My new GF!
Discussion in 'The Hokey Ass Message Board' started by solo_909, Nov 10, 2013.
  1. solo_909
    solo_909
    Just bought her today. Ran her pretty hard for an hour on the way home and she ran cool and strong.
    Quick question, it wasn't driven too much so we had to charge the battery for a little bit to get it to start. I took the battery to get it tested and it was at 93%. Do these drain if it sits for a little bit? What else might cause the lag on starting?
    Thanks,
    George
  2. tb33anda3rd
    tb33anda3rd
    how old is the battery? is it charging properly? i have found that if a battery is 4 years old or older, and has needed a charge more than once, they don't hold a charge well and will fail. check that first, then check if it is charging, then check all the battery/starter connections for corrosion and tightness.
  3. Model T1
    Model T1
    it was driven too much so we had to charge the battery for a little bit to get it to start.
    This makes no sense. The more you drive it the more it should charge. You need a new battery or you have something draining the old one. First try another battery if you can. Nice looking GF.
  4. solo_909
    solo_909
    Correction, it "wasn't" driven that much.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Take the battery to a shop or parts house that can check the battery for cold cranking amp,,,I recently had a battery that we charged to full capacity and was dead in three days.
    It would take a charge but had zero cold cranking amps with a full charge. HRP
  6. solo_909
    solo_909
    Sounds good, any car shop?
  7. tommyd
    tommyd
    from South Indy
    Starting issues aside....nice car.
  8. Weasel
    Weasel
    Any local parts store - I use Autozone for batteries as their Duralast brand came top in Consumer Reports magazine test for conventional batteries and they have test stations set up but make sure you fully charge the battery before you take it in to them....
  9. solo_909
    solo_909
    That's who I took it too and they said it was at 93% and a good battery.
  10. dinokruzordinance
    dinokruzordinance
    Any plans to change it or?
  11. 35desoto
    35desoto
    The lead plates in the battery will sulphate up in time and then they loose the ability to do their job - its already started in your battery with it being at 93%. There are some good products that will stop/slow this down however I do not know their names in the USA. A lack of use or leaving them flat will escalate the downward drop in performance. You may still have a good battery for some time to come and only time will tell how good. Its worth persevering with it.
  12. solo_909
    solo_909
    To a 12v? What are the pros of doing the change over? I thought I would just leave it.
  13. squeaky32
    squeaky32
    nice looking 53, i love the dashes in those. id try replacing the battery, my friends buick had the same problem, bought a new battery and fixed the problem, but ended up switching to 12v right after so it was kinda a waste
  14. solo_909
    solo_909
    Why do people switch over to 12v?
  15. squeaky32
    squeaky32
    easier starting, brighter lights, being able to run 12v accessories, cheaper batteries, etc
  16. luke13
    luke13
    cause 6 volt is ****, 12 volt is easy to change too and is way better, its just stronger and more reliable, i converted my 56 ford and never looked back , if your a miser you can put the battery on a desulphation charger and it will buy ya a bit more time, (thats just a long slow charge that breaks any corrostion off the battery plates so that they can p*** electrons more effectively) neat car have fun.
  17. solo_909
    solo_909
    Cool, I'll look into it. Is it pretty inexpensive?
  18. squeaky32
    squeaky32
  19. forty1fordpickup
    forty1fordpickup
    Nice ride. Check the battery out and replace it if needed. 6 volts systems are just fine. Make sure all the connections + and - are clean and tight. For brighter headlights use H6006. H6006 is a 6 volt halogen. I used a 6 to 12 volt to run a 12 volt stereo.
    This 53 has run to FL from NH and back twice. 6 volts no problem.
  20. solo_909
    solo_909
  21. luke13
    luke13
    yeah what this guy seez. i find about 80% of electrical issues are caused by bad connection because of a dodgy terminal sometimes a broken wire and least of all faulty hardware.
  22. solo_909
    solo_909
    So even thought it tested good I should swap it? I see if it has any trouble starting tomorrow and go from there. Those 6v's are like $100 so I think it would be better to just change everything over for that cost.
  23. 3spd
    3spd
    I don't want to be that guy that does nothing to help the OP BUT... What's up with the blue liquid in your driveway?
  24. luke13
    luke13
    if everything is working ok id probly hesatate to change it like 41fordpickup seez, he runs 6 just fine, i changed to 12volt cause i was doing an engine swap and rewire (thanks to rats) at the time and the newer engine came with a brand new 12volt alternator allready mounted. so it was easy to convert, new battery should see ya right. but its up to you at the end of the day, i always had no end of trouble with 6volt DC systems on motorcycles but it seems to work ok in cars. Ive also found that if you leave the leads attached to the genny you can use them to swing it over your head to throw it futher away!!
  25. solo_909
    solo_909
    Cool, id rather spend the money for blocks and Aerostar springs and get her to lay down a little bit. I'll fill you guys in within the next couple days. I appreciate the wisdom.
  26. 1971BB427
    1971BB427
    from Oregon
    More often the sulfates in batteries sluff off and build up in the bottom of the battery case. Eventually they can begin to short out cells, so a battery will take a charge, but wont hold it with this buildup discharging between cells. It also makes the battery less efficient during starting, and the only cure is to replace it. Some battery testers wont show battery condition well, while other electronic types will show these buildups when testing, even if recently charged.
    I have a Tiff-2500 battery tester, which I think is the finest battery tester ever built. Unfortunately they stopped making them, and have never come out with an updated version for whatever reason.
  27. solo_909
    solo_909
    So this morning she started right up!!
    I did find another slight issue, I think. The car kept stalling when trying to take off in first this morning. I had to step on the gas pedal all the way to keep it from stalling when letting out the clutch. Once the motor warmed up I didn't really need to push the gas pedal in all the way but still lagged it felt like. Any idea what may cause that?
  28. luke13
    luke13
    could be just cold and be a choke issue, or the carb could need quick clean, have a look at how your choke works.
  29. solo_909
    solo_909
    Sounds good, thanks!
  30. Ebbsspeed
    Ebbsspeed
    Looks like a reflection of the car in water to me.
