My yellow white walls
Discussion in 'The Hokey Ass Message Board' started by slysball, Feb 25, 2009.
  1. slysball
    slysball
    I have a set of wide white bias plies that the white has yellowed. I tried steel wool so far but it didn't work. The bleach white scares me. Any suggestions on how to whiten my yellow?
  2. wesleys tire shine.
  3. Special Ed
    Special Ed
    Do NOT use anything containing bleach!!! Use formula 409 and sandpaper. Yes, sandpaper! Do NOT use bleach...
  4. slysball
    slysball
    I heard bleach would crack the white wall. That is why westleys bleach white scared me.
  5. H3O
    H3O
    i've always had good luck with westley's bleach white. never had cracking. just use it like soap, spray, scrub and rinse off.
  6. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I used westleys for years and the sky hasnt fallen yet.
  7. slysball
    slysball
    By the way what grit paper have you had the best results from?
  8. Special Ed
    Special Ed
    Bleach will dry-out and eventually crack, and destroy the whitewall.
  9. theladylux
    theladylux
    I've always had great luck with Westley's Bleach White...never experienced any cracking...
    I guess it depends on how old the tires are...
    I've always used it on newer tires that have turned yellow, (10 years old or less) without any problems.
    Good Luck.
  10. Special Ed
    Special Ed
    220 grit. 150 grit if you have deep marks.
  11. slysball
    slysball
    Thanks for the info. These tires are like new but just that dingy yellow.
  12. BBYBMR
    BBYBMR
    I've used SOS pads
  13. Jarzenhotrods
    Jarzenhotrods
    from .......
    I agree with totallycustom, I have 1 year old whitewalls on my car and they have cracked/checked from using the bleach white. I also live in a very dry climate so that might have something to do with it.
    I have heard that coker sells a really good whitewall cleaner.
  14. BBYBMR
    BBYBMR
    "I have heard that coker sells a really good whitewall cleaner."
    I don't think it works well at all.
  15. Mike51Merc
    Mike51Merc
    Wesleys + Scotch Brite (kitchen sponges) = no problems here. Keep it off any inintended surfaces though.
  16. LOWCAB
    LOWCAB
    from Houston
    I used to use Comet cleanser on a wet bristle brush. Then just rinse. Used it for years with no problems.
    BR
  17. 61TBird
    61TBird
    +1 on Comet(Ajax also works) and a brush.
    SOS pads work well also.
    Try Simple Green and a scotch brite pad too.
  18. model-a-fan
    model-a-fan
    from Kentucky
    I use magic erasers and a cheap cleaner called Spray Power. The yellow just runs off, tires look brand new.
  19. rustrustler
    rustrustler
    I have a 66 t-bird with 20 year old tires that I use bleach-white and a scrub brush on and no checking or cracking. I do,however rinse each tire good after scrubbing.
  20. plywude
    plywude
    from manteca ca
    Try Kingsford charcol lighter fluid, it will blow your mind how good it cleans them ,its also great on tar spots on your paint and any glue over spray on your upholstery I have used it on leather and vinyl and it cleans with out messing any thing up. it takes that sticky stuff off your windsheild from those event stickers too, Plus it only cost a couple of bucks for a 1/2 gallon of it.
  21. bobwop
    bobwop
    from Arley, AL
    you can buy Goof Off in an industrial strength. It works great on whitewalls, sticker glue, bugs, etc. I am thinking it isn't too far off from the Kingsford chemistry
  22. Thorkle Rod
    Thorkle Rod
    Another vote for the Comet/Ajax and a stiff brissle brush, has worked for more than 55 years for me starting with my Schwinn 2 speed in 1954.
  23. xsteve
    xsteve
    from puyallup
    I've always used Wesleys with good results, but if you dont wear rubber gloves it will make your fingers dry up pretty good! make me wonder what it will do if you don't wash it off the tires.
  24. slysball
    slysball
    It sounds like what really takes place here is you are not really going to clean the stains off. You are actually going to scrub off the top layer of yellowed rubber. The bleach would penetrate the rubber and clean it but harm it, the scrub pads and sand paper would sand off the top layer of rubber exposing the whiter rubber below?.
  25. Special Ed
    Special Ed
    Exactly. Go to DiamondBack Tires website and read what they say about bleach products used on whitewalls.
  26. theHIGHLANDER
    theHIGHLANDER
    I use wesleys on cars valued at over $1,000,000. Never an issue. I also use it to get blackwalls blacker.
  27. Stevie Nash
    Stevie Nash
    I've never had any problems with Westleys. It's the best.
  28. HOTRODRUBBER
    HOTRODRUBBER
    Mr Cleans Magic Eraser / Westley's Bleach White
  29. I've used Westleys Bleach White for years on my '36 and elsewhere. I've had the best of luck with it. If it does damage the rubber over a long time I haven't found it. Anyway, I hope to wear the tires out before that.................
  30. Same here-- on a wet scrub brush. Works every time.
