Projects My new project: 1932? Chrysler 3w Coupe
Discussion in 'The Hokey Ass Message Board' started by rschilp, Jun 21, 2011.
  1. clubcoupe37
    clubcoupe37
    that was an awesome pic of your daughter helping you..love these chrysler coupes
  2. Ned Ludd
    Ned Ludd
    Have you considered flipping the blower the other way up? That'd lower it by the rotor spacing. Are you planning to run a spreader bar? It'd be cool if it didn't quite clear the blower and therefore needed a clever and elegant detail at the front end of the blower.
  3. Going strong Rob, the blower is *****in.:)
    Building this in Holland would be muchhhhhh more difficult, try to find an engine like this and i'm sure they are out here too but probably not for sale.:(
    Groeten Hennie
  4. rschilp
    rschilp
    If I lower the engine about 2" the blower will be just above the front bumper mounts on the frame.. thinking that would be a possible mount point for the blower.. kind of like a spreader bar/mount maybe?
    Even in the US it's really hard to find parts for a 1932 Chrysler 3w and harder for the V12's.
    My advantage is that I have a very extensive parts collection, so I can mix and match and find the pieces I need. Having a 10,000 sqft shop with a full fabrication setup helps a bit to.
  5. rschilp
    rschilp
    Making progress.
    Got the hood sides cut off and got some parts in for the lake headers.
    Made a BIG decision today. I'm going to get the car running without the blower first. I want to drive this thing and I'm thinking the blower is adding too much complexity that I don't need right now. Already thinking about how to use the two air cleaners without the blower. The blower will remain with the project and the drive has been build, so I can always add it later.
    The hood mocked up with the lake header in for one side. I'm planning to run these with baffles for now, see how loud it is, if too loud I'll add an undercar exhaust.
  6. farmer12
    farmer12
    Those lake headers are going to look great! Man, you have one great project in your hands. AWESOME.
  7. honeyman
    honeyman
    from Steiner
    Love the build, but just can't get past the blower stickin' way out front. The only way I could see doing it that way would be to lengthen the frame and fenders enough to cover the blower. It just totally ruins the lines of the car for ME... sticking out past the radiator and fenders...but thats just an opinion. Like the idea of getting it running without and working it in later.
  8. rschilp
    rschilp
    The blower won't stick out, it sits between the fenders and behind and slightly above the bumper.
  9. You might be able to beef up the shock mounts and run old school air shocks on the front with just enough pressure to raise the nose a little. You could adjust the stance a hair as well.
    Love this project...
  10. plym_46
    plym_46
    from central NY
    I guess Honeyman never saw the Blower Bently treatment. I think it will look very cool.
    Might I suggest a Deusenberg style exhaust ?
  11. rschilp
    rschilp
    Slowly making some more progress.
    Did some work on the headers and baffles, test fitting the grille shell, headlights, air filter housings and intake tubing.. final result: the engine needs to go back and down to make it all fit right. That means the water pump and/or steering column will need to get m***aged a little bit, just some more work.
    While I was working on my project my oldest son was working on his first car, slightly off topic, but still any car guys dream.. working together with your son.
    I've got all of next week off, but have some other things to do, getting the Early Ford V8 club to visit the shop in a few weeks and I've decided to make a nice display of some flatheads 21 stud, 24 stud, 59A, 8BA, Zephyr v12, Seagrave v12 and a Cadillac 346 v8.. almost all of those will have to be pulled from storage and put on a stand.I see some welding in my future, great work at 110F :mad:
  12. ezdusit
    ezdusit
    This has become a thread I don't want to miss. I love what you're doing with this early Mopar. Very creative. Thanks for sharing your progress.
  13. rschilp
    rschilp
    Had a customer make me a very cool CNC present.
    Company logo and a 1932 Chrysler 3 window coupe, see the size of this thing compared to a standard sized business card!
    Thanks Brian!
  14. honeyman
    honeyman
    from Steiner
    Don't think THATS gonna fit in your wallet!!! Very nice...
  15. billylo
    billylo
    To big for a key chain too.......:D
  16. rschilp
    rschilp
    Slowly working on the car.
    Finally have the engine in the right place, the rear motor mounts are in, the hood sides are cut, the first intake tube is welded and on the block, exhaust tube is mocked up.
    Going to have some work making a new K-member, the current one is too far forward to fit the new transmission.
  17. rschilp
    rschilp
    Progress has been very slow last few weeks. Too busy at my day job and too many customer projects needing my attention.
    Spend some time on the exhaust today, first runner is in and the intake and exhaust seem to fit together well.
  18. edinmass1602
    edinmass1602
    Hi, enjoy watching your build. I have been running the Pierce V-12 engines for over 20 years. I can give you lots of insight on the motor, parts new and used, and common problems with them. Most of the time the cam in the engine is junk due to the dual distributor drive, and cams are very difficult to find. Dee Howard ran a Seagrave coupe at Bonniville in the 90's and ran too much boost, pushed the crank out the bottom of the block. I have never seen anything like it before. His guys that built it are from Texas and may still be around. They made new heads from scratch, and also had head gasket failure problems. I think the car ran over 200 mph, but I can't remember. AJ Foyt was the driver. If you need anything just drop me a note at my email address as I don't check the HAMB but once every 3 months or so. GOOD LUCK! Ed. edinm***@aol.com
  19. rschilp
    rschilp
    Some updates, a few of you saw the car yesterday at the Texas Thaw.
    New front cross member is in, grille shell is updated, rear axle installed, blower and one of the headers mocked up.
    If anyone took any pictures at the thaw, please add them to the thread, I forgot my camera
  20. The37Kid
    The37Kid
    Just got up to speed on this project, I like it. That 6-71 looks a bit large. Study this Blown STUTZ info from HAMB member alsancle's site. I'll look around for a photo of the car, I've seen it and the restoration is very nice. Bob http://home.townisp.com/~alsancle/StutzSuperCharger.html
  21. rschilp
    rschilp
    The supercharger looks big because it's a 6-92.
    Interesting link, I'll have to study that more.
  22. Dominick Hide
    Dominick Hide
  23. Locomotive Breath
    Locomotive Breath
    from Texas
    Looking good Rob, that thing is going to be a beast. :D
  24. That's some incredible build you've got going on.
  25. GaryB
    GaryB
    from Reno,nv
    thats one big hot rod
  26. linkstar69
    linkstar69
    Great project, real different.
  27. farmergal
    farmergal
    from somewhere
    very cool. nice to see it revived!
  28. He Rob
    Any news on your car ?
    Groeten Hennie
  29. Yeah, where's the rest of this story?! I love this build thread, i have a 1930 Chrysler 3w here in the UK and reading this has helped my motivation and opened my eyes to possibilities.
    Hope its coming along and you're just holding back on where you are with it now!
  30. rschilp
    rschilp
    The good the bad and the ugly;
    - Been busy with customer cars and kids
    - Have not worked on the Chrysler much since the beginning of summer
    - Have collected some more parts and because of the work have more funds to spend on it
    Planning to go all out on the Chrysler again as soon as the temperature gets to "manageable" in the fall.
