1952-59 Ford My speedo makes a lot of racket!
Discussion in 'Off Topic Hot Rods & Customs' started by evintho, Jul 28, 2024.
  1. evintho
    evintho
    Not sure why. It's fine up to 30 mph, after that it makes all kinds of noise and the needle bounces back and forth. I'm using the stock '93 Mustang speedo cable. It fit really well. Only a couple of inches too long (which I compensated for under the car) and the inner part that spins and mates to the speedo is the same size and shape (square) as the speedo. It's inserted well into the speedo too. The outer metal sleeve fits snugly on the speedo but I used a 1/2" FI clamp to secure it firmly. It's not loose. Does the speedo/odometer need to be lubed? If so, with what and how do I go about doing that? Just trying to address all the little issues that pop up after a full restoration.
  2. Alan Freeman
    Alan Freeman
    Maybe a dumb question, but did you lube the length of the inner cable before you inserted it in the outer cable?
    nosford likes this.
  3. evintho
    evintho
    No, I just used the entire cable from the Mustang. Never inserted the inner in the outer.
  4. shortshift
    shortshift
    Speedo is Not hard to dis***emble, but need to be removed from dash. One thing of caution,. When installing the plastic face back on the housing, the 2 screws at the bottom will crack the plastic if tightened to tight. Ask me how i know. Took 3 speedos to get everything right. Good luck Oh ya you can turn the odometer back to ) if u want at the same time Speedo Pics (12).JPG
  5. evintho
    evintho
    Yep, did the exact same thing when I re***embled mine! Do you know if the gears require lubrication?
  6. danman55
    danman55
    check this out - mine was making noise too.
    down-the-road likes this.
  7. Alan Freeman
    Alan Freeman
    As pointed out, taking the speedo apart to lube it can be tricky and can result in damage to it. I would try first removing the inner cable from the housing clean it well (as it sounds like you are using a used cable), lube the entire length of the inner cable as shown in Rev's video, ***emble the cable, hook it back up and see if that solved the problem.
  8. evintho
    evintho
    Well, I disconnected the cable from the speedo and tied it to the front of the dash so I could observe it while driving. The inner cable spun freely and it was completely silent. I really think the noise is coming from the gears inside the speedo when it's turning. Sure wish there was some kind of way to lube 'em.
  9. Paul2748
    Paul2748
    Most Ford speedos have a small oil hole at the top. If you can get to it, apply a SMALL amount of a light oil, like 3 in 1 oil.. Otherwise, remove it and oil.
    JeffB2, Dos Cincos and nosford like this.
  10. 51504bat
    51504bat
  11. evintho
    evintho
    Thanks you guys! I'll try Paul2748's method first and if that doesn't work I'll take 51504bat's suggestion and get in touch with Speedometer Service in Colorado.
