My modified project (with pics)
Discussion in 'The Hokey Ass Message Board' started by Empire32, Mar 18, 2006.
  1. pan-dragger
    pan-dragger
    i think you should stick with those lecar 3 lug wheels. lookin good bro.
  2. raaf
    raaf
    great news on the engine - sounds pretty good! keep at it man, one of my favorite builds.
  3. 38pickup
    38pickup
    That's great news Etienne!
  4. Ebbsspeed
    Ebbsspeed
    Nice solution to the master cylinder location. Is the pushrod that goes into the master cylinder supported somewhere on the part of it that is outside of the master cylinder? Looks to me like you could have eliminated the heim joint that is closest to the cylinder and just used a longer straight rod from the throw on the pivot rod straight into the master cylinder. Granted it would have swung through a small arc as you push the pedal, but might remove a little play from all the linkage.
    Looking good!
  5. Empire32
    Empire32
    from FRANCE
    thanks
    Master cylinder system is not yet finished, I will upgrade it when I will finish the frame.
  6. Evel
    Evel
    Very Cool Etienne,,
    I always look foward to seeing the progress of your car,.,.,
  7. Empire32
    Empire32
    from FRANCE
    After some long weeks witohout any job on my project, I finaly spent a day at the garage, and start to work on the header of my 292 chevy 6.
    I've started with a set of ebay header flanges, some s****yard & industrials tubes and elbows...maybe $30 plus the flanges.
    Started to bolt the flanges on the engine
    tacked the first elbows
    followed the process using 90° elbows to turn around the intake
    then, I took a long 4inches or something tube, cut a long triangle on it..
    then, rolled it and start to weld the thing
    yeah !
    cut some holes
    then, again some time spent on tubes and elbows adjustements,
    and voilà ! needs now to spent some hours to finish the weldings, and maybe build a muffler inside...
    and with the carbs, air cleaners and the right valve cover...
  8. Pauly da mick
    Pauly da mick
    Great Work Etienne!!!
    Pauly...
  9. Empire32
    Empire32
    from FRANCE
    thanks Pauly !
  10. Malcolm
    Malcolm
    from Nebraska
    Great work on the header!
    I also always look forward to your updates. Cool, man.
    Malcolm
  11. I dig the header it's real unique and a great shape. I think you are going to end up with one fun ride. Keep up with the good work.
  12. sephgato
    sephgato
    from fenton
    you just solved my master cylinder quandrey! you are a genious!:D
  13. Empire32
    Empire32
    from FRANCE
    latest update, nothing really interresting, worked on the steering components, tried some steering box mock ups...
    A pic for the motivation :)
  14. Empire32
    Empire32
    from FRANCE
    some hours of welding and grinding yesterday...
  15. Etienne, very impressive build ! I'm also following your progress here. What wheelbase did you finally end up with ? Keep up the good work.
    / primerkid
  16. AstroZombie
    AstroZombie
    from Marina, CA
    i love following this build! the header looks awesome!
  17. Empire32
    Empire32
    from FRANCE
    Thanks
    Don't remember exactely, will check next time I will going to my shop. I believe it's around the same wheelbase of a Model A.
    Looks short on the rear, long on the front, because an inline 6 is long !
  18. v8minor
    v8minor
    I love this project ! great to see updates what about regulations there ,its getting harder to build a car here in the UK (sva ****) ,do you guys have the same problem
    Cookie
  19. Empire32
    Empire32
    from FRANCE
    it's even worst here !
  20. chrisp
    chrisp
    You're just sayin' that cause any modification on a vehicule is illegal in France.
    Looks great, do you have any close up pic of it mounted on the engine?
  21. Empire32
    Empire32
    from FRANCE
  22. kustombuilder
    kustombuilder
    from Novi, MI
    LOVE LOVE LOVE this build!!! nice friggin job my man. impressive and inspiring. keep at it. i can not wait to see it finished.
  23. Empire32
    Empire32
    from FRANCE
    Worked a little bit this week end.
    Nothing really impressing. worked on details like rear spring bolting system, also on rear shocks mounts.
    Also some rear light mock ups.
    I need now to buy a set of tire, to work on the right stance and check suspennsion and work on the steering.
  24. JimSibley
    JimSibley
    I like this build a lot. kinda reminds me of my old modified, only yours is gonna be cooler. Man, you are gonna have fun with it when its done.
  25. What a fantastik post, great work truly inspiring. Keep it coming :cool:
  26. mink
    mink
    from CT
    If you get a chance canyou take a close up of those engine mounts you fabbed up.
    -thanks
  27. Empire32
    Empire32
    from FRANCE
  28. grouchy
    grouchy
    Super build! thanks for showing us!!
  29. Empire32
    Empire32
    from FRANCE
    No big update, was busy these last months...
    Today, we rolled it outside the shop, for the first time, that was a good way to look around, check stance, etc.
    I'm very satisfacted with the proportion and stance (will be better as soon as the tires will be here).
    The project start his outside life as a trailer queen, to join a friend's shop, and work together with his 32 sedan project.
  30. David Chandler
    David Chandler
    I have followed this for some time, and admire your tallent. Great job! Makes me want to do more on my pile of parts.
