My Hemi Is Pinching Plugs Closed...Help Needed!
Discussion in 'The Hokey Ass Message Board' started by MR. FORD, Feb 21, 2012.
  1. MR. FORD
    MR. FORD
    from Austin, TX
    My only guess is that it came from one of the cheap *** air cleaners. I have had to fix the two center ones a bunch of times. Who knows? And no, I didn't find the nut sitting on top of the head.... I just put it there for the pic. Im taking the head to the machine shop today, and go from there. As far as the piston goes, in a perfect world I would replace it. They were custom made by Ross, and as far as I know, they won't just make you one. I am way too broke, and way too short on time to replace all of them. Im just gonna clean it up as best I can and run it. I know it will at least get me to the roundup....:cool:
  2. 34toddster
    34toddster
    from Missouri
    Is the piston cast or forged? I really don't think the piston is trash because I've had this happen once also and the piston was fine but hey you never know!
    Good luck on getting it going again as soon as possible.
  3. MR. FORD
    MR. FORD
    from Austin, TX
    Thanks man.... the piston is forged.
  4. tubman
    tubman
    I spit an exhaust valve out of the engine in my dirt car and it did a number on the piston, a .060 over J&E for a 331 which is not a cheap piece. I pulled it out and had it crack-checked, and it had no structural problems. I did take it to a very skilled welder who welded up the gouges in the head of the piston, and then ground it down to it's original shape and finish. That was a few years ago and the engine has run strong since. Single pistons were not available, so that was my only choice, and it worked. I would go to the trouble of pulling it and double checking everything to eliminate the probability of problems down the road. From my experience, it looks like you lucked out.:)
  5. Ebbsspeed
    Ebbsspeed
    You're probably OK with the piston, Ross makes some tough hardware. I don't see any real deep pits, looks like the edge of the piston in the valve reliefs has the worst damage. Pull it out and polish off as many of the sharp edges as you can. Take a good look at the top half of the connecting rod bearing as well.
  6. scootermcrad
    scootermcrad
    Yeah, I agree. If it's forged you're probably fine.
    As for Ross, if you still have the paperwork ***ociated with the pistons (they usually come with a quality check list showing weight of each piston, specs., etc.) there is probably a reference number to your order. I believe they keep your order on file for quite awhile, and I think they will make you one piston if you REALLY had to. But it will obviously cost you. You're probably okay, though.
    I also agree with Ebb. Probably a good idea to pull it off and do a good inspection as well as knock down anything that may do harm.
  7. ididntdoit1960
    ididntdoit1960
    from Western MA
    Just had the same thing happen to a buddies O/T 1967 GT500 the jamb nut for one of the aircleaner studs was the culprate - the offending cylinders plug was destroyed too - your lucky - we had to sleeve his cylinder (and completely rebuild the 428) as it cracked the wall in three places!
  8. 73RR
    73RR
    The pics tell me that the nut bounced freely and was not crushed between piston and 'whatever' so structural damage to the piston is likely non-existant.
    I would clean off the piston top as best you can without removing too much material...a buffing wheel might be enough... and the same with the combustion chamber only there you will need something like a flapper wheel. Just get rid of all of the 'points' that can get hot and cause pre-ignition. Yes, carbon build-up will be an issue with all of the pockets.
  9. S_Mazza
    S_Mazza
    I agree with the majority opinion ... the piston looks to me like it's probably fine. I wouldn't really want to take the bottom end apart just to check it unless I absolutely needed to be sure. But I would like to clean up the top a little. Bead blasting might be good, but you can't really do that with the thing in the motor. I would certainly ****on up everything tight to keep grit out of the motor, no matter what method I used.
  10. loudpedal
    loudpedal
    from SLC Utah
    Dude, I think it's no good now. You need to build a new Hotrod. I'll come get it so you won't have the h***le of getting it out of your way :)
    Realy, I agree with those above. Buff it off and put it back together with a new valve. You'll never know it happened.
  11. Dreddybear
    Dreddybear
    Hurry up. Side by side donuts.
  12. Brad54
    Brad54
    from Atl Ga
    And that, ladies and gentlemen, is why you come off the wallet for a few hundred bucks to pop for an $800 set of forged pistons over a $400 set of cast slugs for our vintage motors.
    There's a very real chance that would have shattered the dome on a cast piston, at which point the con rod becomes a battering ram that slams through the cylinder wall and out the side of the block. If it's REALLY feeling froggy, it'll break the crank on the way out.
    I'm really happy for you that this damage is so slight.
    At the very least, I would pull the piston and file down all the high spots on the divots--they'll become hot spots and can cause detonation.
    I'd also call Ross... they're a race piston company... they're used to making one or two or four pistons for racers that do exactly what you just did.
    You may find out they will only sell a set of 8. But you might also find out they'll do one for you. Either way, the phone call is cheap.
    Congrats on dodging a bullet, and kudos for stepping up during the build and buying the insurance of forged slugs.
    -Brad
  13. yardgoat
    yardgoat
    Glad you found the issue and its not a minor thing but then could have been worse.Good luck,magic words for a Hemi are zoom,zoom before start up.......YG
  14. CGkidd
    CGkidd
    LMAO. Funny *** ****.
  15. raengines
    raengines
    from pa.
    to be safe, i think the piston needs to be checked to make sure the top ring moves feely in the ring groove
  16. falcongeorge
    falcongeorge
    from BC
    x2. And if that had been a hyperutectic the bottom end would now fit loosely in a 5 gallon bucket.
  17. MR. FORD
    MR. FORD
    from Austin, TX
    Dropped the head off at the machine shop today. Thanks you guys for the moral and mental support. Definitely could have been worse! Ill update you on monday when I hear back.
  18. MR. FORD
    MR. FORD
    from Austin, TX
    Send me a PM, and Ill tell you the address to send the car hauler to....:D
  19. mart3406
    mart3406
    from Canada
    Back around 1974, a buddy of mine - also
    currently now on the HAMB - but who for
    the sake of brevity, shall remain nameless
    (but you know who you are. "BL"!:D) - was
    campaigning an NHRA-legal Super/Stock
    250hp/327 '65 Corvette. He had replaced
    the stock cast iron four-hole closed-plenum
    intake manifold with an Edelbrock 'Tarantula'
    (the hot Super/Stock 'trick of the day' back
    then!) open plenum intake, but per cl***
    rules, instead of a Holley carb usually used
    with these manifolds, he had to use it with
    the original 250hp-spec 4GC Rochester carb.
    Unlike Holley carbs though, which would be
    perfectly safe on an open-plenum intake,
    4GC Rochesters have a large, single, 7/16
    inch-or-so diameter machine screw in the
    center of the baseplate, to attach it to the
    main body of the carb. With the stock 4-hole,
    dual-plane, divided-plenum intake, if the
    machine screw comes lose, it would simply
    **** up against the divider in the center of
    the stock intake manifold and it couldn't fall
    into the engine. Not so with an open-plenum,
    single plane manifold design like the Tarantula
    though. And sure enough, that's exactly what
    happened too! He had staged the car and
    was sitting on the starting line, holding the
    revs at 8500 rpm as the tree flashed down.
    Then all of a sudden, just about the same
    time as the green flashed on, the machine
    screw in the carb baseplate came loose,
    dropped down into the intake manifold and
    got ****ed into an intake port and "KABOOM!!!"
    In about half of a nano-second, a fresh,
    $5000 (a LOT of money for an engine back in
    1974!) Super-Stock race engine was reduced
    to 'instant, ready to eat', shrapnel and a
    smoldering pile of broken parts!!!:eek: I think
    he was able to salvage the carb & intake. one
    cylinder head and 5 or 6 pistons from the
    carnage. Everything else in the engine was
    trashed!:eek:
    Mart3406
  20. Jimbo17
    Jimbo17
    You can buy copper washers in different sizes for under the plugs.
    I used to use them all the time for turning the spark plug electrode so that the open end was in just the right position for firing.
    Hope that helps. Jimbo
  21. mr.heavy duty
    mr.heavy duty
    over rev can stretch a rod.. just a bad thought ....
  22. Ryan
    Ryan
    ADMINISTRATOR
    This was fascinating. Be sure to report back on how it all goes back together Mark.
  23. That went about as good as something bad can go.
  24. MR. FORD
    MR. FORD
    from Austin, TX
    Huh? Keep your bad thoughts away man.....
  25. JOE C.
    JOE C.
    hey Mark,
    glad your getting this figured out.
    Thanks again for the ride to the Revolution!
  26. mashed
    mashed
    from 4077th
    I had a valve seat come loose on my '46 Knucklehead and it broke up and did a number like that on the piston and head. I had the seat repaired and ran that piston for YEARS. I replaced a blown head gasket years later and noticed carbon had conveniently resurfaced the top.
  27. MR. FORD
    MR. FORD
    from Austin, TX
    Hey Joe, good to hear from you. Now we know what happened on the way there..haha
  28. Rusty O'Toole
    Rusty O'Toole
    Thanks. It's nice to be appreciated.
    For an extra bonus, you guys, if you are ever in this predicament you can remove the object from the cylinder easily. Take the spark plug out, stick the air hose in the hole and blast away. The air will blow the object out the spark plug hole (if it is small enough and it usually is). This works best if you do it before you start the motor.
  29. Mark, It's an extra days work, but I would pull that piston/rod and check to make sure the rings are free, check your rod for straightness and see what your bearing looks like.
    It will be worth the piece of mind...
    Hans
  30. CGkidd
    CGkidd
    Any updates?
