My modified project (with pics)
Discussion in 'The Hokey Ass Message Board' started by Empire32, Mar 18, 2006.
  1. Everytime I check out your progress I am amazed by your talent,keep em coming,good job.
  2. Empire32
    Empire32
    from FRANCE
    I havn't worked a lot these last months on the project.
    I fund some time to spent this week. Worked on the front axle: grind and adapted F1 brakes on 37/41 spindles, rebuilt the brakes with new parts, changed the wheel bearings.
    Tire are ready to be monted, 7.50x16 and 5.25x16 blackwall Firestone, so, wheels has been painted with a glossy maroon. I will post new pics as soon as the tires will be on wheels and on the car.
  3. Empire32
    Empire32
    from FRANCE
    First time rolled out yesterday !
    I'm really happy with the tire combo (5.00-5.25x16 et 7.50x16) and stance. Still need a lot of job now !!
  4. I like it. It has really come a long way. I applaud you for sticking to your plans with it. It should be a lot of fun for you. Also, that motor is going to sound WICKED!:D
  5. HotRod_Joe
    HotRod_Joe
    Wow! I just read through the whole thread. Amazing work. Thanks for sharing!
  6. Dan Hay
    Dan Hay
  7. captainjunk#2
    captainjunk#2
    pretty kick A** little ride
  8. Empire32
    Empire32
    from FRANCE
    started to work on the steering system.
    It's a WWII jeep steering column and box.
  9. Hellfish
    Hellfish
    NICE! I love this thread
  10. I really like how this is coming along. It's cool how you used unusual parts, but it doesn't look cobbled-together. I especially like the winshield frame, I'm stealling that idea. And you can't stop me, you're all the way in France!
  11. oldrodder43
    oldrodder43
    I've enjoyed this build immensely Etienne. Great work, great ideas, great inspiration, great craftsmanship, exceptional ingenuity. Sure wish I had some of those qualities! Love it. Keep at it. Perley
  12. Empire32
    Empire32
    from FRANCE
    Not a lot of progress these last weeks (months ?)...
    Here's some news: Since yesterday, the modified has a steering system.
    Home made drag link, using WWII rod ends, because I'm using a jeep steering box, and the pitman arm has a "ball" end.
    the steering sounds to have no bumpsteer (will see when it will drive !) and work well (box is NOS). Still need to finish the box brackets and column mount.
  13. Ettiene - I'm using the same brakes on my Modified. Here's what I've done with them;
  14. Empire32
    Empire32
    from FRANCE
    nice !
    Home made scoop, obviousely !
  15. Pauly da mick
    Pauly da mick
    Looks like its all coming together really well Mon Ami!! :cool:
  16. sko_ford
    sko_ford
    heya Etienne did you have to reverse that jeep box? is it from a wwii jeep?
  17. Irish Dan
    Irish Dan
    NICE project! I'd keep the top and, as has been suggested, Z the frame for the best stance. Nice choice of an engine too! Good Luck!
  18. Empire32
    Empire32
    from FRANCE
    no, the box works like this !
    it's from a WWII Wyllis jeep or later licenced european product, and it works upside down on the jeep system (see below)
  19. chaddilac
    chaddilac
    You could have easily made it right hand drive!!! nice job!
  20. captainjunk#2
    captainjunk#2
    great pictures an excellant fabrication , this is one of my favorite threads a very cool ride ,
  21. sko_ford
    sko_ford
    thanks e i forgot about the pivot steering
  22. Flynn's_57
    Flynn's_57
    from Nor*Cal
  23. Pete Fox
    Pete Fox
    from Belgium
    Hi Etienne,
    Just to say that you have a very nice project!
    Is that body from a C4 or C6 because the hood looks long wich is nice!
    Peter
  24. Empire32
    Empire32
    from FRANCE
    it's a c4.
    I'm not sure to make a hood. I have one from the c4, and it just need to be extended (around 1/2 inch) but with the carbs & exhaust, not sure if it will looks good. Will check that later...
  25. martin
    martin
    Only just found this build, and what a build, ****** brilliant mate, well done.
    will be sticking with this one till the rubbers smokin. good work.
  26. Empire32
    Empire32
    from FRANCE
  27. ****, I was hoping to see some progress.
  28. Empire32
    Empire32
    from FRANCE
    Worked a lil bit today
    Column drop is now done, using the "on the dash" location and not under, because of the big distance between dash & wheel.
    The red thing on the second pic is an aluminium cover (need to be striped and engine turned). I will put a gauge on it and some dash lights or switchs..
    Steering works well, light and easy.
  29. Empire32
    Empire32
    from FRANCE
    I wasn't very happy with my column mount, so I worked on a new one, kindly the same, but with a better lower part.
    Will be painted the same color of the body, and with a turned aluminium plate, gauge & switches...
    abd a b&w pic of the whole thing...
  30. biscuit eater
    biscuit eater
    Love your build, keep it up!
