Projects My Model A Truck will soon Scream under new Power
Discussion in 'The Hokey Ass Message Board' started by Littleman, Oct 15, 2007.
  1. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Just back from The DragStrip tonight....I did alot of carb work and jet changing to race at the Norwalk Goodguys event and was not able to go and try out the changes on a fully prepped track...and was upset I could not make it...no big deal because the Thompson G***er deal was a few weeks away....well that was a total wash out......So I heard that they were going to run the UMTR cars at Thompson today and knew they would really prep the track well for them for they are a group of wicked 4 speed cars and a large in #'s group which was great to see.......They also were going to allow test and tune for others....before my changes the Truck seemed to be stuck running in the 11.40's for the most part w/ a best run of 11.33 to this date..............first p*** tonight was an 11.07 then a 11.08,11.10, a 11.06 and as the sun went down so did the temp...last p*** was a 11.03......so the carb work and choices made and the new fabbed up headers really helped out, I am super happy with its performance tonight.....and the big gains found.........six two's rule.......Littleman
  2. tmacracin
    tmacracin
    What MPH you running?
  3. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Its rolling on average 119.50 mph..........Littleman
  4. tmacracin
    tmacracin
    Nice work! What is your max RPM through the traps?
  5. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Its going thru the traps @ 6,300 rpms, the cam stops making power at 6,200 rpms.......its not a full on drag cam, I still drive it on the street, all thou I have been told to take it home the last few times by the local authority..........It needs a cam shaft change, a real drag race stick........still lots of room to improve.....Littleman
  6. tmacracin
    tmacracin
    You have it running good! What are your cam specs now?
  7. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Its a hydraulic roller .533 int./ .519 exh. lift.........243/ 257 duration @.050........and a 1.6 ratio rocker on top of that...........when I change cams I am planning on going with a solid .610 lift w/ 270 dur. @ .050..............Littleman
  8. tmacracin
    tmacracin
    I ran 406ci SBC with a solid with similar specs on the street and it hauled ***! I will dig up the specs for you
  9. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Wingnuts, I improved my 60' times from 1.60's-1.65's, to 1.57's all day yesterday....my changes improved its track performance from start to finish....I leave the line with a slight brake torque and mash the gas.......Thanks, Littleman
  10. wvenfield
    wvenfield
    I don't suppose you considered blipping the gas a bit and saying "what, I can't hear you"? :D
  11. swade41
    swade41
    from Buffalo,NY
    you keep fine tuneing that thing like a mad scientist, your mad I tell ya mad
  12. skwurl
    skwurl
    Man thats haulin. any news on DEATHS DOORSTEP? That is the baddest Model A on the planet!
  13. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    If you do not squeeze them for all they have to offer........then it may be a streetrod....tweekin for performance makes a HotRod a HotRod.............but may drive you mad in the process!!!!!!.............he he he....or atleast thats how I look at it...........Littleman
  14. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I am actually thinking about working on it again........Thanks, Littleman
  15. AHotRod
    AHotRod
    Way to GO Dave, you'll have a 10. E.T. slip in the next week or so.
  16. Tindall
    Tindall
    are you gonna go to the jalopy showdown drags?
  17. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    As of this moment....yes...along w/ the Rebel Reaper.........Littleman
  18. Tindall
    Tindall
    Nice i look forward to seeing you run.
  19. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    No...It just goes........if I had a transbrake I am sure it would be more exciting at launch, DeathsDoorStep has the transbrake......Littleman
  20. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    This weekend was a total Blast, Thanks To The Jalopy Showdown Drags in BeaverSprings Pa. on Saturday and the Thompson G***er meet today, Sunday........I was having Transmission problems at The Showdown but still ran strong.......So we woke up this morning and beat feet the 5 1/2 hours back home to Thompson DragStrip where they were having the makeup G***er meet due to rain out...Figured this weekend was the last race weekend for the season....so I was planning on finishing off the ailing ****** at Thompson....We could only run 1/8 mile at the showdown and today was 1/4 mile at Thompson...and instead of the trans breaking...The Truck clicked off its fastest 1/4 mile times to date,10.89 @ 120.35.....I made five p***es total ..all in the high tens.......I could not be any happier its a great way to end the year....if you tune ..it will scoot!!!........Littleman
  21. 39 sledge
    39 sledge
    from p.a.
    Killer truck littleman i like it sounded angry as hell when it came out of the gate.....
  22. tmacracin
    tmacracin
  23. ENFO
    ENFO
    from Tucson AZ
    Hey Littleman, love the TRUCK. If its going faster in the cold then its probably a little on the fat side..... next time you run in warm weather jet it down and youll get back the cold weather E.T.s. Also Collectors on the headers will make the motor pull harder through the carbs. (just some info)
    http://www.burnsstainless.com/TechArticles/Theory/theory.html
    This is a page from Burns....... Its good stuff.
    By the way, I love your headers..... Im not knocking them. Just figured your trying to go fast, and thought you could pick up a little power with a different header design.
    Again, I love your truck...... all your cars really!!! Nothing cooler than a street driven 10 second car/truck.
    EnFo
  24. TULSA
    TULSA
    from Tulsa
    Favorite truck i have seen on this site so far. Great work. I knew it looked familar. You were on HardShine right? I am sure there is some thread of that subject, I will search for.
    Just wanted to say thanks for sharing and I love your work
  25. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I do understand about the collectors and their gains......I designed the headers for slip on's......The tubes have the correct spacing and I can cut off the bell tips w/ the chop saw and slide them on to get more scavenge affect.....I have taken alot of fuel away from it this go around...and I have heavily modified the squirters....... I always jet different for the heat and cooler temps.........Thanks for the info and website.......we all should always be looking for more info...Those headers really where just an experiment and made quickly, I need to build a real set with a larger dia. next and at this rate will need a ful cage for the Truck............Littleman
  26. swade41
    swade41
    from Buffalo,NY
    Congrats on that 10 second p***, I hope you gave the dash a couple love taps for running so good.
  27. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Close....I love tapped the drivers door while driving down the return road and gave it a verble Hell Ya...............Littleman....and I pumped my fist out the open roof...
  28. ENFO
    ENFO
    from Tucson AZ
    Cool.... glad you didnt take my info the wrong way!!! Looking forward to more updates. And I will PIPE in when I think I have something worth saying.
    EnFo
  29. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I could never take that The wrong way..........People that think they know it all.....tend too...................and let me tell you I still have way much to learn and plenty of screw ups to come...Like I always say''I have no idea what I am doing, I just do it...be it right or wrong''.........Littleman...........being open to constructive criticism can potentially make you better...wearing horse blinders..not so much...............
  30. Aman
    Aman
    from Texas
    Con grads on the time Littleman!! I haven't seen this thread in a while and the things you do to that truck are awesome. Oh, loved the story about the cops at the store.:p
