Most of you know him as "draggin ***", he was banned a while ago. Zack moved out to cali to work at hollywood hotrods, but decided cali wasnt his thing and moved back. body is a 1930 model A coupe that someone cut into a roadster and never finished. started building this when he got back, theres a build thread on the czar board. not finished yet, gonna be a late 40s style car, glossy black he says. anyway, thought some of you might like it. ill post pictures of when its finished next year.
it was 2x6 8th inch steel tubing, pie cut and then bent to match the body(which is just sitting loose on it now), model A frame horns up front, 32 front crossmember, model A rear crossmember in back, and 32 frame horns in the back, 35 ford truck mid-member, and the back of the frame stepped up.
Is he still welding stuff with coat hangers? Hahaha, tell him Johnny Cliche thinks he's still a jerk whatever happened to that black and green thing with the Cad motor he was s***ching together? I always wanted to see how that thing ended up...tell him I said good luck and it'd be good to catch up with him sometime somehow...
