimmy Tee
    I purchased these cool 1930's Truck Turn Signals. They ended up being a little bigger than I anticipated.
    I installed them in the select position, but I feel they may be a litle big and unbalances the look of the Rear. It's a little hard to determine until Color goes on the car and its fully ***embled.
    So for now I'll stick with them, but may change them if they look out of place at final ***embly.
  30. Jimmy Tee
    Jimmy Tee
    As stated earlier, I had the Flathead run up on the Engine Dyno as part of its build.
    In her best run she produced 147hp at 4200RPM, with 216 Ft-lb of Torque at 2500RPM.
    Here are a couple of pics of the Dyno setup, along with a couple of video's of the earlier runs.
