My machinist needs your help!!
Discussion in 'The Hokey Ass Message Board' started by unkledaddy, Sep 30, 2009.
  1. hotrod1933
    hotrod1933
    I have to go with (eddied) your over thinking this. Tape it off, chop it then polish it square. It,s stainless.
  2. hotcoupe
    hotcoupe
    two pages of responses on how to hold a work piece! yipes! i`m not a machinist- but i could figure that one out.
  3. unkledaddy
    unkledaddy
    Well, let's hear it!
  4. HOT ROD BILL
    HOT ROD BILL
    Cut it very slow with a hand held pipe cutter, (Large tubing cutter) while holding the other end with a punch in the joint.
  5. super plus
    super plus
    Holy ! just do it
  6. bobss396
    bobss396
    I know more than a few machine shop owners that I'd hardly call machinists, although they are at their machines every day, lol.
    Like anything else, some guys are artists, others blunder and hack their way through every job they do.
    Bob
  7. Zookeeper
    Zookeeper
    Beat me to it. I do this all the time and not only will it not slip, but it's won't mark, either.
  8. are you going to have enough threads left inside the tube after shortening it , or will you have to tap it deeper?
  9. dumprat
    dumprat
    from b.c.
    Use br*** shim stock or lead sheet. Lead works best it is very soft and will not mar the finish. We use it when clamping rifle barrels in a fixture to unscrew them,it won't scratch the blueing.
  10. unkledaddy
    unkledaddy
    Haven't measured them all yet, but if I need to go deeper should probably do it before shortening?
  11. Hank37
    Hank37
    I was taught to use a collet for this type of machining.
  12. You'll be ok re-tapping for more depth after the cut.
    Depending on tap design - body diameter same or more as the threading section - you may not be able to go deeper until after the cut.
    Since you're only cutting a 1/4" off, the threads may be deep enough as is.
    Measure thread length on bushing male end and compare to thread depth on the four bar's proper.
    Why are you shortening the 4-bars?
  13. Unkl Ian
    Unkl Ian
    If this is a major crisis, maybe you need a different machinist.
