My model a project!!
Discussion in 'The Hokey Ass Message Board' started by HOTRODDORK, Feb 26, 2009.
  1. Beef Stew
    Beef Stew
    from So Cal
    thanks for the pics of the flattening job on the frame.
  2. HotRodDrummer
    HotRodDrummer
    Rick, We sell rail's that are modified for A's and perimeter frame's ...
    ...Kevin...Rock on!
  3. moon man
    moon man
    nice score, keep up the good work
  4. HOTRODDORK
    HOTRODDORK
    from Michigan
    Thanks alot !
    You are welcome, I hope it helps.
    Thanks Matt ! I'm sure I'll see you in Detroit:D
  5. HOTRODDORK
    HOTRODDORK
    from Michigan
    I forgot to add I've made good progress on the ladder-bar crossmember in the last few days I should have some update pics 2morrow night.
  6. HOTRODDORK
    HOTRODDORK
    from Michigan
    Well I finally stopped working i he garage long enoughto post a few pics. I got the ladder bar crossmember all measured out where it needed to go and went from there.
    It ended up needing to be right where a lightning hole was in the boxing plates so I had to fill one on each side.
    I made some pltes to box the x member on the inside where the tube goes through, and finished the radiuses on the ends with some 1/2 inch strips welded in and ground.
  7. HOTRODDORK
    HOTRODDORK
    from Michigan
    here it is all welded up and finished(at least on the top side)
    Then I got the rearend ready to install.
    I dressed up the brackets a little by softening the edges.
  8. HOTRODDORK
    HOTRODDORK
    from Michigan
    I then set up the housing and centered it and set the pinion angle and tacked everything in place.
    today I finished welding all the brackets on the housing and added gussetts with a few lighting holes.
    Thats all for now I,ll be at the Detroit Autorama tomorrow , say hi if you see the Hotrod****.:D
  9. Roothawg
    Roothawg
    Nice craftsmanship.
  10. HOTRODDORK
    HOTRODDORK
    from Michigan
    Thanks Roothawg I appreciate it!
  11. HOTRODDORK
    HOTRODDORK
    from Michigan
    I finished welding the underside of the x member and decided to notch the front rails for spring clearance last night.
  12. model-a-fan
    model-a-fan
    from Kentucky
    How are you going to mount the spring?
  13. HOTRODDORK
    HOTRODDORK
    from Michigan
    I'm going to mount the spring off of the radius rods.
  14. scootermcrad
    scootermcrad
  15. Tindall
    Tindall
  16. HOTRODDORK
    HOTRODDORK
    from Michigan
    Thanks guys! I just got my BMW steering box that I got off e-bay for 22.50:D rhe other day. Plans are for cowl steering,I'm just starting to mock up the front suspension to get it all figured out.
  17. scootermcrad
    scootermcrad
    WOW! Nice score! Keep us posted on what you set up. If it's anything like the rest of the work you're doing so far, I'm sure we'll be proud. :cool:
    Keep up the good work!
  18. HOT ROD DAVE
    HOT ROD DAVE
    dude this is a awsome build, keep us posted
    i miss my 29, thanks for sharing though
  19. HOTRODDORK
    HOTRODDORK
    from Michigan
    thanks alot guys! I'm having alot of fun building this,I cant wait til its a roller and I can put the body on the frame for the first time.
  20. greasy50chevy
    greasy50chevy
  21. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    Nice job it's gonna look great.
  22. HOTRODDORK
    HOTRODDORK
    from Michigan
    Thanks!
  23. Malcolm
    Malcolm
    from Nebraska
    Very nice work! I'll be keeping track of this one. :cool:
    Malcolm
  24. HotRodDrummer
    HotRodDrummer
    Dude, you ****!!:rolleyes: I thought Kevin and I did good at just under 100!
    Everything is looking real nice!
  25. HOTRODDORK
    HOTRODDORK
    from Michigan
    HA I went on egay just after talking to you guys and sniped one:D Thanks dude ,anymore pics of your build?
  26. HOTRODDORK
    HOTRODDORK
    from Michigan
    I found some more pics of some sheetmetal repair I did on the lower door posts(b pillar) they were rusted out. Also the doors had some rust through on the bottom corners and the inner frame work that neede repairing.
    The drivers door top was wrapped around the hinge at one time and the top of the door was pretty messed up . I got to looking at an extra p***enger door I had cut up for the lower patches and realized the doors are mirror images side to side . All I needed to do was cut it off and fill the hinge slot and cut it in the other side.Henry was a pretty smart guy having parts that would work side to side with little changes 9at least on the 28/9
    had to patch the lower cowl a little too
  27. studeboy
    studeboy
    Nice work Kevin (now that I can finally SEE IT :) ) Is this your first time doing tig? I need to see this thing in person SOON!!!
  28. HOTRODDORK
    HOTRODDORK
    from Michigan
    Thanks Eric ! Yeah I pretty much just started tig welding last summer.You cut that roof of your 50 ford yet?
  29. studeboy
    studeboy
    No not yet. I still don't have power in the barn. The barn is my top priority while I'm laid off.
    I have some of the sheetmetal for the truck and will probably order the rest soon. I can work on it til I figure out the car stuff.
    I may have found a roof for the car. I'm keepin my fingers crossed the guy doesn't want a fortune for it. I can also start to setup the ch***is on the car before body work.
    It's kinda cool to have 2 projects so I can go back and forth as I have parts. I just wish I had twice the space.
    Eric
  30. ed_v
    ed_v
    from Kentucky
    Great job. Thanks for all the pics. It is really fun to see. Do you have a flathead for it ?
    Ed
