My Model A Project
Discussion in 'The Hokey Ass Message Board' started by mediumriser, Jan 31, 2010.
  1. old bone
    old bone
    from maine
    i agree...do they bind up?..its my understanding a bit more angle will ride better..where did you get your windshield posts and windshield frame..im pricing em out and it's killing me....yup i dig it..nice work..
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  2. mediumriser
    mediumriser
    from Ohio
    The mounts are not done I am putting some gussets in there for added strength. The shocks were an after thought after I did the steering and if I switch them around the upper steering arm hits the shock. I thought the more vertical they were the more shock travel you would have= smoother the ride?
  3. mediumriser
    mediumriser
    from Ohio
    I bought all the windshield stuff from Sacramento Vintage Ford. The stuff is expensive but I needed it. The frame is an original in very rough shape, I am just going to buy a chrome one when the time comes.
  4. mx6262
    mx6262
    Is that a 7k build from start to finish? I dont mean to get in your bussniss there but I would love to have a roadster and a gl*** one is the only way I can see a way to one down the road, great looking car good luck on the build.....Father Son is always cool dont care what it is...:cool: As long as it ant trouble!!:)
  5. mediumriser
    mediumriser
    from Ohio
    Yeah I traded around alot of parts and making the frame myself save alot of money.
    When its all said and done to the point I want it, it will probably be in the $8000 range.
  6. mediumriser,
    Great project there - and ya get to work with your dad! I wish my dad was here to ride in my roadster this spring when we finally get it on the road. I know he would have liked it. I used a gl*** body too and installed a metal firewall band and I'm very pleased with it. I'd do it all again!
    I'm thinking all the praise goes to all those folks who build those gl*** bodies! Cost is, for most people, a consideration. Pro or con, those new bodies are helping to keep the hot rod thing alive for the next generations...
  7. mediumriser
    mediumriser
    from Ohio
    Agreed and sorry to here about your Dad.
  8. mediumriser
    mediumriser
    from Ohio
    Well the pitman arm thing was bugging me so I have been searching and so far I have come to the conclusion that its a 53-56 F100 arm.
  9. jamesgs4
    jamesgs4
    from denver
    Cool car, I have model a roadster dreams, maybe someday. My brother in law cant drive a stick either lol.
  10. Hackerbilt
    Hackerbilt
    Do yourself and others on the road a favor and get a Pitman arm MEANT for that box. The shaft is tapered and configured for full spline engagement as the nut is tightened.
    I BELIEVE just about any pitman arm from an early Ford car or truck will work...but the F100 is a different animal entirely.
    Guys...lets help him out here...just what Pitman arms will have the right spline configuration for the F1 box????
  11. mediumriser
    mediumriser
    from Ohio
    Thanx for the info.
  12. mediumriser
    mediumriser
    from Ohio
    Been getting really cold weather and snow storms so Slow Progress. Body work is getting pretty close, but a change of plans car is now going to be Summit Paint Hot Rod black. Body wasn't as straight as we thought. O'well I think it will still look good. I'll try to have pics up tomorrow.
  13. Hotrodbuilderny
    Hotrodbuilderny
    Nice start good luck with it
  14. tbcworks.com
    tbcworks.com
  15. brady1929
    brady1929
    great roadster
  16. 29Coupe
    29Coupe
    Great project! Keep posting updated pictures.
    -Jeremy
  17. mediumriser
    mediumriser
    from Ohio
    Just bought the correct pitman arm from chaddilac on here, great dude and good price.
    Maybe I will get my steering shaft exactly parallel with my wishbone so I don't have any bumpsteer. Will have pics tomorrow. The Boy comes first. hahahah
  18. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Your model A looks great ,You might want to trim off 2 and a half inches off the side of your shell.Thats the best height ....
  19. HotRod33
    HotRod33
    I think both of the cars will be great...... Enjoy the time you spend with your dad in the garage..... I wish my Dad was still around to work with again..............
  20. Hackerbilt
    Hackerbilt
    Great on the pitman arm!
    You might not be as far off on the steering (regarding bumpsteer) as you think.
    Parallel 4 links require the draglink to be perfectly parallel...but a wishbone is a different animal.
    Heres a diagram, originally posted by RELIC STEW on a different thread, that shows your likely very close as you are! :D
    Check it to make sure of course...
  21. mediumriser
    mediumriser
    from Ohio
    Thanx for the Pic. Yeah about the shell the one in the pics is a original and I don't want to cut it so I have a gl*** one I am going to cut.
  22. baspinall
    baspinall
    from SE PA
    Just curious. Doesn't a 57 283 lack side motor mounts. Thought they only had mounts up front which means you would need a saddle mount or similar.
  23. fiftyv8
    fiftyv8
    from CO & WA
    Yes your lower shock mounts need to be switched left with right and right with left, it will help lots.
    Also make sure your steering push rod is close to parallel with the ground when the engine is sitting in it.
    If not you my find it maybe a problem.
  24. mediumriser
    mediumriser
    from Ohio
    The engine #'s came out to be a 57? And it had side mount bosses. I over looked some things with the shocks and steering, so they are gonna have to stay the way they are.
  25. mediumriser
    mediumriser
    from Ohio
    Body work is about 90% Blew the ch***is apart for paint and ***embly. Now the ball is rolling down hill.
  26. baspinall
    baspinall
    from SE PA
    I have a ? about your F1 box. Did you graft a model A flange on it to mount to your frame?
  27. crminal
    crminal
    Thnaks for sharing. Inspiring. Keep posting your progress!
  28. ratfink56
    ratfink56
    any progress?
  29. mediumriser
    mediumriser
    from Ohio
    Yep frame is all painted. Put the front end on for good. Have to fab up some shock headlight mounts. Rear end will all be installed this week and I hope to have it all an the ground and rolling on Friday. I will get up some pics this week. Also my friend is now going to mix up a batch of paint out of all the left over silver and grays he has, so the car is gonna be some shade of medium silverish gray. Trying to have it driving for Wades cruise the 2nd or 3rd Saturday in April.
  30. mediumriser
    mediumriser
    from Ohio
