Technical Mystery transmission
Discussion in 'Traditional Hot Rods' started by V8-m, Jan 18, 2023.
  1. V8-m
    V8-m
    from Alaska
    Hello,
    Can you guys help identify this gearbox? Sprockets are not original.
    Thanks!
  2. Well its a Ford. LOL
    There that'll get 'em started
    seb fontana likes this.
  3. V8-m
    V8-m
    from Alaska
    I know it's Ford...but what model exactly.
    Garbox is smal about half size of the regular 3speed transmission...some kind of a reduction box ? Truck?
  4. with that shifter tower it is most likely a truck box.
  5. squirrel
    probably from a Popular, Anglia, or similar. Like the 100E, or something.
    V8-m likes this.
  6. V8-m
    V8-m
    from Alaska
    Thank You
  7. gimpyshotrods
    gimpyshotrods
    Ford 3-speed sawmill.
    Desoto291Hemi likes this.
  8. Mr48chev
    It resembles a T-96. Could have started life as an Early Ford GWP (their version of the Jeep) Transmisson.
    V8-m and seb fontana like this.
  9. Beanscoot
    Beanscoot
    They were also often adapted for use on fishing boats.
    ProtoTypeDesignFlauz and V8-m like this.
  10. AccurateMike
    AccurateMike
    100E Anglia Transmission. Mine's in a car. I would like to see the other side. Looks close from here.
    Mike
    V8-m and squirrel like this.
  11. lostone
    lostone
    from kansas
    Old lathes I've seen had 3 speed trans on some of them too.
    V8-m likes this.
  12. DDDenny
    Yep
    My uncle had a small machine shop that he built at home, a number of his machines used them.
    V8-m likes this.
  13. V8-m
    V8-m
    from Alaska
  14. AccurateMike
    AccurateMike
    Here's a drawing of the LH side of an earlier 8/10HP trans. Sure looks like it.
    Mike
    V8-m likes this.
  15. roadsterlines
    roadsterlines
    The mystery transmission looks like it's from a 1930's four cylinder, 933cc or 1172cc Ford. The right side view shows two threaded bosses, for mounting part of the hand brake mechanism. Also on the right side is an inspection hole for the oil level. I have seen this kind of gearbox housing on a 1937-38 1172cc four cylinder Ford.
    Later versions of this gearbox are basically the same but don't have the two bosses on the right side and they have a dipstick at the top front corner, right side, instead of the inspection hole on the side. (See part number 7179 in AccurateMike's diagram.) There is one sitting on the floor next to me right now (an empty housing). (I have become a bit too familiar with these things.)
    The 'tower' that the gear lever fits into looks a bit taller than I would expect but that could be a distortion in the photo.
    squirrel, V8-m and AccurateMike like this.
  16. V8-m
    V8-m
    from Alaska
    Thank You! Mystery solved.
