My Second, First Car
Discussion in 'The Hokey Ass Message Board' started by Hotrod95, Jul 11, 2010.
  1. Hotrod95
    Hotrod95
    Thats a 52. And nah, they make bold on brakets that go off the original motor mounts.
  2. Hotrod95
    Hotrod95
  3. smarg
    smarg
  4. Hotrod95
    Hotrod95
    Haha. Thats the first one I showed her! She thought it was kool. Didnt want one thou. This is the site I showed her.
    http://www.kikker5150.com/indexb.html
    Not sure about the brakets.
  5. smarg
    smarg
    They are all the same brand, just distributed in different places.
  6. Hotrod95
    Hotrod95
  7. 53olds
    53olds
    Look's Cool, gotta love a old ford truck. Here is a model I built of one..
  8. Hotrod95
    Hotrod95
    Would you be looking to sell that?
  9. 53olds
    53olds
    Um...I don't know. You could build one just like it...it's painted Krylon Kackhe (TAN)...and just lowered.
  10. historynw
    historynw
    Make a good Fred G. Sanford truck
  11. 53olds
    53olds
    Is their another 48 sitting next to it in the pic???? Thought I saw one.
  12. Hotrod95
    Hotrod95
    Yes there is.
  13. Hotrod95
    Hotrod95
    Haha. they dont sell that year of model around me.
  14. 53olds
    53olds
    Oh...you could order one.
  15. Hotrod95
    Hotrod95
    Haha! True man. I like your ford. 60? Manual?
  16. Speaking of the Sanfords.. When you see the truck, from the inside of the living rooms P.O.V, they removed the windshield.. So you couldn't see the reflection of whats goin' on behind the scenes. Thats one flat windshield!
  17. Hotrod95
    Hotrod95
    We might be getting the truck later tonight
  18. Hotrod95
    Hotrod95
    We got the truck. Its pretty solid. A good ol' farm truck. Im gunna pull the seat this weekend and get the p***ager door unlocked since it didnt come with a key.. But thats all part of the fun.
  19. Hotrod95
    Hotrod95
    Pictures later. This will now become my build thread. I have a couple questions. 1.I got the p***anger side door to open from the inside. But I cant figure out how the handel works from the outside. Help? 2. What all would I need to buy/do to get this truck to a 12 volt system? Thanks guys!
  20. Hotrod95
    Hotrod95
    Bump. I need help
  21. the lights
    the lights
    if you cannot open the door from the outside the inside lever could be in the locked position or worn out. if its worn out you could take the whole ***embly out and possible weld it. for 12v you should need a 12v alternator, new bulbs, voltage reducers for the gauges that drop 12v to 6v found at your local radio shack, and new coil and wires.
  22. Cool truck! My Grandfather had one of those sitting in a field about 30 years ago. He gave it to my cousin and he got it running. It had the V8 in it and he would drive it around burnning oil like mad! I mean just a BIG blue cloud behind it. Well, he finely drove it to my house for a engine rebuild and we found the problem, a mouse nest in the lifterr valley! The mice had pulled the stuffing out of the seat, went down into the motor and made a nest. When the engine pumped the oil up into the motor, it could not drain back down. I guess with all the oil pumped up under the valves, some would get ****ed past the intake stem. Some things you never forget!
  23. Hotrod95
    Hotrod95
    Thanks!
    Haha. Man, gotta love hearin' storys like that! Thanks for sharein'!:D
  24. Cool truck, love the old fords.
  25. 56oldsDarrin
    56oldsDarrin
    #1 good steering, #2 brakes (all new stuff).#3 get that old motor running and drive it!
    oh yea, have fun.
  26. Scratchbuilt
    Scratchbuilt
    Fix the obvious first like , new brakes, tyres, exhaust, sloppy steering etc , your life and others are worth more than a few bucks worth of repairs you'll spend jus to make it roadworthy.
  27. hihorse
    hihorse
    from Orting, WA
    First make sure the gas tank and lines are not ruined by old gas sitting in it for 30 years. Drain away what is left over and dispose safely, then you can inspect it. If there are no leaks, lucky you, you might be able to save the old fuel tank with an Eastwood tank coating. If not check a repair shop or see if a repop is made for your truck. Meanwhile if you need to byp*** the gas tank, run a fuel line to the carb from a jeep can full of new gas. Clean out the carb before you run the new gas. Be verrry careful with that open gas can, a spark or spill will ruin you, your day, and your truck. Always disconnect the battery and keep a good fire extingusher around when working on it.
    Make friends with a guy who welds, have them show you how. Don't bother to weld a leaky gas tank, it isn't safe.
    You will probably find the floor is rusted through, so start practicing your welding skills on that. Then you should replace the front and rear window rubber so you don't leak rain water and rust the floor out again.
    Joining a group like this and your local car club will help you with fixes, finding parts, and even give you a club member discount on insurance.
