Projects My New "59" Edsel Ranger.
Discussion in 'Traditional Customs' started by chrisg_ky, Apr 27, 2016.
  1. 1-SHOT
    1-SHOT
    from Denton
    House and kids come first. If MOMMA is not happy nobody is happy. Keep up the good work. My 40 got sidetracked about 25 years because I chose to spend times with growing family and a couple of remodels. Frank
    chrisg_ky likes this.
  2. Moondog13
    Moondog13
    That wood floor is beautiful! Is it laminate?
  3. chrisg_ky
    chrisg_ky
    Thanks. No luck with the motor. I'm gonna pull it when ever I get the time. Probably throw a 302 in like squirrel suggested.
    Sent from my SM-G930V using H.A.M.B. mobile app
  4. greg
    greg
    Great find. I live in Southern Indiana and found my 59 Villager in a field. I love that air unit under the dash. Looking forward to updates.
  5. chrisg_ky
    chrisg_ky
    Been a while since I've messed with the Edsel. Today I decided to finally push it in the garage. Pulled the Dog house off and I am about to pull the engine in a day or two. That way I can work on the body and look for a good donor. I'm thinking of rebuilding the 361 later this year. Either way I have plenty of time.
    biggeorge, chryslerfan55 and bedwards like this.
  6. The 361 Edsel used the same bore/stroke as the later truck 360 and both shared bore size with the 390, so a easy upgrade is a 390 crank and rods...
  7. chrisg_ky
    chrisg_ky
    biggeorge and chryslerfan55 like this.
  8. chrisg_ky
    chrisg_ky
    So I installed a beam to pull the engine via a hoist. I must say it work pretty well. The motor is out. I did forget to drain the transmission fluid. So now I have to make a trip to the store for cat littler (a.k.a Dry sweep). Then I rolled the car back outside, so I can re-pressure wash her and vacuum again. I must of clean up a 5gallon bucket of rust off the floor. Lol I will need to fix the floor pan later but now I'm ready to move on to body work. Nothing to crazy though. I figure I could do that while find a drive train or rebuild the old one. Pretty happy to finally made progress. It was really bothering me that I haven't done any thing to it except free the back break on the p***enger side.
  9. bobss396
    bobss396
    My '59 Ford was quite the greasy mess when I got it. Probably a 3/8" thick coating on the ch***is back to the rear seat under the car. Used Krud Kutter and a power washer to get the bulk of it off.
  10. chrisg_ky
    chrisg_ky
    That's what I did. It was a real mess.
  11. bobss396
    bobss396
    I still have to dive under and s****e some more off it, at least I'll be in the shade. It comes off easy once you get something to dissolve the top coat of grime.
  12. chrisg_ky
    chrisg_ky
    Well I finally pull the heads. One cylinder looks as if a BB fell down in it. There is a decent amount of rust. The intake is ready to pull but the distributor is seized in place. So I guess my question now, is this this savagable? I tried to turn it over with the heads off and she is pretty solid still. Thinking of pulling the pan and seeing if I can get the distributor taped loose from inside. Also cracking the caps loose also. Also I found a running 332 and Tran for sell for $500, thoughts? I post a video. Seems like I hear a taping or a exhaust leak but I might be wrong. IMG_20170616_194100.jpg IMG_20170616_194100.jpg IMG_20170616_194100.jpg IMG_20170616_194044.jpg
    junkers72 likes this.
  13. bobss396
    bobss396
    Will the 332 & trans be a direct bolt-in? The engine pictured doesn't have much going for it.
  14. chrisg_ky
    chrisg_ky
  15. Lebowski
    Lebowski
    Are you sure it's not a 223 instead of a 332? My '60 Edsel had a 223 straight 6 and the '59 I had a few years ago had a 223 also....
  16. chrisg_ky
    chrisg_ky
    My bad it's a 223. Lol
  17. bobss396
    bobss396
    Plug and play and $500 is not that bad for something actually running good.
    chrisg_ky and Bruce Fischer like this.
  18. chrisg_ky
    chrisg_ky
    Selling the 59 corsair Parts car 800 o.b.o in the cl***ifieds. No motor, trans or vin plate. never had them since I got the cars. It Does have the a hood but I'm switching it for the one on my ranger. Has cracks across the hinges. 8597073819. will need a 8ft wide trailer or a dolly.
  19. chrisg_ky
    chrisg_ky
    Well I p***ed on the motor above because it sounds to me to have a rod knock. But that could just be me. Last time I was on hear I read something about brake fluid being a pretty good agent to help free things up. So I pour a little in each cylinder. It been about a week
  20. chrisg_ky
    chrisg_ky
  21. chrisg_ky
    chrisg_ky
    [QUOTE="chrisg_ky, post: 12109451, member: see any difference????....
  22. manyolcars
    manyolcars
    On my 59 Ford, I had to break the pistons out. The car had 52000 miles so I didnt bore it or turn the crank, just overhauled the motor with new standard pistons. Its been running well for 18 years now
  23. chrisg_ky
    chrisg_ky
    It freed up. It will spin over by hand easily now. The pictures show the pistons in different positions in the cylinders. Excited about that. Now I just have to tear it down the rest of the way. Which should be alot easier now. I'm going to take it to a machine shop to check for cracks and get it cleaned up. Im planning on a very simple rebuild. What so I have done and what should I be looking to spend? I just don't want to spend money where it's not really needed. Would be best to go back stock or bump it a bit with 390 parts? If I can?
  24. chrisg_ky
    chrisg_ky
    It would be awesome if I could do that as well.
  25. mysticalstorm
    mysticalstorm
    if you havent already could you post a pic of your data plate for the edsel preservation society
  26. greg
    greg
    Check out "my 59 Edsel wagon build", here on the hamb. I have several pictures of my rebuild.
    Sent from my SM-G925V using The H.A.M.B. mobile app
  27. chrisg_ky
    chrisg_ky
    Found a engine stand yesterday at the pawn shop for 20 bucks marked down from 45. It was old and ugly but worked great. Glad to get it on a stand. Pulled the pan and timing chain cover. The rods are already labeled.
  28. bobss396
    bobss396
    You'd probably be fine with a standard rebuild. I'm sure it would be plenty strong all freshened up.
