thanks for the coments and for liking my thread I have worked with rearend I have her spot weld the new spring hoders on the rearaxle Put it in the shoebox and test if it fitts I have now weld the holders the will lower the shoebox 1" I have put on the new u-bolt for test and the restored bottom brackets /Stefan
thanks for the coment I have a fight with drive shaft I have some problems with the spinces when i put it toghter but now is it up I put tempory in the shoebox with the volvo u-joint that not fit the ford 8" rear end /Stefan
I have a power brake kit from jamco suspension that should fit a shoebox it look like that the brake pedal shall be mounted outside the original master cylinder I have not a ***embly instruction to it or i not have fond it Her's the old master cylinder removed I think mayby to modyfi the kit so i not need put the old master cylinder inside the new pedal holder. If i do that will i move the new master cylder ***y. closer to the frame I can get som problems with the pushrod that it hit the gearbox member If i move it there will be more room for the headers/exhaust system /Stefan
I'd contact Jamco to see if they can help you out with the missing ***embly instructions . Seeing as you're in Sweden , an e-mail might be your best/only choice . **EDIT** you could also give HOTTWHEELZ a PM right here on the HAMB .
Hey Stefan,check out my build thread.I did some modification for the Jamco's mastercylinder bracket,its on the first page.I hope there's some help for you about them. The brake pedal will be too center,so there wont be enough room for the gas pedal without any modifications..
I took a look on your tread. Thanks I think to somthing like you. I have to melt it little before i start to do the modifactions /Stefan
this is why i come on here, if some one has a problem most of guys on are more then willing to help or point you in the right direction. AA++ for the hamb good luck Stefan
I must modify the brake pedal from jamco becase it not shall have inferace with my headers build I have cut of the boss on the backide of the holder so i can move it closer to frame and i cut the pedal holder and rotate it 180 degrees so it is in same deriction as the original pedal Her's a comper to the original pedal ***y. /Stefan
Quoting post #22 back in Oct 2009: Newcommer to this forum - in fact my first post, I must comment this whole build is taking place in a garage on my farm. The cars are mine (and my two sons) and on "the other side of the doors" are a full stable with horses and sheep . The Villager 9-seater as of the summer of 2011 My son David's slammed -67 VW Type 3 Fastback My son Andreas' ongoing project slammed -57 VW Oval (Sorry for the Off-Topic...)
Have just read the whole thread ! Really, really, really great stuff - keep up the pace (I need the garage space, ha ha ha ) !
I have worked with Jamco kit. I cut of the screw bracket on the master cylder holder. Now will came nearer the frame and so i can get more road clearance I have weld it up in the frame I put the parts up for a test the pedal is now in orignal place after moving the kit nearer the frame the master cylinder and the power brake unit is now put in near the frame and close to the floor I cut a hole in the foor for inspection and matance of the master cylinder i have to do somthing with this hole so it look better and make a lid to it /Stefan
Good job , Stefan . Looks good . I'll be doing something similar in the near future with a custom dual master setup . We did it already in (HAMB'er) Legend544's shoebox , so I have a perfect model to copy for mine ! I have to gather up the disc brake stuff yet - till then , it's drum brakes for me ... Figured I'd add a couple pics of what we came up with . It mounts in front of the crossmember just as original and fits to the original pedal , eliminating the long rod (it's non-booster , so it fits perfectly) . Pics are from mock-up stage , BTW - it's all plumbed now and works great .
You can come and take a new look on the shoebox it had happen some since your last visit in my shop /Stefan
I promice that should do something with hole in the floor I have made a frame that i think to weld in And now is only grinding left /Stefan
Thanks for the coment I cut a out some more of the floor there was some rust holes under the feet pan. and i repace the sheet metal under the pan /Stefan
Looking good Mr. T ! I was looking for this tool the other day: Any chance you know where it is? (Link to larger image: vwnettet.dk) Or could you possibly make a copy of this for removing door sprints?
