Projects My New New Ride
Discussion in 'The Hokey Ass Message Board' started by grdra1, Sep 24, 2022.
  1. grdra1
    grdra1
    Ive just spent 4 weeks driving around outback OZ on holidays, not much progress on hotrod but I was still able to purchase some items to keep project moving along. I now have a complete ignition system. I also purchased a steel cowl vent panel, I plan to reproduce vent in fibregl*** or attach to body as is - Im not sure witch way to go and am open to suggestions. A few pics. Glen 20250506_171130.jpg 20250506_171149.jpg 20250506_171157.jpg 20250506_171242.jpg
  2. grdra1
    grdra1
    A few pics of recent progress, at this point in time I plan to glue steel panel in place ( although making one in fibregl*** is still an option ), today I fabbed up a support frame that will hold panel in place and have provision to hinge vent. I still need to fab up handle ***embly to open / close vent. I have a plan in place and hopefully will fab handle on next day off, Glen 20250601_143134.jpg 20250601_143140.jpg 20250601_143152.jpg 20250601_144350.jpg 20250601_171412.jpg 20250601_174303.jpg 20250601_174306.jpg 20250601_174405.jpg 20250601_174439.jpg
  3. 05snopro440
    05snopro440
    Generally, fibergl*** has about 1.5 times the thermal expansion coefficient of steel. In rough numbers on a 12" section and a 16°C (30°F) temperature swing, the steel will expand by about 2.8 thousandths of an inch, while the fibergl*** would be more like 4.2 thousandths.
    Its good news this way, as your steel shouldn't push on the fibergl*** and cause body cracks, but you could get cracks over time in whatever filler and paint is over the connection between the steel and fibergl***. I'd use one of the fillers with fibergl*** strand in it to help stabilize the connection. Otherwise everything else expands and contracts with temperature changes, so you should be fine to go with the steel lid and frame.
  4. grdra1
    grdra1
    Thanks for this info, this is the reason I was planning to re produce panel in fibregl*** but have now decided to glue steel panel in, as the car will have a distressed look anyway and if it cracks in the future a repair wont be an issue. Thanks again, Glen
    05snopro440 likes this.
  5. grdra1
    grdra1
    I glued vent panel in place today, once set I will finish of with body filler and complete hinge / handle ***embly, a few pics. Glen 20250616_162758.jpg 20250616_162801.jpg 20250616_162809.jpg 20250616_162811.jpg
  6. grdra1
    grdra1
    I applied some fibregl*** reinforced filler today, still need another skim coat but happy so far, Glen 20250617_174049.jpg 20250617_174051.jpg
    duecesteve, 05snopro440 and loudbang like this.
  7. grdra1
    grdra1
    Started fabbing hinge ***embly today, only problem was there was no room for lever under dash as brake booster in the way so I decided to poke it out the dash, happy with the result. Still a lot to do - I may make a a nice surround around lever either riveted or bead rolled or both. I also have to work how to keep open and closed. Glen 20250705_131124.jpg 20250705_131135.jpg 20250705_145829.jpg 20250705_145837.jpg 20250705_145842.jpg
  8. 05snopro440
    05snopro440
    I like the dash mount. You're missing some parts that would help with keeping it open and closed. My 46 GMC has kind of a cam where you pull the lever back to lock it down, and there are detents when you open it up to hold it. Usually these pieces connect to the cowl vent where you have connected your lever. You might need to get creative with that you have there.
  9. RodStRace
    RodStRace
    I try not to be a safety freak in older cars, but I'd prefer a handle that doesn't look like a spear also.
    I don't know how much leverage is needed to operate. Could it be bent down? I see it threads in and a bend would be a bother.
    I realize the wheel isn't in place yet, but that design looks unfinished.
  10. grdra1
    grdra1
    I have seen how the original rachet system works to open and close these vents on a 34, but I don't have one on hand to play with / modify. My plan at this stage is to fab up a fancy bezel / surround with slots at the top and bottom for the lever to go sideways into the slot, and possibly hinge lever horizontally and use a spring to hold in position. Hope I have explained it ok, I also plan to shorten lever and make it all look like it belongs there. Glen
  11. grdra1
    grdra1
    You are correct, this design is totally unfinished, the finished product hopefully will look like its supposed to be there, there is very little leverage required to open and close vent so the lever will not be this long, watch this space. Glen
    RodStRace and loudbang like this.
  12. 05snopro440
    05snopro440
    I can see your idea, it's just like the mowing height adjustment on my lawnmower. Good plan, that will save a lot of space under the dash.
  13. grdra1
    grdra1
    I spent about 2 hours in shed today, this is what I came up with. I plan to make a little smaller and shape similar to center of dash and recess in by machining around the inside edges of bezel, a few pics, Glen 20250707_171343.jpg 20250707_173633.jpg 20250707_173638.jpg
    RodStRace and 05snopro440 like this.
  14. grdra1
    grdra1
    A few pics of todays progress, I now have a working vent. I'm not 100% sure if I love it but I do like it, I will wait until I have gauges, steering wheel, glove box etc. and then see how it looks. I will leave it for now and progress with other items such as fabricating headers, exhaust, windshield frame, trans tunnel, cover for rear crossmember in trunk etc. etc. etc. But my next job is to install some aluminum cylinder heads on my 31 coupe. Glen 20250709_173318.jpg 20250709_173324.jpg 20250709_173339.jpg 20250709_173347.jpg d1b48257-0ef8-49c1-bd4f-3bbfadbd9c3d.jpg d849b4bb-6934-47c7-9c90-a3dc678bc9b5.jpg
  15. grdra1
    grdra1
    I recently purchased some vintage gauges for my 34, Yesterday I started fabbing some bezels for the gauges and for a glovebox lid. I decided to follow the theme of my vent handle bezel and machined some groves into some allow sheet, I still need to sand and polish all items and I am happy with the result so far, although not 100% happy with glove box lid - I plan to reduce the overall size of the outside of the lid by 2-3mm, a few pics, Glen 20250825_141259.jpg f5c382d4-530b-4338-a1fc-332e00b5f72b.jpg 57260795-8a7c-47df-9af0-d1a2a50a4031.jpg 20250826_152824.jpg 20250826_152837.jpg 20250826_152853.jpg
  16. 34Larry
    34Larry
    Well as 34Larry would tell you, you can't do any better than that. ( Oh I did say that):rolleyes:
  17. grdra1
    grdra1
    I trimmed my glove box lid today, so glad I did as it looks so much better now. Glen 20250827_115603.jpg 20250827_115613.jpg 20250827_115713.jpg
  18. grdra1
    grdra1
    Started fabbing headers and exhaust recently, yesterday I started making a pair of mufflers, a few pics Glen 20250903_104035.jpg 20250903_123914.jpg 20250903_123929.jpg 20250904_100726.jpg 20250904_100732.jpg 20250904_100736.jpg 0ef2a22f-fca6-4512-9058-2c01802c43e3.jpg
  19. grdra1
    grdra1
    A couple more pics, I decided to make my own mufflers as this car needs to meet quite strict noise requirements for registration and running a healthy supercharged SBC this was always going to be an issue. So I decided that I would fill up as much space as I could with muffler, these mufflers are 750mm long, 175mm wide and are made using a 4 inch pipe cut in half, inlet and outlet is 3 inch ( whole system will be 3 inch and finish out the side before back wheel ). Once mufflers are done I will fab the headers, Glen muffler 1.jpg muffler.jpg
  20. grdra1
    grdra1
    Finished mufflers today, happy with how they have turned out, now to work out how to mount them and start fabricating the headers, a few pics, Glen 20250905_163955.jpg 20250905_164004.jpg 20250905_164011.jpg 20250905_165611.jpg 20250905_165621.jpg 20250905_165629.jpg 22b61691-1494-4b24-8725-5cd132a17720.jpg 20250831_171306.jpg e1f81981-039b-40b4-8931-119732882fb2.jpg
  21. AmishMike
    AmishMike
    First mufflers seen built on HAMB - amazing. Had thought about something similar as gather parts for modified. Love your build & all the detail
    RodStRace likes this.
  22. flyn schlosser
    flyn schlosser
    from Elko,NV
    Awesome build. Enjoyed going thru it .can't wait to see progress..
  23. grdra1
    grdra1
    Thanks for nice comments guys, a few pics of recent progress, started fabbing headers, Glen 71c79b00-ea06-40a7-b801-58025dff2ccf.jpg 237c6878-4831-4a59-a83d-19bd1b0a9f5a.jpg 0f5bc86d-b3b0-4e9d-81e8-cf78edb0951a.jpg d3af774f-beb0-497e-a471-41eb37be1c0d.jpg 20250907_153119.jpg 20250907_153112.jpg 20250907_153108.jpg 20250907_153010.jpg 20250907_153005.jpg 20250907_152959.jpg 20250907_152952.jpg 20250907_121011.jpg 20250907_121007.jpg
    catdad49, lurker mick and loudbang like this.
  24. grdra1
    grdra1
  25. grdra1
    grdra1
    Headers are nearly done, Im very happy with how they have turned out. All I need to do is mount mufflers so that the collector has a straight run to the mufflers, I plan to bolt headers directly to the mufflers and fab muffler mounts to suit, then fab rear pipes to end before back wheel. I can access all spark plugs except no 8 and needed to fab a plug spanner to suit, a few pics. Glen 20250917_160237.jpg 20250917_160246.jpg 20250917_171752.jpg 20250917_173948.jpg 20250917_173958.jpg 20250917_174824.jpg 20250917_181425.jpg 20250917_181439.jpg 20250917_181452.jpg
  26. RodStRace
    RodStRace
    Beautiful work!
    Really like the cone at the collector.
    I was picturing the wrench before I scrolled down and saw the pictures.
    You are going to have a special plug wire for that one!
  27. grdra1
    grdra1
    Thanks for nice comment, I don't think the plug lead will be a problem there should be enough room just looking at it ( I do have the leads - I will check today ). Glen
  28. grdra1
    grdra1
    A few pics of todays progress, I still need to fab mounts and finish weld but overall happy so far. I would like the pipe to be less noticeable and dump under car pointing slightly to the side, but in order to keep engineer happy I will leave as is for now, being a 3 inch diameter pipe it still looks the business. Glen 20250918_165543.jpg 20250918_165601.jpg 20250918_165614.jpg 20250918_165916.jpg 20250918_165854.jpg 20250918_165901.jpg 20250918_165932.jpg 20250918_165937.jpg
  29. grdra1
    grdra1
    20250919_182542.jpg b901d872-40e6-47c0-9ac4-0b1cda8b8931.jpg ba9396ec-d2db-414d-a730-673caabe2466.jpg c3a43c72-ef05-4f31-8bef-9d15d9cc6d24.jpg f851750d-5702-4a3c-b89b-438e2e07c9eb.jpg Finish welding exhaust today, all I have to do is fab exhaust mounts to finish, then I start on fuel tank fab out of this sheet of 1.6mm steel. Glen 20250919_182542.jpg b901d872-40e6-47c0-9ac4-0b1cda8b8931.jpg ba9396ec-d2db-414d-a730-673caabe2466.jpg c3a43c72-ef05-4f31-8bef-9d15d9cc6d24.jpg f851750d-5702-4a3c-b89b-438e2e07c9eb.jpg
  30. grdra1
    grdra1
    Fabbed up rear exhaust mounts today, all I have to do is finish a few little welds and paint complete system, overall very happy with the finished product, I'm really digging how the side pipe is looking. Glen 20250922_181034.jpg 20250922_181039.jpg 20250922_181050.jpg 20250922_181044.jpg
