Projects My latest project
Discussion in 'The Hokey Ass Message Board' started by fordf1trucknut, Jul 28, 2008.
  1. fordf1trucknut
    fordf1trucknut
    I have been trying to find an original 4x4 conversion pickup for a while with no luck so I decided to build one in the driveway.
    It isn't a hot rod but I figured the pickup guys on here might want to see a 4x4 pickup truck that isn't a ch***is swap and lifted. It sits a tad higher than a stock truck and I could probably remove a few leafs and get it lower.
    I saved this ch***is bed and cab this past winter from the crusher for s**** weight. The frame was nice, the cab floor boards were in good shape but the area above the windshield was completely rotted out. The exterior metal is pitted pretty bad but I plan on running it in salt to a perfect paint job isn't to big of a concern.
    A combination of parts from a junk early bronco, a chevy truck, a dodge truck and an early CJ brought me to this point this spring:
    I picked up a junkyard ford 200 I-6 and put it in with an early bronco 3 speed and t-case with some motor mounts made from s**** metal I put a header on the motor for a little better performance (the manifold that came with it was cracked anyways):
    I had to cut and brace the original cross member (so I could keep the stock pedal setup) and make a new one right behind it to get the engine as far back to the firewall as possible to give me room for the radiator.
    currently I have the cab painted inside and out with 1944-1957 OD green. I put a light coat on the hood and bed to get an idea of what it will look like.
    I would like it to look like a korean war era army base truck.
    It is now running, driving, and stopping. The final things I have to do to get it ready for the road are:
    Tie up loose ends.
    Make a wiring harness (right now it is just wired enough to run and charge...no lights or guages.).
    Install the side gl*** and wing windows.
    buy and install headliner.
    buy and install some non directional military tires (I will be running original 16 inch rims).
    put a tailpipe on (right now the exhaust ends at the muffler at the back of the cab.
    install the bed floor.
    Finish up fixing rust in the bed and hood and paint the rest of the truck. (I am going to paint the fenders and running boards black and the rest of the truck OD green.
  2. spudshaft
    spudshaft
    I really, really, really like that. Great work.
  3. curbspeed
    curbspeed
    Perfect for pulling old crusty tin out of the bushes. Put a winch on that ****er. Were going tin huntin'! YeeHaw!
  4. fordf1trucknut
    fordf1trucknut
    Yes, I plan on driving it daily.
    I currently drive my 1952 f-1 (2wd) most of the time BUT apparently i built a little too much motor for it and keep going though rear ends and transmissions (I just blew another ****** in it this weekend...that makes 3 ******s and 3 rear diffs). I park it in the winter anyway due to it not liking wet or snowy roads and I drive my 79 f-350 4x4......the mileage ****s in that truck so....here I am building this "new" one.
  5. I SMELL SMOKE
    I SMELL SMOKE
  6. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Now that's cool!!!:cool: I love the little six!
  7. fordf1trucknut
    fordf1trucknut
    Thanks guys.
    Curbspeed, I have no plans of adding a winch (all the old tin in PA is usually rusted too bad to pull out of the woods) BUT.......I do have the air conditioner compressor that came with the motor. Once I get the truck on the road I may put the compressor back on the motor and plumb it as an air compressor so I can use air tools out in the middle of nowhere. There have been times where a cutoff tool would have been handy, cutting off parts with a hacksaw isn't fun.
  8. Isaak_M
    Isaak_M
    from LV/WA
    that's really cool.
  9. guiseart
    guiseart
    Looks pretty "stock" to me - nice job!
    (I like Rocky's new one too, even if it is a ch***is-swap)
  10. 1959Ford
    1959Ford
    Very cool. I really like the Korean War era theme you chose for the truck. Nice work...
  11. Chris
    Chris
    Very Nice John! I bought these 7.50 16's from Les Schwab (I don't know if you guys have them there) for like 65.00 a piece. About 33" tall. There non directional and have been on my 1960 factory 4x4 for years with no problems!
    Keep it up ;)
  12. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    2 words.....Bad ***!! I had a '60 2wd...same color...same rust spots...I wanted to make it 4wd...But I s****ed it and got a '57 Big Window.
  13. fordf1trucknut
    fordf1trucknut
    Well I am tailights, tires, a couple bolts and a bed floor away from getting it inspected.
  14. Topless Ford
    Topless Ford
    Good save, that truck rocks!
  15. Great truck, very cool. It will be lot's of fun to drive.
  16. fordf1trucknut
    fordf1trucknut
    here are a couple more pics.
  17. biscuit eater
    biscuit eater
    Cool truck! Check out "DL Bensingers" website, they have lots of cool military stuff for fair prices.
  18. fuzzy bunny
    fuzzy bunny
    Very cool truck! The interior pannels look to be in great shape.
  19. fordf1trucknut
    fordf1trucknut
    Well I got everything done....bed floor, aligned it.....etc...etc
    I also got the coker firestone military tires for it installed and drove it around a good bit yesterday (it runs stops and handels pretty well for a cobbled together pile of junk parts).
    The only thing left to do before I get it inspected and start driving it everyday is to go over everything and make sure that everything is tight and to be sure that I didnt' miss anything. I also still need to hook up a couple of the guages (I had to order some balast resistors to cut the voltage down to 6v at the guages and they aren't in yet).
  20. Chris
    Chris
    WOW! That thing looks super bad ***!!!!! Great job!
  21. TGrant
    TGrant
    from Ohio
    That thing rocks, great job. I have always thought those trucks had the coolest interiors of all.
  22. vexner
    vexner
    Very Kool looks super tough,I all fits well toghether!
  23. looks great man good job.love that green was it rattle can?
  24. Kustm52
    Kustm52
    Nice. Now you need one of those govt. issue NOMENCLATURE tags on the dashboard just to make it official...
  25. fordf1trucknut
    fordf1trucknut
    Thanks guys.
    The paint is rattle can OD green that I bought form a jeep restoration place. It is the correct color for 1944-57 vehicles.
    I plan on ATTEMPTING to make a br*** tag that mounts above the rearview mirror similar to the tag that was put on marmon-herrington conversions. And a tag showing the shift pattern of the T-case.
    I read an article on here how to do it but I have't ordered the materials yet.
  26. jerseyboy
    jerseyboy
    Your truck turned out real nice! I like the black and OD. Despite the cobbling of "junk" parts, it sure looks stock. Also like the spare and jerry can in back.:cool:
  27. murfman
    murfman
    Chrysler Town and Country seat? Looks like the one I put in my Willys..
    Nice looking truck, I like the fact the the engine is super detailed, looks like it grew there. The whole truck has a nice "authentic" look to it
  28. Nice rig...ought to come in handy back there...nice color choices
  29. blackmopar
    blackmopar
    from fallbrook
    yea, pretty damn sweet
  30. fordf1trucknut
    fordf1trucknut
    I new update on the truck.
    I now have over 14,000 miles on it and it has been VERY reliable!!!!!
    Since We had a baby I realized the bias ply tires were a tad to bouncy so I took them off and put some radials on untill the baby gets a little older.
    My band has been playing out a lot more and I got tired of always renting a trailer when it rains of hauling with my 79 f-350 4x4 which gets 10MPG.......SO i decided to build a easily removed and ***embled canopy that matches the military theme of the truck.
    Here is what it looks like with just the hoops....I made it so I can tear down or put up the hoops down in under a minute.
    Here is a pic of me originally test fitting the canvas with the hoops 9 inches higher...... I am still working on a simple reliable method of attachment since the test run with the rope thought the grommets resulted in tearing out the grommets. That is why I lowered the hoops 9 inches....less wind and I can now double up the material at the attaching point.
    I wouldn't have needed to hunch over as much to load out equipment BUT it looked kinda goofy and the grommets tore once I got over 40 MPH on a test run.
    In addition I found some even older looking locking hubs that matched the truck better and made a minor adjustment to the ride height in the front. ( I raised the front a 1/2" so that I could add more caster.....I was limited by the tie rod hitting the springs and I didn't have quite enough caster when I first built it. It auto-centers much better now and the deathwobble that it initially had has just about gone away.
    I also upgraded the truck by adding on board air... so I can run air tools anywhere and can air down and re-inflate my tires when I offroad......It was pretty cheap and easy to do.
    Here are some other random pics from the last few months....
    6DODGE6RAM6 likes this.
