Projects My Willys Gas Coupe build
Discussion in 'The Hokey Ass Message Board' started by langy, Mar 20, 2011.
  1. Jalopy Journalist
    Jalopy Journalist
    from Austin, TX
    I keep expecting to read ...
    Really, your work is amazing.
  2. milwscruffy
    milwscruffy
    Langy, The saw that you used to hand cut the 3/4" aluminum I've never seen such a saw. What would be it's proper name.
  3. langy
    langy
    Thanks Eric, hope you well & safe
  4. bobwop
    bobwop
    from Arley, AL
    you should consider becoming a jeweler
  5. Racrdad
    Racrdad
    Another amazingly simple (if you have the tools) fabrication of a functional and beautiful one off part. Will be waiting to be amazed by your next update!
  6. robleticia
    robleticia
    Are you kinding me right now???? Man, that's some really cool work!
  7. langy
    langy
    Had to go to the tyre place to get a customers tyres fitted and Crumble had got my tubes for me (thanks John) plus I had been itching to get my Radir tyres on my ET rims.
    I had a slight clearence problem on the inner arch as these tyres bulge out a fair bit so I replaced the wheel studs with some longer Strange Eng studs and fitted a 1" spacer either side. I don't have a problem running spacers.
    I'm still undecided about the whitewalls, I may turn them around.
    Had to cut a fair bit out of the rear arches to get them on and they still need blending & fettling which i will sort at bodywork time. Its got a bit more at***ude now.
  8. I never saw this thread before...
    Just beautiful stuff! :eek:
    Hope to see that car on the road :cool:
  9. langy
    langy
    Thanks, it will see the road for sure.
  10. junkyardgenius
    junkyardgenius
    from Kernow
    Think it will come this far? :)no excuses now mate this one,s got a roof. Looking good , like the whitewalls too but hey what do I know?
  11. I hope to see it by myself, we are not so far ! :D
  12. Jalopy Journalist
    Jalopy Journalist
    from Austin, TX
    Two things...
    1) I love this picture. I saved it. I am not really sure why, but it just looks perfect.
    2) I know that you are into stainless steel, and you do polish it quite commonly, have you ever made a stainless frame and polished it?
  13. langy
    langy
    You may like my other project then 26T build, click here. [http://jalopyjournal.com/forum/showthread.php?t=267054
    QUOTE=Jalopy Journalist;7128834]Two things...
    2) I know that you are into stainless steel, and you do polish it quite commonly, have you ever made a stainless frame and polished it?[/QUOTE]
    Sent from my iPhone using TJJ
  14. TomT
    TomT
    Langy - the car is looking very, very good. You've made some really great progress since I saw it last when I had the "honor" of standing in your driveway this past summer before we all took off for the Supernats- love the switch panel you made up - very slick!
  15. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Ya know, I'm an American, so I automatically think everything we do is the best...
    But watching this thread, it REALLY makes a person understand the English "Keep a stiff upper lip" mentality! Talk about self-sufficcient! Wow, with a "go get 'em" at***ude like yours (and God-given skills), it really shows how the Brits were able to hold their own during WW II.
    Impressive! Are you gonna make your own tires (tyres) next? ;)
  16. hershambob
    hershambob
    whitewalls look great steve
  17. langy
    langy
    Hi Tom, know you know why i'm slow replying to emails :eek:
  18. langy
    langy
    John don't feel bad about us Brits being the best :D:D:D
    Seriously thanks for the comments.
  19. Cymro
    Cymro
    The tool is question is known as a Panel hack saw, normally used to cut sheet metal as it does not have a frame as such to restrict cutting depth, similar to a panelsaw for wood.
    Great work Langy, do you ever sleep?
  20. langy
    langy
    Sorry i must of missed Milwscruffys's post, yes your right about the saw.
    Whats sleep ????
  21. langy
    langy
    Thanks Bob, you may like the front ones too.
  22. langy
    langy
    Met Carl at Heathrow to pickup my front wheels, Carl had already started on the disc conversion but not finished it so i have a little machining left to do.
    The disc is positioned on the wheel hub by an adaptor that also holds the oil seal. 5 holes need to be drilled through the disc, adaptor and into the wheel hub, these will be slightly counterbored and tapped 5/16" UNC, a co**** thread is used as the magnesium is very soft and i fine thread could possibly strip, the studs are fitted into the counterbore so that the force is taken by the shank of the ARP studs I am using and not the threaded section.
    The spindle is an early ford part & bearing setup is normal taper bearings with a standard size oil seal.
    The calipers & disc is from a modern car and the caliper has to be fairly small to clear the wheel, clearences are very tight !!!
    Custom caliper brackets have to be made and removing a wheel means removing a caliper first so this has to be taken into account when making the brackets. 3/8" UNF hi tensile bolts hold the spindle to the internally threaded hexagon bar caliper spacers.
    The caliper plates are made in 1/4" stainless plate, Securing bolts are hi tensile countersunk setscrews that have been modified slightly.
    Heres the completed setup.
  23. langy
    langy
    Clearances are a little on the tight side !!!
  24. langy
    langy
    Maybe !!! :)
  25. captainjunk#2
    captainjunk#2
    youve probably heard this enough times , but gawd you do some outstanding work , heck of a fabricator , and a great eye for detail , wish i had the patience ,
  26. langy
    langy
    Thanks Capt.
  27. farmer12
    farmer12
    Langy, how many more times do I need to tell you............outstanding work!
  28. langy
    langy
    As I'm considered an old guy now I forget what you told me LOL
  29. jimdillon
    jimdillon
    Langy, I had mentioned several pages back that I had some spindle mount mags like the ones you purchased. Mine are mounted on a straight axle and I would rather run front brakes if I ever intend on driving the car.
    Not sure how or which rotors and calipers I will use, but thanks for how you are going about your project. I am sure I will scratch my head a couple of times and then look at how you did it for comparison when my time comes. Thanks again, Jim
  30. langy
    langy
    Glad its of some help to you Jim.
