Projects My New Firestone brown walls
Discussion in 'The Hokey Ass Message Board' started by lodaddyo, May 21, 2017.
  1. lodaddyo
    lodaddyo
    Just had a new set of 6.70-15 firestone whitewalls from Coker mounted yesterday. Cleaned the blue protectant off today and this is what greeted me. Yellow/ brown stains leeching thru the whitewall. I tried cleaning them with wesleys and a Brillo. No luck getting the stains off. One tire was beautiful white, 3 are stained. I'll be calling Coker tomorrow as I bought the extra tire protection. Just wondering if anyone had any insight on this problem.
  2. LBCD
    LBCD
    Sorry no insight to the browning, but just a heads up...mine hairline cracked all over the white walls after having them for around 3/4 years. I didn't look into replacing them till after 5 or so years having them on the car and Coker did replace them free of charge... just had to pay mounting and balance. Good luck and they should hook you up!
    30TudorSedan and lodaddyo like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I use greased lightning and a scrub brush,no brown staining. HRP
  4. lodaddyo
    lodaddyo
    This isn't dirt or grease. They were just unwrapped yesterday. It's something leeching thru the whitewall from their process.
  5. lodaddyo
    lodaddyo
    Talked to Coker today. Sent them pics of the tires. They shipped me 3 new tires today and emailed me 3 FedEx labels to send the other ones back.
    56shoebox, Bugsy48, BradinNC and 10 others like this.
  6. The37Kid
    The37Kid
    That is great news that needs to be posted. :)Bob
    Spoggie likes this.
  7. C69A
    C69A
    The first pair of Coker Firestone 560/15 I got had 1/4" of runout, so bad I stopped driving my coupe altogether, they Didn't want to know. After six years I thought I would get another pair as the quality must have improved Wrong!. Not only do the new ones have bad runout they also have lumps and brown stains on the whitewall.
    Would be great if they could spend some of my hard earned cash they now have on some quality control!!!
    As I am on the other side of the world you screwed me again Coker. Well Done!
    Spoggie likes this.
  8. 32ford5
    32ford5
    from Australia
    It's caused by what's called "Tire blooming" or if you live outside the U.S. "Tyre Blooming". This post explains it quite well. It's caused by the "anti-ozanants" in the rubber. Here's what the article states. It also explains how to clean near the bottom.
    ______________________________________________
    "Chances are you've encountered tire blooming and you don't even know it. Blooming is what causes a tire to look brown. That new set of tires that you have to scrub over and over again to get them to look black, or the tires on a car you detail less frequently that are closer to the color of chocolate than they are black. Modern rubber compounds are becoming increasingly complex, far more than most people realize. Tire manufactures are continually pushing the envelop with chemistry and design to create tires that can keep up with the demand of todays cars and drivers. Higher mileage, more miles per gallon, better all-weather traction, or high speed and cornering as cars get better, faster, more intense the tires they roll on must change to keep up.
    We expect increased performance from our vehicles and tires are an integral part of that, but rarely do we take the time to understand what exactly has changed about tires other than going from bias ply to radial in the late 1960's.
    What does this all have to do with your tires turning brown? Read on.
    ANTI-OZONANT
    An anti-ozonant is probably something you've never heard of. Its an organic compound added to rubber materials that prevents, or at the very least, slows the deterioration caused by exposure to the elements. Anti-ozonants are used as an additive in most all of the exterior rubber and plastic parts to one degree or another, but they are most prevalent in tire manufacturing. The anti-ozonant additive keeps plastics and rubbers from becoming dry, brittle, oxidized or cracking. It does this by preventing the surface of the material from oxidizing and keeps the material pliable.
    Thanks to anti-ozonants in rubber compounds we have have high mileage tires, performance tires, and everything in between. Without it sports cars would shred tires incredibly fast after just a few high speed turns or long track runs where the tires were heated up. Even your daily driven commuter car would need tires far more often as the sun and heat slowly rotted away the rubber compounds.
    TIRE BLOOMING
    Tire rubber compounds are designed in a wat that allows the anti-ozonant to continually work its way to the outside of the tire and as such, continually keeps the outer surface and sidewall pliable and resistant to oxidation.
    Once anti-ozonant reaches the outside of the tire and is exposed to air and moisture it oxidizes, the result being a brownish residue. The term for this ugly brownish tire look is 'tire blooming'. Just like metals left exposed to the outside world will slowly begin to rust (oxidize) as it is exposed to water and air, so does the anti-ozonant component of the tire rubber.
    Making matters worse is the use of mold releases in the manufacturing processes. These lubricant type chemicals provide a non-stick surface for the inside of a tire mold. The mold release chemical bonds with the tire and hold anti-ozonants onto the surface of the tire.
    While some people will point to mold release as the primary and/or only source of tire blooming, it is in fact often times only a part of the problem. Even after the removal of mold release a tire will continue to push anti-ozonant to the surface allowing the brown residue to return.
    THE ROLE OF COLOR CHANGING WHEEL CLEANERS
    Wheel cleaners used to dissolve metallic contamination (Deep Wheel Cleaner a**** them) can have an accelerating effect on the oxidation of anti-ozonant. The reaction you see when brake dust it turned to a reddish slurry by Deep Wheel Cleaner or a similar product is, in a very simplified way, oxidation. The chemical reacts with the metallic contamination and begins to dissolve it.
    Tires that have not been cleaned properly before or have been left uncleaned for long periods of time will have substantial amounts of the anti-ozonant built up on the surface of the tire. When an active wheel cleaner comes into contact with this buildup it will accelerate the browning or blooming. Because of this its imperative to regularly scrub tires to remove the buildup of anti-ozonant and 'dead' rubber - think of it almost like exfoliating your skin. If you are a regular user of Deep Wheel Cleaner or similar color changing wheel cleaners for their ability to remove stubborn brake dust then be sure to spend an extra couple of minutes scrubbing your tires as well.
    Does this necessarily mean you should discontinue the use of Deep Wheel Cleaner? No, but it should be used with the understanding that the tire needs deep cleaning after the wheel to remove any residues or prevent tire blooming acceleration as a result of the oxidation process. Abrading the tire sidewall to remove this will prevent the blooming in the first place - the reason your sidewalls brown, but your treads don't is that the treads are continually worn away by driving so the surface never is allowed to sit long enough to display blooming.
    DON'T BLAME THE SILICONE
    For years the prevailing thought has been that silicone based tire dressings are the culprit for brown tires. Read any number of forums and the first thing most casual detailers will point to is the choice of tire shine the person with the issue uses. While silicone can be a messy and sticky solution to making your tires shine it isn't always the main culprit of the brown issue.
    Most browning related to silicone will be due to the silicone holding dirt and debris on the tires surface, not the tire itself turning brown. This type of browning is very easy to remove as silicone dressings also remove with scrubbing and a degreaser like All Purpose Cleaner.
    Don't think this means you should immediately start to treat your tires with tons of silicone, there are still a lot of reasons it's not an ideal way to dress your tires, but don't believe the story that your choice of tire dressing is the ONLY source for the brown residue. Silicone and water based dressings can be used and the tire can still exhibit blooming... its the tires surfaces and/or lack of heavy cleaning more than it is anything you've treated it with.
    REMOVING THE BLOOMING
    Removing the blooming is really a simple process - the use of a good degreasing agent, like Adam's All Purpose Cleaner, and a stiff bristle brush should be more than enough to remove even the worst blooming within a few treatments. Be sure to rinse the tires extremely well with clean after each cleaning to remove any chemical buildup.
    Once the brown residues are removed regular cleanings with All Purpose Cleaner shouldn't need to be as aggressive or frequent, but if you notice the blooming returning just scrub well. The application of a quality water based dressing like Super VRT or a dressing low in silicone content like Adam's Tire Shine will help slow the reappearance of blooming by providing a barrier between the tire surface and the environment.
    IT WILL COME BACK, ITS JUST A QUESTION OF WHEN
    Because anti-ozonants continue to work their way towards the outside of the tire even a car which sees very little use or doesn't have very dirty tires may experience tire blooming when eventually exposed to oxidizers due to lack of cleaning. As such it is recommended that even relatively clean tires be treated to a semi-regular scrubbing to remove the anti-ozonants from the outer layer of the tire sidewalls.
    Each tire will have a different amount of blooming it is prone to. Some tires may bloom very slowly, while others will bloom almost before your very eyes. The amount of anti-ozonant and the way the tire is designed to push it to the surface will determine how fast or slow it happens. Regardless, one thing remains true - regular cleaning and dressing of your tires will prevent or at the very least minimize the appearance of brown on your tires."
    Later in further replies to the thread he mentions...
    "The anti-ozonant works it's way to the surface regardless of your frequency of cleaning, so in theory an uncleaned tire loses it at the same rate as one cleaned frequently if they're exposed to the same amount of air/water."
    Source: http://www.adamsforums.com/topic/27661-pro-tip-tire-blooming-and-why-your-tires-turn-brown/
    lodaddyo and scrap metal 48 like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I have had several sets of Coker tires and only one minor problem and they corrected it fast. HRP
  10. bondolero
    bondolero
    My new bias look www radials came with a Coker tire cleaning product and works terrific like Lesleys Bleach White on any marks you get. IMO Cokers ww are far superior to Diamondback.
  11. MikeRose
    MikeRose
    from Yuma, AZ
    I've had two sets of firestones from Coker. One whitewall and one blackwall. No problems with how they looked or performed. Glad they took care of you. ****s to have to deal with it though, I bet.
    lodaddyo likes this.
  12. lodaddyo
    lodaddyo
    My 3 new tires showed up today. Haven't had a chance to check them out yet. But I want to commend Coker on their customer service. I even got a PM from Coker's VP of sales!
    Shaun1162 likes this.
  13. RICK R 44
    RICK R 44
    Most white wall mfg'rs do not recommend using cleaners that contain bleach. I use Castrol Super
    Clean - works great.
  14. lodaddyo
    lodaddyo
    New whitewalls all mounted and no brown in sight!
    Bruce Fischer and lbcd like this.
  15. Rocky
    Rocky
    Classified Editor
    I had a set of 4 that had this browning. It was from the inside-out and it wouldn't go away, no matter what I used on them. I even painted them with the old rubberized whitewall tire paint for bias ply tires. Mine were radials and after driving 20 miles, the paint all sluffed off inside my wheelwells! The whole thing was a mess. I went back to black wall tires.
  16. iwanaflattie
    iwanaflattie
    This is why I'm afraid to spend 800 on tires.
    tfeverfred likes this.
  17. LBCD
    LBCD
    Do you have pics of the whole car? Would like to see some!
  18. lodaddyo
    lodaddyo
    It's still on my lift. Hard to get a whole shot of It. Still working on my rear panhard bar and the skirts are off. Here's a pic with the 16 " Stock wheels and bfg silvertowns. Also 16" lyon caps
  19. LBCD
    LBCD
    Looks great! I ran the same combo 670-15 with clipper covers on my 41 but down sized to 65/70 radials for a while, in the process of saving up for 640-15 BFG's
  20. lodaddyo.I am glad it worked out for you. They sure look nice.Bruce.
