Projects My "You didn't build that" 27 T Roadster build thread
Discussion in 'The Hokey Ass Message Board' started by daddio211, Sep 13, 2012.
  1. 26 T Ford RPU
    26 T Ford RPU
    About a week then.:eek::rolleyes::D JW
    daddio211, brad2v, JOYFLEA and 3 others like this.
  2. daddio211
    daddio211
    First prime and sand... [​IMG]
  3. 26 T Ford RPU
    26 T Ford RPU
    Must be some more progress to report. Started the drive shaft yet? Mine is back to a rolling ch***is now. JW
    daddio211 likes this.
  4. daddio211
    daddio211
    Yikes, I'm long over due for an update. Yes, we have progress!
    Jeremy, driveshaft is done just needs paint.
    Steering column is in and wiring to it done...
    Small victories count, right? Finding a radiator hose was a huge pain. I ordered a Dayco 71380 and chopped it up a bit. I'll put a piece of 1 1/2" tubing in between these two.
    Other than that, I've just been tying up loose ends so it doesn't really look any different.
    Sorry for the delays, middle of the elk hunt right now, plus work has been super busy.
  5. daddio211
    daddio211
    Fishing headlight and blinker wires through the frame rails now. Old speedometer cables work GREAT for this! [​IMG]
    Sent from my SM-N950U using The H.A.M.B. mobile app
  6. daddio211
    daddio211
    Note to self: lower radiator hose is Car Quest Green Stripe 82008GL with 1/2" removed from each end. [​IMG]
    brad2v, AndersF, loudbang and 2 others like this.
  7. daddio211
    daddio211
    Ugh, guess I'll have to take pics first then upload them later. Taking them within the app doesn't rotate them correctly.
  8. 26 T Ford RPU
    26 T Ford RPU
    Great to see progress, Eric. That drive shaft looks good as does all the other bits and bobs. Very cool. JW
    loudbang, daddio211 and JOYFLEA like this.
  9. 26 T Ford RPU
    26 T Ford RPU
    Speaking of progress, Eric, you need to check my build (rebuild) thread....the push is on.:cool::D JW
    tfeverfred and daddio211 like this.
  10. cowboyinachair
    cowboyinachair
    from colorado
    a straight forward t stat housing would make that top hose look a ton better
  11. daddio211
    daddio211
    Totally agree. I tried three different ones and because the vintage Offy intake and Rochester fuel bowl are SO close I couldn't find another option.
    I even tried on of those rotating ones.
    26 T Ford RPU likes this.
  12. cowboyinachair
    cowboyinachair
    from colorado
    kidcampbell71 likes this.
  13. cowboyinachair
    cowboyinachair
    from colorado
  14. daddio211
    daddio211
    kidcampbell71 and loudbang like this.
  15. cowboyinachair
    cowboyinachair
    from colorado
    well hell if you have a steel one bob can make it work
  16. daddio211
    daddio211
    We've discussed it at length. Bob despises welding anything cast. This one has the temp sender built in so it works, as the intake and block done have provisions for it.
    loudbang and 26 T Ford RPU like this.
  17. daddio211
    daddio211
    Back at Bob's this afternoon. Driveshaft painted and in... still not done with wiring but I'm getting close.
    Now I remember the debacle with the thermostat. I needed one with the thermostat boss and went through several before settling on this one. Doesn't look like it, but I can slide a piece of paper through that gap, LOL.
    Also have the 1 1/2" pipe cut and installed, but it'll get painted before the clamps go on.
    Blue One, loudbang, AndersF and 2 others like this.
  18. 26 T Ford RPU
    26 T Ford RPU
    Great progress, Eric. You have a lot of wires under there and glad you are painting that pipe. At this rate you may just beat me to having a driver as I hope to mate body with the ch***is by the end of the month. JW
    kiwijeff, t-rod, daddio211 and 2 others like this.
  19. daddio211
    daddio211
    Yeah, that's a TON of wire but it'll all dress up nicely. That's the trouble with mounting the fuse panel in the trunk, lots of wires to hide.
    26 T Ford RPU, t-rod and Blue One like this.
  20. cowboyinachair
    cowboyinachair
    from colorado
    do you have a pic that shows the top of the engine
  21. daddio211
    daddio211
  22. cowboyinachair
    cowboyinachair
    from colorado
    just a thought for in the future you could run a 1/4" carb spacer to get the t stat housing you want
  23. daddio211
    daddio211
  24. cowboyinachair
    cowboyinachair
    from colorado
    good to hear you dont want to get your temp reading from that side of the t stat either if the stat sticks you gauge wont show hot
  25. 26 T Ford RPU
    26 T Ford RPU
    The sender will still read if it does stick as the heat will still transfer as its not being cooled. JW
    da34guy and daddio211 like this.
  26. cowboyinachair
    cowboyinachair
    from colorado
    on that side if its stuck shut it wont be the right temp cuz water is not flowing by the sender
    tomschev2 likes this.
  27. 26 T Ford RPU
    26 T Ford RPU
    It is still encased in coolant and the valve of the thermostat will not stop the heat from the other side from transferring I/2 an inch to the temp unit. If you could measure any difference in heat it would not be worth recording. If it was on the motor side and the stat stuck shut it still wouldn't have water ''flowing'' past it as the coolant will be stationary. JW
    da34guy and JOYFLEA like this.
  28. JOYFLEA
    JOYFLEA
    I always drill a 3/16 hole in my t stats . A little circulation . Carb spacer is one thing I would definitely use . Helps with all this ethanol fuel ,176 f boiling point I’ve been told . Looking great Mr. O . Be in Vegas for SEMA if your going . Maybe I could finally meet you . Blue
    afgjr, daddio211 and 26 T Ford RPU like this.
  29. 26 T Ford RPU
    26 T Ford RPU
    I agree with the hole in the stat, I do it to all mine. It also helps to get air out when changing the coolant. Took me awhile to figure who ''Mr O'' was, to me its ''Mr H'' !!:cool: and yeah he is worth meeting.:cool::cool: :rolleyes::D JW
  30. JOYFLEA
    JOYFLEA
    Tried to get together with Eric last year but we couldn’t get it together .
    26 T Ford RPU and daddio211 like this.
