Technical Mystery i-beam axle: Can you identify ?
Discussion in 'Traditional Hot Rods' started by Richard Newton, Oct 12, 2023.
  1. Richard Newton
    Richard Newton
    from Reno, NV
    I picked this up recently for nothing because I thought it was interesting, but have searched the web for many of the common US auto manufacturers circa 1920-1940 and couldn't find anything even similar.
    Other than the unique dip in the center of the axle, which should help greatly in identifying it, note that it apparently used a single transverse spring, NOT semi-ellipticals (no large pads on the axle) with spring perch holes 35-1/2" apart, the top of the kingpins are 50-1/2" apart, and the forging is 1-3/4" wide, looking down from the top. BTY, it's beefy as hell, much like my '32 heavy axle. Two pics of it are attached.
    Any help would be greatly appreciated !
  2. trevorsworth
    trevorsworth
    Is that old chrome or just bright steel on the high spots? Cool axle - looks like a dropped Model A or 32 (through 36) with some custom flair and those dimensions match those pretty closely.
    Are your measurements center to center of the holes? The dip in the middle would shorten the axle just a smidge if you were measuring straight across.
    alanp561 likes this.
  3. Fordors
    Fordors
    I think that is a ‘46-‘48 Lincoln axle, check the diameter of the king pin holes, early Ford is .813, Lincoln is .936
    Nailhead Jason likes this.
  4. trevorsworth
    trevorsworth
    Here is a Lincoln on eBay for reference. Harder to find pictures of these than of Fords.
  5. Mr48chev
    I'm not seeing any tweaks from having camber set that you see on some I beams and those bends in the middle seem to match. Mystery Axle 1.jpg
  6. Illustrious Hector
    Illustrious Hector
    From the angle of the king pin holes, it looks like wall art.
  7. Dan Hay
    Dan Hay
    Hmmm, that bend doesn't look intentional... like it was mangled and straightened at some point. Here's a pic of a 37-41 Lincoln axle, ad says 52" KP to KP but no perch measurement.
  8. Heres a Lincoln axle i had 20 odd years ago.
  9. krylon32
    krylon32
    from Nebraska
    Check Anson Axles On Instagram. He has several pictures of Lincoln axles he's worked on.
  10. Hot Rods Ta Hell
    Hot Rods Ta Hell
    The OP's axle in question doesn't look like any of the Lincoln axles posted as the Lincolns all have a flat center section that angles upward on both sides. The Lincoln axle 34 Gaz posted has much different shaped webbing section between the spring perch and kingpin.
    I agree with Dan Hay, that it's an unintentional ben (damage) vs a purposely dipped axle. Look at the pic Mr48 Cev posted; the dip is not centered. It's slightly off-center to the left.
    trevorsworth likes this.
  11. trevorsworth
    trevorsworth
    Also every Lincoln axle that has been posted has a raised pad inboard of the perches which this axle does not have. I still think it is a dropped Model A or 32.
    As is, the camber would be crazy with a regular Ford spindle so I also think the bend is damage and not style…
  12. IIRC, the kingpin inclination on Lincoln axles is different than that on ford axles.
  13. Fordors
    Fordors
    The k/p holes will tell the story.
  14. dirt car
    dirt car
    from nebraska
    Looks like a Lincoln to me, if so, I believe the inclination of the spindles will differ from the Ford, not sure how compatible it might be, but then anything is possible with proper tweaking.
  15. krylon32
    krylon32
    from Nebraska
    I just looked at Anson's Instagram page and the axles he claims are Lincoln do not have any pads?
  16. Richard Newton
    Richard Newton
    from Reno, NV
    Thanks very much for the info - the seller of the axle and most of the replies here point in the direction of a Lincoln axle, but I believe your assessment is closer. To answer your questions, the axle isn't chromed, the hole to hole dims I stated are centerline to centerline, but the most telling dim are the kingpin holes. They mike out at .997-1.000. Was your note about big trucks having 15/16" and 1" kingpins referring to Ford big trucks or other makes? Got any idea what models of big trucks have those kingpins? I looked at AA's earlier, but they seem to be the same as cars.
  17. Richard Newton
    Richard Newton
    from Reno, NV
    Thanks - kingpin holes mike out at .997-1.000. Would that be some kind of big truck?
  18. trevorsworth
    trevorsworth
    I am having trouble finding specific information and don’t have the personal experience to weigh in, but may be prewar/wartime 1-1.5 ton truck?
  19. Fordors
    Fordors
    IDK, but that is very likely. As mentioned by @trevorsworth I could’nt find k/p specs on large early Ford trucks either.
