My modified project (with pics)
Discussion in 'The Hokey Ass Message Board' started by Empire32, Mar 18, 2006.
  1. sko_ford
    sko_ford
    too *****in
  2. ~Diablo~
    ~Diablo~
    looking good hope to see it finished soon
  3. Blitzmädl
    Blitzmädl
    Great Job!
    Thanx for the pics!
  4. that its ****** orsome- will be cool when its on the road!
    you have some erious fab skills
  5. Hellfish
    Hellfish
    looks great!!
  6. Deeviant
    Deeviant
    from Tulsa
    This is looking cool.
    Subscribing to this thread. Can't wait to see your next update.
  7. dave s
    dave s
    i've been following this one.. it looks great! i really like how you did the back of the "cab"...
  8. Empire32
    Empire32
    from FRANCE
    thanks !
    I will try to make some progress soon.
    Maybe tomorow, stay tuned !
  9. NashRodMan
    NashRodMan
    That black and white pic is good enough for a calendar!!
    Paul
  10. Empire32
    Empire32
    from FRANCE
    Some progress yesterday.
    I've rebuilt a shifter setup bracket, modified the shifter linkage, to have a centered shifter.
    And started to work on the floor structure.
  11. Chris Casny
    Chris Casny
    from Jungle
    Pretty cool brake set up
  12. Empire32
    Empire32
    from FRANCE
    Still worked today on the substructure, and seat substructure, who helps also to rigidify the body.
    Also done brackets to bolt the body on the frame.
  13. Empire32
    Empire32
    from FRANCE
    Work today on the seat substructure, the seat will be bolted on a frame who can be opened to have an acces to the under seat volume (maybe for battery and/or tools or electrical system).
    Finished also the floor structure, and ****** tunnel structure.
    Started to adapt the embossed firewall. I don't use the lower part, wo will be made from scratch. The part I used, has been reversed and fits perfectly, firewall/engine space is just perfect.
    I just bought a VW bus column and steering box on ebay, I wait on it to mock up the steering and column, and finish the firewall.
  14. Steve Grimes
    Steve Grimes
    Hello Etienne -
    I've been following the progress on you car for sometime.
    Your diligence and creativity are reflected in what I know will be a wonderfully unique car.
    Keep up the good work.
  15. Empire32
    Empire32
    from FRANCE
    Thanks Steve !
  16. Empire32
    Empire32
    from FRANCE
    Bolted he radiator today, and the shortened grille shell.
    and some mockups with hood and hood sides..
  17. 38pickup
    38pickup
    Etienne, its really coming together! Looks great!
  18. Hellfish
    Hellfish
    DAMN that looks good!!
  19. Empire32
    Empire32
    from FRANCE
  20. fur biscuit
    fur biscuit
    quel fromage!!! progress!
    (i hope you use some Citroen or Renault parts in it)
  21. 29bowtie
    29bowtie
    This project is incredible!Also the brake setup is a very ingenious solution to a space problem.:D
  22. Empire32
    Empire32
    from FRANCE
    thanks.
    Yes, the body is a 30's Citroen !
  23. Nice work! I really like the proportions.
  24. Empire32
    Empire32
    from FRANCE
    Not a lot of progress, just some steering box & column( from a early VW bus) mock up.
  25. sko_ford
    sko_ford
    i love this build
    it should join the ranks of b***,paul,& rolf in the tech-o-matic
  26. Harris
    Harris
    Looking good - this thread is great the progress you've made in such a short time is damn near inspirational.
  27. Thanks For Sending This Good Job On Your Ride Tim
  28. spooler41
    spooler41
    great thread,lots of good pix&info. I'll be using it a lot during my build.
  29. Empire32
    Empire32
    from FRANCE
    A litlle progress.
    Mocked up the cable operated clutch system, with a clutch cable from a modern european car.
    It works great, and just need now to be finished, but now, brake & clutch pedals works !
    Also work again on the substructure/floor, started to close some area with sheetmetal...
  30. Empire32
    Empire32
    from FRANCE
    A little progress yesterday.
    Started to work on the windshield, to create a roadster style one, with "swivelable" posts on my straight pillar pick up body.
    Stanchion are not bolted but welded to the body.
    I've started to cut the pillar with a hole saw, and welded a tube section to create the "stanchion".
    With some other tubes, welded together, and adding some sheetmetal, I've made the posts from scratch.
    They need now to be finished, like on the superior section, and need also to create the screw system...
    to be continued...
