Projects My Deuce Coupe Project
Discussion in 'The Hokey Ass Message Board' started by Jimmy Tee, Aug 15, 2009.
  1. gjp1
    gjp1
    from Conroe, TX
    Been very interesting watching your build (and learning a lot) IMG_1331.jpg IMG_6941.jpg I'm in the same process with my 34' chev, ch***is done now on to the body. Keep your progress coming!!
  2. Jimmy Tee
    Jimmy Tee
    Looks good gjp1. Keep going.
    I had to take my ch***is back to paint because I forgot to plug up the Fender pilot holes that were in the new rail. So one side of the rail is being repainted.
    The body is also receiving some Filling before the initial Primer.
    kiwijeff and thommoina33 like this.
  3. Jimmy Tee
    Jimmy Tee
    Progress continues slowly.
    The Body is in Primer, where it will sit for 3 weeks before it has it's first Block back.
    I'm continuing with ***embly.
    Engine and brake system is in. I'm now waiting on the Leaf Spring Teflon Liners to be delivered before I can install the Front & Rear suspensions.
    AHotRod and thommoina33 like this.
  4. langy
    langy
    Looking great mate, looking forward to seeing your updates
  5. Jimmy Tee
    Jimmy Tee
    Shiny Bits starting to go on now.
  6. AHotRod
    AHotRod
    BEAUTIFUL !!!
    Your attention to detail is great.
    Jimmy Tee likes this.
  7. Jimmy2car
    Jimmy2car
    from No. Cal
    Jimmy
    Thanks so much for the info on the fan shroud. Apologize for the very late "Thank You". Been away for awhile. Regards
    Jim
  8. lowsquire
    lowsquire
    from Austin, TX
    Looking fantastic Jim! Going to be a beautiful rod . Proud to have played my part.
  9. Roadsir
    Roadsir
    Your build is coming along similar to mine (probably faster!) Looks very nice, you'll have a cool Hot Rod!
  10. langy
    langy
    Engine looks like a jewel [emoji106]
  11. Jimmy Tee
    Jimmy Tee
    Thanks Ben.... And what a major part that was you played. So glad you were involved.
    I hope I get it finished for you to drive before you take off.
  12. Jimmy Tee
    Jimmy Tee
    A few more bits went on.... and some came off and went back on for the third time, namely the rear spring back. It was not sitting correctly, so I took it out and made sure the leaves were matched to the wear groves, and then re-***embled and fitted it. Now I'm happy with it.
    thommoina33 likes this.
  13. Jimmy Tee
    Jimmy Tee
    The ch***is is back on all fours again, although I've taken the rear wheels off again to give me more room to fit the Exhaust.
    The exhaust now needs to be sanded, painted and fitted, then Battery cable, fuel lines, the remote oil filter and it's done.
    The body has had the first Primer rubdown. It will have another layer of Primer applied and rub down before the final Primer layer and rubdown for Paint..... Probably 3-4 weeks away.
  14. thommoina33
    thommoina33
    Alliance Member
    from australia
    Go jimmy, is the exhaust stainless?
    Looking real good.
  15. Jimmy Tee
    Jimmy Tee
    Yeah Thommo, full stainless Lowsquire built.
    You can see a bit of it in the bottom left corner of the last pic. So I need to sand it to get the paint to bite into it.
  16. thommoina33
    thommoina33
    Alliance Member
    from australia
    Polish it jimmy, did mine at home.
    Buy the gear at bunnings, the polishing buff and compounds.
  17. Jimmy Tee
    Jimmy Tee
    Nah... I don't want the exhaust highlighted at the rear. I want it to just blend in and be hidden. The Sinister Black look is what I'm after... Similar to 3wLarry's master creation below. ImageUploadedByH.A.M.B.1426567512.266416.jpg
    kidcampbell71 likes this.
  18. thommoina33
    thommoina33
    Alliance Member
    from australia
    Gotya jimmy, killer.
  19. Jimmy Tee
    Jimmy Tee
    Bodywork moving slower than I would have liked. I gave him a Rev up on the week end, so hopefully only a couple weeks left.
  20. Jimmy Tee
    Jimmy Tee
  21. Well done Jimmy
  22. langy
    langy
    Looking great Oz [emoji106]
  23. Jimmy Tee
    Jimmy Tee
    Body work is moving along.
    Door Gaps all done.
  24. Jimmy Tee
    Jimmy Tee
    It's Door Hinge polishing time.
    Here is a before & after pic, after the first step... 120 Grit.
    Next is the 800 rub and then a final 1500 rub before they are buffed and Cleared, for nothing looks nicer than polished Br***.
  25. ago
    ago
    from pgh. pa.
    Br***? mine are steel.
  26. Jimmy Tee
    Jimmy Tee
    Last pice of the puzzle before I can call my Frame ***embly complete.
    Heat Proof Ceramic coated exhaust from HPC, Vic.
    langy and thommoina33 like this.
  27. langy
    langy
    Looking sweet Oz [emoji106]
  28. Jimmy Tee
    Jimmy Tee
    Looks good when fitted, but bolts need to be painted Black.
  29. TomT
    TomT
    Great looking build/work - it will be a killer ride ...
    509garyd likes this.
