Mystery gearbox - ford v8?
Discussion in 'The Hokey Ass Message Board' started by Kume, Mar 9, 2012.
  1. Kume
    Kume
    Have acquired this gearbox thinking it would fit an early fathead but am now not sure. Can anyone ID it for me.
  2. It will fit, its a truck 4 speed.
    Apparently they are not worth a pinch of shit.
  3. 302GMC
    302GMC
    from Idaho
    At least you now have a clutch alignment tool ...
  4. Kume
    Kume
    Thanks chaps - am new in the flat head field and suspected I had acquired a pinch of shit. Should have done my homework first. At least it was a very cheap learning curve.
  5. First gear in that thing is a real stump puller, and the removable side cover is for mounting a power take-off. The mounting bosses on the shifter top are for the big truck parking brake lever/ratchet mechanism. It will bolt right up to '32-'48 flatheads except 60 HP. This trans is the hot ticket if your flathead is going into a wrecker or log truck.
  6. 117harv
    117harv
    Looks like a AA model A truck trans?
  7. Flatheadguy
    Flatheadguy
    I have two of these gearboxes (transmissions) and if anyone who want them, they are FREE. Come and pick them uo. Too heavy to ship. In a few weeks hey go to the scrap yard.
  8. 38 coupe
    38 coupe
    from Texas
    The later versions of these had a removable bell housing typically called a "hogshead". Many T-5 to flathead conversions use these "hogsheads". You can probably cut the front of that particular transmission case off and machine it for a T-5 conversion too.
    I am fascinated with the heavy duty u-joint and rear motor mount on this transmission. The rear motor mount looks suspiciously like a 32 rear motor mount. If you decide to junk the transmission, would you mind sending me the u-joint parts? I'll pay shipping.
    If it is a 32 rear motor mount, someone will be willing to purchase it from you. If not, I'd be interested in it as a curiosity too.
