Projects My first hot rod : '28 A
Discussion in 'Traditional Hot Rods' started by chrisp, Aug 27, 2023.
  1. chrisp
    chrisp
    I'm done mocking up the cowl, everything is held by screws and clecos where there are rivets originally (at least on my tudor).
    So I placed it on the frame to see how well it fits.
    Well... it needs some tweaking before it bolts on the frame.
    I also wanted to see the windshield in place, so off with the factory windshield posts, and the filler neck.
    For a rough first fit, it's pretty close. It will requier a minimal amount of work.
    I'm super happy, Sellers was making a high quality Hallock.
    I just love it. It's expensive but the look can't be beat!
  2. Bandit Billy
    Bandit Billy
    Yes, very beautiful windshield frame. I am curious, can you get chrome plating done locally?
    Outback and winduptoy like this.
  3. chrisp
    chrisp
    Yes, there ain't many at least aound me. The closest to me which is about a 40mn drive, I will never set a foot in there ever again.
    Then there's one about an hour and half away that does good work, are kinda expensive but they changed owner and don't know how they're doing now, I'm expecting 2 Alfa bumpers from them in a couple weeks, so we'll see.
    I don't know if they do aluminum though and it might be out of my budget so I might just polish the windshield frame if that's your question.
    Other chrome shops are really far and I'm not a fan a shipping valuable and sometimes impossible to find parts, I don't want to be looking for my or my customers parts on craigslist.
  4. chrisp
    chrisp
    Everything's going according to plan, I figured out all the parts that came with the kit and I'm missing some screws and nuts and bolts.
    It seems somebody over at Brookville didn't pack everything, for example there are 5 hinges screws and no tailgate hinge bolts, I didn't check every nuts and bolts yet, but everything was neatly packed so they didn't get lost during transportation, I just hope I do have all the rivets.
    That ****s because imperial hardware is difficult to find and expensive here.
    Anyway I wanted to see how I could mount the '32 dashboard without the dashrail, weld it in or bolt on? And in a neat way.
    If welded, can I still have access to the upper hinge nuts, do I need to put some inserts?
    Then I remembered I have this '31 to '35 Renault Primaquatre dashboard I found some 30 years ago in a pile of s**** metal.
    Kind of look like a '33 Ford dashboard, it's the exact same width as the '32 dashboard, it fits like a glove on the A tank, but it's way to bulky. Plus Alchemy insert wouldn't work on that.
    So it's angle grinder and mig time.
    After some hours:
    I will mold it to the tank and the sides can bolt to the A pillars, I even could retain the original gas tank if I wanted to. Best part I still have access to the hinge bolts.
    I couldn't finish it because I ran out of welding gas and I need to cut the lower part of the tank.
    But it fits like a glove, and I like the look of it and the way it blends in.
    I'm super happy about it.
    I will have to check how to bolt the windshield with the dashboard in, that will determine if it will be molded or bolted in.
  5. chrisp
    chrisp
    Not much done, been working my *** off on customers cars.
    At first I didn't want too much bling on the car, I was thinking something like late 40's early 50's style, but I like shiny and detailed cars, so ...
    I decided to fabricate my convertible top mounting brackets out of polished stainless steel.
    I'm gonna fabricate the tailgate hinges out of polished stainless steel too and install polished stainless steel door hinges.
    I did some mechanical work because I don't have much time to work on the car and that is less set up time than for the body so I can do more in the little time I have these days.
    The front end is pretty much done and ready to go in, I didn't take the time to take any pictures unfortunately.
    Now I ran into something I didn't expect on the engine.
    I'm using a Powermaster 9508 mini starter, made for the French flathead, but it's a push type starter gear, and a Mc Leod 563300 flywheel for a '49-'53 flathead so the bevels on the ring gear teeth are on the outside so obviously for the pull type starter.
    I'm no mechanic so I looked for an answer and it seems people say it's not a problem with the solenoid type starter. But I'm skeptical because I've seen this done on a Jag engine and the result wasn't pretty.
    Is this true? Can I use these parts together without risking damaging the teeth on the flywheel?
    Thor1, Outback and winduptoy like this.
  6. Outback
    Outback
    from NE Vic
    I'm sure there are other ways but I have put the lead in by hand on a flywheel before, you could possibly swap the ring gear over if it's a replacement item (shrunk fit), but I'm not so sure how well it'll come off undamaged
    winduptoy likes this.
  7. chrisp
    chrisp
    The thing I don't understand is that the starter is said to be manufactured for the french flathead with stock or aftermarket aluminum flywheel and both are for the pull type starter.
    Today I also found out that the aluminum flywheel is 3mm or 1/8" thinner. So I had to cut the bolts on the lathe, it would be great to have this kind of infos in the description of the product to buy the correct stuff from the get go.
    Now what do I do with the pilot bearing?
    Can it stay like this or do I need to find one that is 1/8" thinner ?
    Here's the front end I'm ***embling for it, I'm not decided yet if I'll be using a cross steer '40 box or an F1 box, I'll see when mocked up.
    Thor1, winduptoy and Outback like this.
  8. chrisp
    chrisp
    I feel like an idiot : wrong flywheel...
  9. Outback
    Outback
    from NE Vic
    Dang, better to work that out now, than after mucking with it
    Thor1 and winduptoy like this.
  10. chrisp
    chrisp
    Yep, but still doesn't explain how that push style starter is supposed to work with the Factory pull style flywheel. Bevels are still on the wrong side. Or it doesn't matter?
    Thor1 and Outback like this.
  11. chlsnk
    chlsnk
    from Kansas
    That Renault dash has a great look. In your Initial post you said your engine carries a warmacht tag, does that designate ww2 use?
  12. chrisp
    chrisp
    The 4 cyl came from an AA truck, yes it's a german WWII usage, I suspect that the person who rebuilt the engine at that Pellerin garage or machine shop either did the best with what was on hand or decided that some sabotage was in order because I found some sketchy stuff.
    Here's the plaque
  13. Outback
    Outback
    from NE Vic
    I would be inclined to put the bevel's/lead in onto the ring gear as it will be kinder on both starter & ring gear.
    I've done it by hand with a die grinder before on an early car we fitted a different starter to. You can get a reasonable result with a steady hand.
    winduptoy and Thor1 like this.
  14. chrisp
    chrisp
    So according to Powermaster the flywheel doesn't need to have the bevels reground
    I machined the oil pan to solve the starter/flywheel distance problem
    I ***embled everything and gave it a try which was successful : the starter engage perfectly and the engine cranked for the first time since 1992 when I bought it.
    Now I have an 8BA flywheel where a 59A should be.
    After I install a pedal ***embly I'll see if I need to space the throughout bearing or not.
    With the T5 matted to the engine I can now place it in the frame to position the motor mount who will be riveted to the rails. I had to relevel the frame prior since I moved it.
    I positionned the front suspension with the stock spring to see what I need to modify next and where will the hairpins tabs will be.
    I'm gonna have to drop the rear of the transmission, probably modify the X member and maybe even space the front of the engine in order to have the correct carb float level.
    I was checking the pedals I have to see which one I can use, I only have a '46/'48 Ford pedal ***embly, unfortunately the brake pedal is badly rusted, the bracket is unusable for this aplication.
    None of the pedals I have work, so I decided to unearth the after market ones I got for free that I promissed myself not to use...
    After some measurements I machined a shaft for them using some bar stock and a Jaguar clutch fork shaft, I still have to weld some flat stock so I can bolt it to the frame.
    But I already saw that I'll probably won't be able to keep the hand brake on the left and that the brake pedal interfer with the oil pressure sensor, I have to first finalize the engine placement.
  15. chrisp
    chrisp
    I couldn't stand those pedals so I back tracked a little and decided to use my '48 pedals, after hours of welding and grinding I made the brake pedal pretty again then I reshapped both of them to make this :
    Now I'm pleased with them.
    Then I tackled the tube shock bracket, I have a pair of free reproduction F1 bracket
    Since it's a full fender car I threw on a fender to check for clearance
    Hard to see on that dark blury pictures but I have about 1/4" room to spare with the fender
    For those who don't know the problem with F1 bracket and fenders, here's how much it needs to be reshaped
    Right now the shock absorber is barely compressed but since I put some tires on the ch***is I now know I'm gonna reverse the main spring leaf thus compressing the shock absorber a little more to be closer to it's operating specs.
    I think now I will have to rebuild the rear end to mock it up in the ch***is to be able to finalize the front end and transmission mount.
    Tim, Bigcheese327, winduptoy and 4 others like this.
  16. Outback
    Outback
    from NE Vic
    Those pedals are much more pleasing to the eye
    Thanks for the update's
    winduptoy and CSPIDY like this.
  17. chrisp
    chrisp
    Not much done, I have been quite busy with my customers cars.
    But I reversed the front main leaf spring and fine tuned the spring.
    I decided I wanted shiny tailgate hinges so instead of chroming the Brookville one, I decided to fabricate them out of stainless steel so I can polish them once all the mock up are done.
    I modified only the bottom bevels and will match them better to the upper ones, other than that they're identical and it was not an easy job.
  18. Bugguts
    Bugguts
    Nicely done so far.
    I really like how you created new tailgate hinges to polish.
    That’s hot rodding!!
    winduptoy, osage orange and CSPIDY like this.
  19. winduptoy
    winduptoy
    been following along and I admire your resourcefulness....you have vision and talent...
    carry on...
  20. chrisp
    chrisp
    Thanks, I try my best, the good thing when you do something for yourself is that you can do whatever you like and not worry about the time spent on stupid little details that nobody will ever notice and spend whatever time to build something that you could buy.
    Again I had a lil bit of time for myself so I got rid of the gas tank and shaved the neck, mocked up the '40 Ford steering box thanks to continentaljohn.
    I modified the Ford steering shaft with a Jaguar XK140 steering shaft, that allows me to have a very compact u-joint that looks and is actually old
    But damn, that is tight, I might have to modify the header to gain some clearence. For now it works.
    It's still possible to remove the head without taking out the steering shaft, at least for now, that's a bonus.
    I'm building a steering tube out of stainless steel again to polish, I can't help myself : I like shiny stuff.
    I'm using an original '32 ford column drop, thanks again continentaljohn, to mount it in the car.
    I'll need to tune the length and angle when everything is mounted tightly. I'll also will modify the Jag steering shaft for my steering wheel.
    Peugeot 403 steering wheel that I'm planning on using, I like it a lot.
  21. chrisp
    chrisp
    As always I'm too busy to tackle some big task on the rpu, so small task it is:
    The steering box is mounted solid to the frame and since I won't be able to use the nice shinny dropped headlight bar I bought without some reworking because of the '32 grille and I decided to use it on the delivery. Now what for the rpu? Why not the garage sale hi boy headlight stands I got without needing them.
    The shape is way off, needs to be turned 90° from it's pad and it's too high, but nothing that a torch and a big hammer can't fix.
    Turns out it was a good idea to buy them.
    I also welded together the 2 pieces of the Hallock frame and mocked up a cardboard template for the windshield so everyday I can look at it and see if I like the gl*** shape or not.
    What do you guys think about the windshield shape?
    Tim, Deutscher, dmar836 and 5 others like this.
  22. hfh
    hfh
    from Western MA
    I think you will love driving behind that windshield. But I would encourage you not to commit to a gl*** shape until your car is much more together with grille, hood, all body parts, etc. The longer you wait, the more likely that you will make a good choice on the gl*** shape. HFH.
  23. Tim
    Tim
    from KCMO
    Looks good but I would toss a driver door on for a better perspective.
    really neat hot rod in a ****er for a roadster pickup
  24. chrisp
    chrisp
    It was on, I removed it to fabricate some cage nuts because I don't like the screw and nut ***embly, it get old very fast when you have to install and take off a door multiple times.
    winduptoy and Tim like this.
  25. Bigcheese327
    Bigcheese327
    This is neat. I look forward to watching this progress.
  26. chrisp
    chrisp
    This week task took way too much time for what it is : a steering wheel adapter to mate the Peugeot steering wheel to the Jaguar steering shaft.
    I started with an old Jaguar xk120-150 steering wheel
    I just needed the hub
    Then after hours of welding and machining
    Obviously it's not perfect as I ran out of gas and can't get a new cylinder before a week. One of the pleasure to live in the middle of wheat fields
  27. chrisp
    chrisp
    I got my hands on a set of '33 Ford pedals, so another change of plan for the pedals.
    They requiered just a little bit of tweaking to fit , to actuate the master cylinder I needed a bell crank to change from pull to push, since I needed a new shaft, I machined a longer one and placed a modified model A mechanical brake actuator on it on a custom br*** bushing, it even has now a zerk fitting like the pedals.
    All this because I didn't want to cut and weld the brake pedal.
    On the other hand, I will have to cut and weld something for the clutch to have it to work, either on the pedal or balance shaft or both. But I'm more comfortable doing that on the clutch pedal than braking parts.
    A better view of what I did.
    The springs are not mounted yet, they're just holding the pedals in place.
  28. Bigcheese327
    Bigcheese327
    @chrisp all the image links in your last two posts are showing up broken for me. I'd like to see, though!
  29. chrisp
    chrisp
    That's weird, for me too but when I click on edit it shows the pictures and the links don't appear to be broken?
  30. Stovebolt
    Stovebolt
    Hi @chrisp , love where your build is going.
    I am interested in seeing the photos of your front upper shock mounts - it’s something that I am looking at doing.
    my build will differ, as I’m still running mechanical brakes, and push-pull steering using 32-34 spindles.
