MY OT 32 5W CHOPPED & BLOWN BLAST FROM THE PAST project..
Discussion in 'Off Topic Hot Rods & Customs' started by ALLDONE, Aug 24, 2025.
  1. twenty8
    twenty8
    Has it ever occurred to you that it might be posts like this one that attract some negative attention?
  2. ALLDONE
    ALLDONE
    did you read post 151? and did you understand???
  3. ALLDONE
    ALLDONE
    I think the point I'm try'n to make...traditional cars are cool... to me they are pulled out of a barn cleaned up got running...new tires and wheels... drop axel... the more old stuff the better...then there's what I call imitation builds ,not even one old wire brushed bolt on the whole car.. there's is no difference between a street rod and a traditional rod but the catalog you buy parts from..
    same with the 50's and 60's cars.. cool ol truck / car with og paint thats wearing thin...
    hotrodjack33 likes this.
  4. SS327
    SS327
    What brand are those? They are a good looking wheel kinda like Astro Supremes?
  5. ALLDONE
    ALLDONE
    american vintage wheels...
    SS327 likes this.
  6. SS327
    SS327
    That’s what I thought. I was looking at those for my Bonneville.
  7. ALLDONE
    ALLDONE
    what year??
  8. ALLDONE
    ALLDONE
    SS327 likes this.
  9. ALLDONE
    ALLDONE
    anyway.... on with the 32...one dislike I have is the mustang steering box... or should I say... the short 4 bar... I like hair pin.... haven't mess with this stuff in years... but... could i run a f1 box... and build it to mount on top of the frame??? and couldn't you just use a borgenson joint... then you could get a plain steering column???
  10. swade41
    swade41
    from Buffalo,NY
    Tradional cars will never go out of style, they are timeless, either you get that or you don't.
    Why bother coming here and asking questions if you just want to argue with everyone ? Those wheels **** and I've never owned them nor ever will, same with Oakley sungl***es.
    I'm out, good luck doing what ever trend your on.
    deathrowdave and twenty8 like this.
  11. ALLDONE
    ALLDONE
    thankyou...at least I can change the wheels...
  12. ALLDONE
    ALLDONE
    anyway.... back to the 32.. looking for an easy out fix..pretty sure someone has done this....I wanna get the 4 bar off and hair pin it... box has to move...although 4 bar probley works better...
  13. ALLDONE
    ALLDONE
    maybe better to go f100? instead of f1???....I see the direction this is gonna go...and my vision is all the front suspension off the car,,
  14. ALLDONE
    ALLDONE
    I bet you feel real good right about now getting to blast out like this...and being able to tell someone their wheels ****..
  15. ALLDONE
    ALLDONE
    I just wanna say this... sometimes, like said... I can 't see the forest for the trees.. sooo.. I ask for advise and opinions... never ever did I ask for approval or permission... at the end of the day, I listen to all the advise and opinions... then do what I want, how I want... it's my car... so don't get all bent cause I didn't do what you said do.. I make my cars.... my cars... not for sell so who cares...of corse, cars with attention to detail are the ones I like...sometimes I don't even like the car at all... but like what they did with it..
  16. DDDenny
    Uh, what was the question?
  17. ALLDONE
    ALLDONE
    are you my daddy?
    SS327 and hotrodjack33 like this.
  18. ALLDONE
    ALLDONE
    so last night, I was thinking... wonder what the cheater slicks would look like on the yellow roadster..stuck the on... right where I wanna be... so I ordered 2 more 5.50' and 2 more 15x4.5 americans...figure I could just swap the radials on when we run to bull head and havasu...
    so this morning we headed out...cars and coffee in vegas and break fast... both 32's ran very well... pretty happy right now...
    SS327 and 19Eddy30 like this.
  19. ALLDONE
    ALLDONE
    newest update... got the 4''x15'' wide crows toes american rims... but no tires from coker..so roadster is in waiting... on the coupe.. ordered a new drilled axel and drilled split bones kit .. i'm thinking I can raise the mustang box to where the bones will work and maybe change out the column at that time should be busy next week...
    19Eddy30 likes this.
  20. ALLDONE
    ALLDONE
    I seem to keep running into a block wall messing with the front suspension..
    I got the drilled axel and drilled split bones... mul***ude of problems...first, they welded the steering arm to the spindle...then heat and bent the tie rod arms...the suspension works great.. and steers good... I don't like it though... the 4 bar is way too short.... the steering box is in the way no matter what I try.... I could move it up or go to reverse corvair.. f1 or some thing...I sit out there on a bucket and just stare at it...probley 40 years since I messed with anything like this....I was also thinking of flat top hair pins,,,
    the way the steering is, it works with 4 bar as it goes through the bars... to put the split bones the arms would have to be heated again... don't like that idea as i don't like the idea in the first place.. to do it right I would have to remove from the steering wheel to the front wheels and start over.. I'm probley too cheep to do that to a car that works as is... so I'm just letting it sit.... not off the stove... just on the back burner on simmer...
  21. ALLDONE
    ALLDONE
    I've done a lot of these ... all easy... take the 4 bar off... cut the 4 bar mount off... put the hair pin on...then paint and done.... the p*** side will work like that... but the dr. side....night mare
  22. ALLDONE
    ALLDONE
    I'm still just letting this car simmer... but one thought I keep having is to get rid of the blower motor... it runs and drives perfect... and maybe I'm just not a street blower motor guy... I know it costs a grip to build a blower motor, and even though it's dependable... probley not my comfort zone the 671 on there...then next.... what power would I put there??? hemi?? cad motor?? SBC with a carb???
  23. ALLDONE
    ALLDONE
    568285678_1372860271223266_8775623803462260365_n.jpg 568703297_1402959764776689_4866388665378996603_n.jpg 570791733_1138336061602015_8229372797579529425_n.jpg 571220803_782768508091012_5375729849759391960_n.jpg Soooo...the blower motor???? I was thinking this...pull the motor???? pull the blower and put this on????in put welcome...
    59sedandelivery likes this.
  24. ALLDONE
    ALLDONE
    I don't wanna jump the gun... figure the blower motor would be easier to get rid of running in the car///// also easier to get rid of the blower if some one sees all the stuff you would need and seen that it works????
  25. ALLDONE
    ALLDONE
    the 3 -2's I know are not traditional.......but good copies...... might even wanna leave the coupe and put the 3-2's on the roadster????? IMG_6188.jpg IMG_6189.jpg IMG_6190.jpg IMG_6192.jpg
  26. ALLDONE
    ALLDONE
    lol... the bee hive is buzzing
  27. twenty8
    twenty8
    Not bees...... crickets.
    downlojoe33 and 57 Fargo like this.
  28. 59sedandelivery
    59sedandelivery
    EVERY single time it will be easier and bring more if they hear it and can go round the block... I SAY lets see the CADDY motor your hiding from us????
  29. DDDenny
    Be honest, isn't the "blower motor" what attracted you to the car in the first place!
    SS327 likes this.
  30. 19Eddy30
    19Eddy30
    from VA
    Not trying to start a argument,
    """ IS IT A BLOWN BUILT ""
    Or just
    Engine with Blower ?
    Not throwing rock's or bashing !
    I have ran blower on pretty close stock
    Parts @ 10psi , some last a
    Day or so , some 15-20k miles.
    The one sb I have Just main parts steet
    Engine .
    $1,500 crank
    $1,200 rod's
    $1,300 piston's
    $3,200 heads , no rocker
    O ringed .
    Mid to decent engine ,
    Yada , Yada !
    Do not need all this to have a blown
    Engine ,, my static is 11:1 I can run
    14 psi on , Block weak link stock.
    This before aftermarket Block's was commonly available.
    So I keep @ 5.5 psi, Pump gas still @ 6,000 - 6,300
    Iffy burning piston , In 1/8th ,No 1/4's
    No lock distributor
    25 btc
    Total 35
    Under boost 28 .
    Most looking @ Blown engine's compleat , they are going to want to know parts & history, Build sheet.
    With out pulling heads, pan & So on
    Me If I was going to take a chance
    Even with Leak down , cutting Open
    Oil filter , look @ oil pressure after about
    30 m - 1 hr Tops 6 K & thats also depends on Brand
    Of Blower, Style & condition.
    I have been looking @ 540's that have been freshened with doc's some short
    20k -35
    & long 45k used & ^^^
    I was dum A$$ few years back I sold
    Engine to a racer for 1/4 price 10 run's since freshen. Long block.10,000 rpm's.
    Was in Nostalgic F/c cl*** & popped his engine in Need for next race.
