Projects My Willys Gas Coupe build
Discussion in 'The Hokey Ass Message Board' started by langy, Mar 20, 2011.
  1. Don's Hot Rods
    Don's Hot Rods
    from florida
    Damn, Steve, that roll bar looks fantastic, and so does the front end. Your chrome buddy does really nice work and from the sounds of it gives you a good deal.
    Hope you and Sue have a nice New Years, and take it easy on the cider New Year's eve. Nah, second thought, get blasted. :D
    Don
  2. otas
    otas
    Just caught up with this. Saw the roadster build as well. Wow Steve. Subscribed for sure to this one!!! Can't wait to see paint on this incredible build.
  3. langy
    langy
    Thanks Don, yes he looks after me good, Happy new year to ya.
  4. langy
    langy
    Thanks Otas, hopefully you won't have to wait too long.
  5. spot
    spot
    from usa
    Everytime I check in your build I am shamed by your skills and attention to detail. Great build.
  6. art.flame
    art.flame
    hi Langy , i'm going to some meets in the UK this year ,hayride, hot rod drags ,are you going to one of them?
  7. gassercrazy41
    gassercrazy41
    every time you post a picture of your work, it amazes me. Great work!
  8. langy
    langy
    I'm usually at most of the events mate, I'm hoping to take the Willys to the Hotrod Drags.
  9. langy
    langy
    Thanks mate, don't be shamed mate we all build to the level of finish we require.
  10. langy
    langy
    Here's one of the wheels fitted, ignore the fact i put the springs back on the wrong way round , the pins are off set and i didnt notice till it was back on the ground.
    Fitting the spindle mounts did exactly what i wanted by moving the wheel inboard a few inches, the old wheels were pushed out by the adaptor in the disc kit and the answer would of been to narrow the axle slightly.
    Today i took the wheel to an expert, he was a really nice bloke and even let me have a go on a s**** magnesium rim, Its very much like welding ally, except the gas mix is 50/50 argon/helium and the rod is obviously different, we used a az101 filler rod. The arc is also much shorter than aluminium and everything has to be very very clean. Also he preheated it.
    I learn't a lot of this old guy today and now would'nt hesitate to have a go myself.
    Unfortunately he didn't finish the job as he ran out of rods :(
  11. farmer12
    farmer12
    Looking good as usual Steve!
  12. langy
    langy
    Thanks Eric, you jetting around or back at home.
  13. Altered wheelbase g***er? Go with it! LOL
  14. Triggerman
    Triggerman
    from NorCal
    So Langy, I have had a question about welding magnesium and perhaps now that you are experienced you can answer it. Magnesium burns ferociously because it supplies it 's own oxygen. It even burns underwater, I've been told. Soooo, how do you prevent the magnesium from burning when welding it?
  15. langy
    langy
    That's one of the things that was puzzling me mate, I've done aluminium welding but the thought of burning magnesium put me off having a go so i took it to an expert, it was the first question i asked, apparently it only ignites when it gets too hot, I was told if it did ignite plunging it into dry sand would put it out.
  16. bentwings
    bentwings
    Magnesium welds ok but you muct not have mag filings or chips around. Be very carefull grooving a crack out that you do not cause any sparks. It's been a long time since I welded it but it welds much like aluminum but a casting is very likely to crack faster than you can weld up the crack. last year an "expert" tried to weld one of our cast mag blower manifolds that had developed a crack. It split from a simple 1 1/2" crack to about 4 inches the very first hit with the tig. then developed another couple of cracks farther down. It was a huge mess. We took it back and sent it out to the mfg and it came back with a bill for about 2/3 of a new manifold plus shipping.
    Mag rod can get to $90+ a pound.
    Make sure you know what to do if you get a fire....
  17. Triggerman
    Triggerman
    from NorCal
    Langy, I suppose the sand cools the magnesium down enough that it puts out the fire. You basically answered my question mate. Thanks
    bentwings, so even an expert has difficulty welding magnesium. It seems to be one of those materials that it is better to melt it down than try to repair.
    Soooo, what do you do if you get a fire? Plunge it into dry sand as Langy wrote?
  18. Triggerman
    Triggerman
    from NorCal
  19. bentwings
    bentwings
    Used cl*** D fire extinguisher for burning metals.
  20. rovertenrod
    rovertenrod
    Like all your builds- fantastic work Langy! Subscribed on every site I see them. I worked do a while at an aircraft parts factory (Harlow, Es***)where one day the flame cutter jammed while cutting a 1/2" sheet (8' x 4') it went up. I was in the next room. It was like a scene from The Tommyknockers. Green light emminating from every nook and cranny of the room. The whole building was evacuated until the fire services sorted it. Also saw a chap at a s**** yard flame cut a gearbox out of a VW Golf (Rabbit) once. The mount went up for a few seconds! Don't know why it didn't continue! Be careful. , I've seen the carnage.
  21. langy
    langy
    The guy doing it welds the mag wheels for the Historic racers so i reckon he knows what he is doing, but thanks for the tips.
  22. 5w31a
    5w31a
    from England
    Steve, as you know I work in a historic Formula race team, we race all types of cars F1, F2 , Group C, all are wheels are magnesium, any time we have a wheel failure through accident and they get damaged regarding how slight these have to be s****ped, as no one we use would consider welding them due to the Health and Safety implications.
    Should any wheel fail the outcome would be catastrophic, therefore you need to take great care with the wheel you have had repaired.
    Brian
  23. langy
    langy
    Thanks Brian, Appreciate the advice, He has said it will be crack tested as a matter of course, We will see what happens.
    It seems that welding magnesium castings on aircraft is quite normal practice
  24. 1954satan
    1954satan
    any more updates Steve?? is it running yet;)
    ps. did you get the message about the caddy motor?
  25. langy
    langy
    No not running yet Ray, I'm building a 514ci for it with a 8/71 blower for it, yeah got your message and replied.
    Sent from my iPhone using TJJ
  26. langy
    langy
    Well not much progress to speak of but today i'm a very happy chappy, Got a call from the wheel repairer to say my Spindle mount mag welding was done, They did an absolutely outstanding job and you would think it had never been damaged !!! They also sent it for crack testing and gave me a certificate to prove its ok.
    They couldn't remachine it as their lathe was down but luckily i knew someone that had a big faceplate on a lathe, 24 hrs later it was done (thanks Brian)
    Before
    After
  27. Don's Hot Rods
    Don's Hot Rods
    from florida
    Glad to see those saved, Steve. They are too nice and rare to see them become s****. Are you going to be able to run tubeless tires (or is it "tyres" :D ) on them or will you have to use tubes?
    Say hello to your good looking helper for us. :)
    Don
  28. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    That's pretty amazing stuff there. Wheel looks great!
  29. langy
    langy
    Thanks Don, no one is happier than me about it :D
    After chatting to the repairer for 1/2 hour i knew i was in the right place.
    Sue sends her love & kisses.
    have to run tubes in them anyway as they don't hold air terribly well.
  30. langy
    langy
    Thanks mate, it sure does !!!
