1952-59 Ford My NEW '54 Ford - Power Steering question
Discussion in 'Off Topic Hot Rods & Customs' started by Edsel58a, Aug 20, 2024.
  1. Edsel58a
    Edsel58a
    Well in Sept of '22 I was unfortunate enough to have a head on collision with a semi but thankfully am still here. Well, I have a '54 Victoria/Skyliner project I probably will not be able to finish (physically) and it will be going up for sale. In the meantime I still wanted a '54 so when I found this locally and jumped on it.
    Well, I want to add power steering and have been told to use a '66-'68 Galaxie box. Anyone ever use this as an option? It has me baffled because of the sector shaft length. Thanks in advance.
  2. GAmes
    GAmes
  3. slider-ok
    slider-ok
    from oklahoma
    have to agree that's a nice car
  4. Edsel58a
    Edsel58a
  5. jimmy six
    jimmy six
    Don’t know about 66-68’s but it would include changing the column or cutting yours. Would a 55 bolt in. There are completes for sale on the Facebook Ford pages.
  6. Edsel58a
    Edsel58a
    Well, I an staying away from factory type with the cylinder.
    Yes, I have a 67 Thunderbird column. I am gonna check FB because that's where I heard of the Galaxie box
    jimmy six likes this.
  7. 51504bat
    51504bat
    Borgeson makes a box but it won't work with a 3 speed column ship per their web site.
    https://www.borgeson.com/P-S-Conversion-52-64-Full-Sized-Ford-Cars.html
    P/S Conversion, 52-64 Full-Sized Ford Cars
    Power steering conversion box for 1952-1964 Full-Size Ford cars. New manufactured modern power steering gearbox with a quick 14:1 ratio and firm modern feel. Steering column modifications required for installation, see product instructions for more info. Will not fit vehicles with 3-speed column shift manual transmission. All Borgeson power steering boxes are ***embled and tested in the USA from globally sourced components and have a 3 year warranty. WARRANTY
    *800115 Box will fit Mercury vehicles sharing the same platform.
    bondojunkie likes this.
  8. ffr1222k
    ffr1222k
    I have the Borgeson box on two cars and recommend it.
    There will be issues with the column shift. On my 56 that wasn't an issue because I went with a T5 swap at the same time. I used an Ididit custom column with out tilt. It worked well.
  9. jimmy six
    jimmy six
    You’re too far from this shop but ABS in Orange Ca. installed power steering in a 54 Ford with a six. They were able to keep the column shifter. It was a lot of work and took 2 months but he was really happy. I haven’t seen the gentleman in quite a while but I know he was pleased.
    Kustomline54 likes this.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. 51504bat
    51504bat
  12. abe lugo
    abe lugo
    Once again gonna remind people that if you add electric steering. If you steering box is ****, you will still have ****ty steering just easier ****ty steering. I'm talking about a wandering steering box or other funky issues
    So the course of action should be to replace all those things and then have electric steering.
    for the borgeson. I seen we post on him where someone took the time and shortened all the shifting mechanism, but it took some space up into the floorboard. But it still kept the original column shift.
    It's a matter of shortening a few few tubes, adding a D or a mount for the for the soft coupler on the end and a bearing probably also a new shifter rod
    down-the-road likes this.
