1952-59 Ford My Wagon needs new Tires
Discussion in 'Off Topic Hot Rods & Customs' started by Anthony Nigg, Nov 25, 2023.
Tags:
  1. Anthony Nigg
    Anthony Nigg
    My 57 wagon needs new tires, the old ones are rotten.
    I am running 225/60R15 on the SS Cragars and I am finding that 15 inch tires are hard to find. All I have found are modern style tires with odd designs on them.
    I am trying to keep the cost down, so Cokers are out for now.
    I found BF Goodrich TA radials for a okay price with a tire shop here where I live.
    I will need to turn the white lettering to the inside for a old school look.
    I known that radials are not what most like here, but I want to drive it down to LA on Highway 5 to see my daughter and car shows down there.
    So, if someone knows of a better looking Tire for around $180 please let me know.
    Tony
  2. bobss396
    bobss396
  3. abe lugo
    abe lugo
    If you are coming down to LA area. Check out performance plus tires in Long Beach. They have your T/A for 158.00 and other options.
    I got lucky and bought the Coker radials when they were 225.00 before the prices soared.
  4. ajracing9
    ajracing9
    I got a set of 235/70r15 coppers for 126 each plus taxes and install at America's tires. I got there replacement plan too. America's tire price matches pretty much anyone.
    abe lugo and bobss396 like this.
  5. Texas57
    Texas57
    I am definetly not a period-correct guy, but to me the raised white letters just don't look right on a 50's car (sorry, AJ). That said, neither do the Hankook tires I have on mine, but not so obvious. Mine have the "odd design" that the OP posted in his opening post, but they are great tires. I went with them because of a wider range of tire sizes available than most other brands.My fronts were replaced about a year ago with 60k+ miles, and my rears look to be about 1/2 worn with 74k miles on them! Don't believe I've ever had a tire last so long on any car, and my car handles great in dry or wet weather.
  6. Zax
    Zax
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. ajracing9
    ajracing9
    Ouch Tex! Lol Im kinda going for the dirt racer NASCAR look haha! I tried a set of black walls and I didn't like all the design in the sidewalls. Even these tires in the backside with no white letters still have design. I like the sleek smooth side walls but I can't pull off white walls .
    Texas57 likes this.
  9. I'm another fan of Cooper Cobras. But they no longer make a 225/60-15, but do have a 215/65-15 which is very close to the same diameter, just a small bit narrower. How about $125 each to your door?
    4 Tires 215/65R15 Cooper Cobra Radial G/T AS A/S All Season 95T | eBay
    Want to spend even less? I've had good luck with Hankook and Falken tires also, but they also don't offer a 225/60-15 anymore, just the 215/65.
    Don't like the 'designs' on the sidewall? Sand 'em off....
    Technical - Smoothing an ugly sidewall | The H.A.M.B. (jalopyjournal.com)
    ajracing9 and JeffB2 like this.
  10. jimmy six
    jimmy six
    How wide are your rims?
  11. Anthony Nigg
    Anthony Nigg
    I think they about eight inches, not sure a 100%, they look towide to be seven inches wide.
  12. Anthony Nigg
    Anthony Nigg
    Thanks eveyone for the info.
    I never thought of sanding the side walls of the tires.
  13. abe lugo
    abe lugo
    On sanding the tires it easier to lift the car and put on a jack stand and turn the wheel as you go. I did this to clean up a messed up white wall and it worked well.
    Also note it's messy and can stink. So wear eye, hand and breathing protection.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    Or this ? And this for wide whites.
