Technical Mysterious angle dizzy drive
Discussion in 'Traditional Hot Rods' started by V8-m, Sep 20, 2022.
  1. V8-m
    V8-m
    from Alaska
    Hello Guys,
    Quick question...I have oportunity to buy Scintilla dizzy with angle drive. It looks like factory one ...it have Ford script on it. Can somebody tell is it worth attention?
    Thanks!
  2. 62rebel
    62rebel
    Well; if it's not priced like a cotton farm in Georgia, I'd say snap it up. They sure aren't making new ones.
    V8-m likes this.
  3. banjorear
    banjorear
    Industrial or tractor?
  4. Fordors
    Fordors
    I don’t know the application but the letters SAF on the casting mean it was made by the Ford subsidiary in France.
    Carter and V8-m like this.
  5. Budget36
    Budget36
    The way it’s made, and ***uming it mounts somewhat with the cap upright, is like a FH Ford that would be driven with a slot on the end of a camshaft.
    FHs have the slot favoring one side, not suggesting it’s for a FH V8, but the last pic makes it look like the slot to go into would be offset as well.
    The Fords do have a 3 bolt distributor on some too, maybe try to match up and compare?
    V8-m likes this.
  6. V8-m
    V8-m
    from Alaska
    Yes, it looks like Flathead angle drive..something early probably. I though I could use it with vertex magneto but it would seat very high probably..
    Intetesting piece
  7. Budget36
    Budget36
    If the price doesn’t hurt you, and even if you can’t use/modify it to work for you, it’ll be good to hang on the wall;)
    V8-m and Desoto291Hemi like this.
  8. Asphalt Demon
    Asphalt Demon
    from Australia
    I believe these were factory german flathead items,ive been looking for one for some time Johnny
  9. Budget36
    Budget36
    Tanks maybe or?
  10. Asphalt Demon
    Asphalt Demon
    from Australia
    Not sure but ive seen them on German engines,and they seem to show up in Brasil too. I believe Matt from iron trap found one in his travels. Johnny
  11. banjorear
    banjorear
    What is throwing me is the three bolt mount and the use of the 8BA style dizzy. The 3 bolt mount was phased out in the early 40's with the advent of the 59AB series.
    With Ford, anything is possible, so I hope someone here knows what this came off of.
  12. X38
    X38
    French you say? Perhaps it's related to their military flathead V8's in some application?
    Fordors likes this.
  13. hemihotrod66
    hemihotrod66
    I believe the three bolt distributer went away after 1936....
  14. alchemy
    alchemy
    The two bolt cover and distributors were introduced in 1942.
  15. V8-m
    V8-m
    from Alaska
    Distributor is suited with va*** advance. I don't think that's industrial.
    @Asphalt Demon do You have any photos of those engines?
  16. The angle drive is from a french Ford Vedette 136 cu in 60 hp flathead.
  17. V8-m
    V8-m
    from Alaska
    Mystery solved! Thank You!
    BlueNotes likes this.
  18. Magfiend
    Magfiend
    I could use one of these - anyone know where one might be for sale?
