History My Grandfather's 32 Roadster, A True 50's Hot Rod
Discussion in 'Traditional Hot Rods' started by Josh Schutz, Dec 16, 2022.
  1. F-head
    F-head
    Wow what a great survivor
    Love the column shift
    Spooky, hfh and Josh Schutz like this.
  2. The37Kid
    The37Kid
    This looks just so right, did it ever see any race use, Dry Lakes or Bonneville?
    Nobey and Josh Schutz like this.
  3. 1946caddy
    1946caddy
    from washington
    Seen this guy lurking around?
    SDS, LOST ANGEL and chryslerfan55 like this.
  4. 19Eddy30
    19Eddy30
    from VA
    Tac drive ***uming ? off the Gen
    Tman, slim38, Outback and 5 others like this.
  5. 19Eddy30
    19Eddy30
    from VA
    No on locking hood latch , see post /pic above ,but could be done.
  6. 19Eddy30
    19Eddy30
    from VA
    Back story also about 61 yrs setting inN.M.
  7. Black_Sheep
    Black_Sheep
    All it needs is a little clean up. I’d go through the mechanical stuff so it’s safe and reliable while leaving the paint and interior as is. Very cool ride…
    Josh Schutz and chryslerfan55 like this.
  8. Deuce Daddy Don
    Deuce Daddy Don
    Great story!!----At 90 years I have given my roadster to my son to enjoy as I have for 300,000 happy miles.
  9. V8-m
    V8-m
    from Alaska
    Yes Tach drive - Stewart Warner kit
  10. Hitchhiker
    Hitchhiker
    Is it done yet? o_O
    Josh Schutz likes this.
  11. Josh Schutz
    Josh Schutz
    from Colorado
    We want to add a fan, but we're running into clearance issues with the tach drive generator. Does anybody have any suggestions? We would prefer to do a belt driven, but a 6v would work if we needed to. 20221107_151324.jpg 20221107_142928.jpg
  12. Josh Schutz
    Josh Schutz
    from Colorado
    Yes those are latches for a hood lock. We considered removing them, but decided against it.
    chryslerfan55, catdad49 and The37Kid like this.
  13. Josh Schutz
    Josh Schutz
    from Colorado
    They sure are!
    chryslerfan55 and catdad49 like this.
  14. Josh Schutz
    Josh Schutz
    from Colorado
    It has a left column shifter. We think it can off of whatever the engine was from because there no place in the ****** for a floor shift.
    Jeff34, chryslerfan55, brEad and 4 others like this.
  15. 51504bat
    51504bat
  16. 62pan
    62pan
    Why do you feel the need for a fan? If it never had one why the need to change.
    Tim likes this.
  17. Nobey
    Nobey
    Wow Josh, this car is incredible, It has all the whistles and bells and is probably in print somewhere.
    It's not a 59 block they are post war, it's a 41 and probably a Mercury. Check the bore, it will be 3 3/16
    or larger, making it a Merc. It has adjustable lifters also, so someone knew there stuff. Chrome water
    pumps were done back in the day and it made a flathead look even better. The cam will be pre war, with
    the lobe centers moved out to accommodate the valves being closer to the bores. These engines were
    the racers choice, so be sure to save that cam. Outside the roadster shows so much detail, with the radius
    around the steering box and all the chrome. The front axle looks like a rare Zimmer and that top knocks
    my socks off. They just don't get any better than this. Congratulations, and really sorry for your dad loss.
  18. Itchy-Pit
    Itchy-Pit
    What a great share - THANK YOU
    Josh Schutz and Spooky like this.
  19. F-head
    F-head
    That thing is Awsome just the way it is
    Please do lots of homework before changing anything
    There are very few true survivors left such as this
    It’s a beautiful car and deserves being treated with kid gloves
  20. BILL LUPIANO
    BILL LUPIANO
    from Canada
    I'd sleep in the garage next to it! Great car,great story.Thanks for sharing!
    OLLIN, chryslerfan55 and Tim like this.
  21. The37Kid
    The37Kid
    My Dad's roadster hasn't run since 1983, I can understad that life gets in the way, maybe 2023 is the year for me.
    Bob
    chryslerfan55, joel, Outback and 2 others like this.
  22. Josh Schutz
    Josh Schutz
    from Colorado
    That's a good question. Neither of us really had the knowledge or means to move it and get it running. We ***umed that something was really wrong with it since my grandpa put it away. It was my father in law that got us motivated.
    chryslerfan55, brEad, drdave and 7 others like this.
  23. Tim
    Tim
    from KCMO
    Sometimes they get parked for something pretty simple. Life gets in the way and time just moves faster and faster. Next thing you know it’s been decades.
    a lot of flathead hot rods did and do run with out a fan. I’d make sure the pumps work and the rad is good and see how it fairs as is before I started fixing a problem that might not be there
  24. alchemy
    alchemy
    Yeah, what Tim said. If the thing used to bomb around the hot southwest it might be just fine in cool Colorado with no fan.
    WC145 likes this.
  25. solidaxle
    solidaxle
    from Upstate,NY
    To add clearance for the fan, you can change the generator mount. The one you have twists the generator up instead of straight out. Here's a common Offenhausen that will change the angle. The down fall is you can't run with the hood on. Gen Mount Striaght.jpg
    chryslerfan55, catdad49 and Outback like this.
  26. dirt car
    dirt car
    from nebraska
    I'm sure a fan could be utilized in a number of ways, might be wise to get it running & see how it cools with close attention to all aspects of the system .
  27. A Boner
    A Boner
    Beautiful survivor!
    Most survivor Hot Rods have something or another, wonky…not this one. Keep it as original as humanly possible, please!
    Tman, chryslerfan55 and Josh Schutz like this.
  28. Rickybop
    Rickybop
  29. WB69
    WB69
    from Kansas
    Great old car. Enjoy..
  30. Little Terry
    Little Terry
    Fanastic. Just be careful you don't do 'too much' to it.
    By dipping the block, you will now be left with the dilemma of painting it - then you have to decide where to stop.
