my latest buy...
Discussion in 'The Hokey Ass Message Board' started by C. Montgomery, Jun 20, 2004.
  1. C. Montgomery
    C. Montgomery
    For my Y block going in my 49 coupe.... [​IMG]
  2. Mr. Happy
    Mr. Happy
    Give that to me.
    NOW.
    Thank you.
  3. radical56chevy
    radical56chevy
    thats gonna look good on their..post a pic when ya get it on..
  4. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    wow... I just picked up a Tri-power setup...but because im running a 272...ill just have to fake it...running the center carb only...at least the spectators will think its a hopped up ride...he he he [​IMG]
  5. metalshapes
    metalshapes
    I saw that one on Ebay.
    Would you mind taking a couple of measurements for me, after it is sent to you?
    I would like to build a 6X2 U-fab like setup for the Nailhead I am going to use in my Special, and I want it as close as possible to being right...
  6. Hard On Parts
    Hard On Parts
    from SE Kansas
    Kool, post up after you install.
  7. leadsleadolds
    leadsleadolds
    Het Metalshapers I think the guy at www.northwestcustoms.net makes that set up for the nailhead you might want to check with them
  8. BLAKE
    BLAKE
    Nice score, Cody... what ****** you using behind the Y-block?
  9. C. Montgomery
    C. Montgomery
    Blake I don't know- 4 speed? I'd like to put my T-5 behind it but I'm not sure it'll work...Plus it has to be rebuilt..
    metalshapes-I should have it by the end of the week..PM me with what you need, I'll try my best to get you what you need...
    Cody
  10. C. Montgomery
    C. Montgomery
    dammit, why is my avitar not showing up?????
  11. ABone312
    ABone312
    You should go for the T5, you won't regret it. That is what I run behind the 312 in my A. It is well worth having it rebuilt to run it. Just my 2 cents.
  12. C. Montgomery
    C. Montgomery
    what's involved in putting the t-5 behind it? Started to put one behind the flathead that was in it, modified the bellhousing got the right clutch then found out the trans was no good...basically the same thing for the 292?
