Projects My Willys Gas Coupe build
Discussion in 'The Hokey Ass Message Board' started by langy, Mar 20, 2011.
  1. Triggerman
    Triggerman
    from NorCal
    Beyond grey primer, you're gonna have to build saggy door supports and the car will have to be bump started all the time LOL.
  2. langy
    langy
    I hope not !!!
  3. shane85
    shane85
  4. Triggerman
    Triggerman
    from NorCal
    On the plus side, it'll have a blown hemi.
  5. langy
    langy
    Show off :D
  6. ScottV
    ScottV
    Out of an AMC Matador Police car no doubt !!!
  7. Triggerman
    Triggerman
    from NorCal
    Awww, but the bobbies don't have Matadors over there so Langy is just gonna have to smuggle one outta the states.
  8. Langly, Ive heard that aftermarket 460 ford intakes will fit on the big cad motors. May be something to look into. Cool build also.
  9. langy
    langy
    Yep they do but with work, to be honest i dont think 2 x 4 barrels is in my budget at the moment so will probably start with just one and then improve the motor over time, Thanks for the input its appreciated.
  10. langy
    langy
    Weather been a bit on off today but managed to get a bit done a****st the interuptions.
    Originally was using a Vega box but just not enough clearance on engine as its a bit lower in the frame than most, Alternative was to use a Land Rover box, these are very underated and easy to mount and work real nice.
    The box is fitted with a built in column which was no use to me so i cut it off just above the top bearing, doing this means a oil seal has to be fitted on top of the top bearing, a 1.75" OD 3/4" ID seal presses straight in.
    The iiner column was then cut down, the majority of it is tube but the bottom couple of inches is bar so 2 flats were ground on it and then it was fitted with a double D UJ.
    I will bore a 2" hole in the side rail when the engine is next out as the hole has to have a sleeve welded in to the hole, also the mounting bolts need sleeves welding in also.
    While having a tidy up i came across a pair of shocks i had bought at some time, they are new and had the right dimensions so i thought i would get them fitted today.
    The shocks had a 2 bolt lower fixing so that was removed and i spun a couple of adaptors up on the lathe for the shock to mount on and also space them off the front axle slightly.
    The top mount was made from 1/8" flat plate, a few holes were added so they are slightly less boring.
    All welded and bolted in place.
  11. langy
    langy
    Spent yesterday evening making up some 60's style wheelie bars, I did a bit of searching around and got contacted by an old gas racer from the 60's who gave me the info i needed.
    I started with a pair of 5" OD steel wheels with a rubber tyre that i found on ebay, then my mate Mark Bull donated a pair of 1956 International truck springs which i cut 3" behind the centre bolt.
    Next i plasma cut a axle mounting bracket from 3/8" plate and used 56 Chevy truck U bolts to clamp it together.
    I'm pretty pleased how they came out !!! Just hope i don't need them !!!
  12. glenn33
    glenn33
    from Browns, IL
    Say what???
  13. langy
    langy
    Ha ha ha ha ha
  14. 41 Dave
    41 Dave
    Langy, You never disappoint. Each and every update shows the progress and craftmanship that you are capable of. Way to go there Mate !
    Dave
  15. Yes I am enjoying this build also! Interesting because the car is fibergl***, I don't think the body has to be steel. For me it has more to do with the style you build the car. I think you are setting a new standard. Very cool project!
  16. gasserkiwi
    gasserkiwi
    hey there langy, nice build, duno if this is of any use but i used an early transit steering box in mine and it worked out real nice, looks good too.
    wheelie bars are cool as is the rest of the car.
  17. langy
    langy
    Very kind of you to say Dave, thanks.
    I forgot this pic in last update.
  18. langy
    langy
    Thanks Kev, I got my initial inspiration from your very own project.
  19. langy
    langy
    Thanks mate, I take it yours is RHD ??? mine is a left ******.
  20. About the Gl*** body...I was shootin' the breeze with Gene Altzinger at Bowling Green about my Willys being gl***, He replied shoot, the only steel on most of the old g***ers was the roof and quarters!!! No big deal !!!!
  21. R Frederick
    R Frederick
    from illinois
    I'm still a little disgusted about the way you have to make everything look so precise. You're making me look like I'm fabricating my stuff with toenail clippers. Heck, you don't even have any dirt on the ground. I've been rolling around for two weeks doing my floor pans, and can't figure out where the bucket fuls of dirt come from. It's like someone throws shovel fuls of dirt and metal shavings all over the garage when I'm gone. You make it look like surgery. I'm going to go shake my head now.:D
  22. langy
    langy
    It certainly don't bother me mate but there are those out there that don't seem to like the gl*** body :(
  23. langy
    langy
    Hahaha, you cracked me up :)
  24. violet springs
    violet springs
    I have been following your build from the beginning and look forward to your updates. You have some very impressive fabrications skills.
  25. langy
    langy
    Thanks man, whats the low down on the car in your avatar then ??? looks dead cool
  26. violet springs
    violet springs
    It a was a tube ch***is car that I am G***erizing. I'll post a build on it some time in the future.
  27. langy
    langy
    You wouldn't happen to know this measurement would you ??? Or anyone else ?
  28. When it comes to fitting a Willys fibergl*** hood the only important thing is that the body line is straight with the rest of the car. Put some masking tape down the line so you can see it easily and then either trim the hood to lower it or re mount the fenders until everything lines up, you may have to do both or add some gl*** to correct gaps. Those Willys with uphill hoods don't look so good.
  29. langy
    langy
    Ah ha, thats exactly what i did Kev, except i used black insulation tape :)
    Just curiosity really, I trimmed the bottom front hood edge slightly and it seems to all line up pretty good now.
    I need to make some spreaders to fit inside the hood as the sides are flexing in slightly, I'm not using hinges on the hood or the trunklid just holding them both in place with pins.
  30. koolkemp
    koolkemp
    I agree 100% its the build style and the quality of this build that reeled me in !!
