mystery part
Discussion in 'The Hokey Ass Message Board' started by stellar, Mar 4, 2011.
  1. stellar
    stellar
    Does anyone know what the heck I found?
  2. henry29
    henry29
  3. stellar
    stellar
    Thanks, I knew it was something someone would be able to identify. where was my head? It has an electric clutch to engage the fan and pulley. It looks fordish to me but I can't figure what it came from.
  4. Fighter-of-Wars
    Fighter-of-Wars
    Appears to look like a fan. With attached mounting bracket.
  5. daddio211
    daddio211
    Looks like an 8BA flathead fan to me. I'd bet $5 on it!
    I've never seen one with the electric clutch looking thing, but I'm not a FH expert either.
  6. stellar
    stellar
    did they have an elect clutch?
  7. Deadweight
    Deadweight
    Thats interesting. Looks like it could be an aftermarket setup.
  8. stellar
    stellar
    23mm thats about 7/8 inch in american money
  9. stellar
    stellar
    I doubt if its aftermarket. It looks as old as the hills and weighs half a ton. They don't make stuff like this anymore. Unless it was an antique aftermarket.
  10. Maybe old diesel stuff ?
  11. 32-3 WINDOW
    32-3 WINDOW
    from utah
    im going to guess with some of you , i suggest possibly a older large truck flathead maybe , 272/292 raised type mount to get more in heart of air flow , maybe even coe , older electric lock up hub as newer have air control and thermo switchs , just thoughts though
  12. stellar
    stellar
    My best guess is the fan was engaged by a temperature switch to power the clutch making for better cooling.
  13. 57tailgater
    57tailgater
    from Georgia
    Maybe an electrically switch controlled electromagnetic clutched fan drive? Disengage at higway speeds then engage when creeping thru city traffic? My guess. :cool:
  14. sdluck
    sdluck
    Common on diesel trucks
  15. stellar
    stellar
  16. Heo
    Heo
    Fan from a 292 truck engine
    Here is the bracket it mounts on
    engine is from a f600
  17. stellar
    stellar
    That looks sweet. Where does the wire go?
  18. stellar
    stellar
    It looks like you need one. The price is right, but the shipping will get ya.
  19. Heo
    Heo
    I dont realy checked that they came from the cableharnes
    gues they came from a temp switch mine was a firetruck
    with front mounted pump gues they neded a electric fan
    when running the front pump standing still
  20. stellar
    stellar
    great info. Anyone need or want it? I hate to s**** it if it can be used.
  21. F&J
    F&J
    Heo, those headers are pretty cool :cool:
    I like the large radius sweep on the pipes.
  22. Heo
    Heo
    Thank you here is a better pic filled the pipes with lead
    and bent them with the tube bender i use for bending
    rollcages then melted the lead out
  23. unkamort
    unkamort
    Glad it was ID'd. It would make more sense to me to find an armature and windings in there so the fan could overrun in a low RPM/high load condition, rather than a clutch to disengague and free wheel. Those engines run 'a little warm'. Hers an idea... amaze your friends and make a shop fan outa'it.
