*My Modified* - I've been busy
Discussion in 'The Hokey Ass Message Board' started by Anderson, Jan 19, 2008.
  1. Anderson
    Anderson
    Sorry dial up folks, this one is chock full-o-pics.
    Hammered out a recess for the distributor...shot bag then english wheel.
    Started working on the front shock mounts/headlight mounts/nerf bar...
    Finally got around to the body mounts....
    Lather, rinse, repeat.....
    They will be welded up better once I get the body back off of the frame.
    The rest is coming up in a reply....
  2. Anderson
    Anderson
    Got this clutch/brake master cylinder hanging pedal ***embly from a company called ECI. I like this piece a lot.....I didn't have any room for anything under the floor, and I didn't want a willwood setup because I don't like the cast arms or having 3 master cylinders that would be hard to get to. This one fit the space well and was made to be pretty universal. Even comes with Ford style pedal pads and bungs to weld to the arms. Also has a built in brake light switch.
    I can access the brake M/C through the cowl vent. For the clutch M/C I'll make a door in the dashboard - there will be a mirroring door on the p***enger side for a glovebox and access to wiring.
    Bent the brake arm a little to the left to clear the transmission tunnel and to give me some room for the gas pedal. I shortened both arms about 2.25".
    even more to come.....
  3. chaddilac
    chaddilac
    Very cool... man it just keeps getting better! Can I come hang out with you?
  4. Anderson
    Anderson
    Finally....started on some seats. Pretty basic....nothing like some of the much nicer versions posted here before, but this is what I came up with.
    Step one.....outline your ****.....I don't think mine is really this crooked.
    Hopefully your girlfriend's/wife's *** is smaller....or at least not bigger than yours...Transfered the pattern to some plywood and cut a couple out.
    Pattern for the seat back. I used thumb tacks to hold the posterboard in place on the seat, worked great.
    I didn't take any pictures of it because I wasn't sure how well (or if) it was going to work....but I made the sheetmetal pieces about 3/4" bigger than the pattern. I then rolled a bead 3/4" in from the edge, and later rolled that 3/4" flange around to the backside to stiffen it a bit. It kinda worked....
    Once the seat back is attached to the bottom (so it can keep it's shape) I'll roll a couple beads in it to stiffen it up some more. It's kinda starting to feel like a car now....
    Thanks for looking!!!
  5. Dirty2
    Dirty2
    S W E E T ! ! !
  6. Sam F.
    Sam F.
    **** ya dude! *****in!
  7. cracker head
    cracker head
    looks good holmes. "the chad" will be proud.
  8. PeteFromTexas
    PeteFromTexas
  9. silent rick
    silent rick
    i like this build. keep the updates coming. what year is the X member from?
  10. Rusty
    Rusty
    Good job Eric.
  11. Damn, that is a bad *** dunebuggy! Seriously, keep up the good work.
  12. Muttley
    Muttley
    Muttley likes it.
  13. Anderson
    Anderson
    Thanks a lot fellers!
  14. LabRat
    LabRat
    thanx for showin your work great pix
  15. ratster
    ratster
  16. The Shocker
    The Shocker
    Damn ,you have been busy.Looks like some high quality work ...
  17. CGkidd
    CGkidd
    As said before Damn... I like the look of it alot.
  18. pecker head
    pecker head
    Nice ! Cool pedals also !
  19. butch27
    butch27
    Damn: Great fab work!
  20. Very nice. I just read all your old posts. You're doing a hell of a job. I love the windshield.
  21. bigken
    bigken
    Damn right it's lookin' like a car. Good job, man!
  22. Bassfire
    Bassfire
    from Mart, Tx.
    Lookin good, Eric.
  23. Anderson
    Anderson
    Look again......I did.......................
    Believe it or not folks, I -do- know what I'm doing.
    The car WILL be drivable by April 3rd.
  24. Dirty2
    Dirty2
    May be sooner !!!! Keep it up .. Looks good .
  25. fab32
    fab32
    I went back and looked at your first picture and saw that you did that so i deleted my post. I've got to make sure I'm awake before I reply to these things.:mad: Sorry, your making some great progress on your car.
    Frank
  26. BigRed390
    BigRed390
    You, sir, are quite talented. Keep up the good work!
  27. Yes, you DO know what you are doing. Nice progress shots man. Those seat backs are eerily similar to the ones I did for the Touring............I found the old pattern last night cleaning!
    Keep us posted!
  28. flt-blk
    flt-blk
    from IL
    Good idea on the body mounts. :p
    I think Dreadman had a good post awhile ago on making seat bottoms. Springs and all.
    Looks like another busy weekend. If you get bored wiht the car and want to strip some wallpaper give me a call.
  29. Irish Dan
    Irish Dan
    VERY innovative Eric! you're a talented young man! Good Luck as you progress on this project.
