Mystery! - Weird '6bbl' 409 Chevy F.I intake - Can anybody I.D???
Discussion in 'The Hokey Ass Message Board' started by mart3406, Sep 3, 2010.
  1. ACACG
    ACACG
    from TX
    More 409 fuel injection!
    more info here
    348-409.com
  2. Max Gearhead
    Max Gearhead
    from Wisconsin
    Very interesting!:cool:
  3. bigdav160
    bigdav160
    The FI manifold (above) doesn't look anything like the one originally posted.
  4. Little Wing
    Little Wing
    from Northeast
    Yes, you can see the 3 carb base sections,,interesting...nice piece of work
  5. Boat application, custom made fuel injection, note the mounting flange at the distributor hole and no water crossover/ thermostat. One of a kind.....MAKE IT WORK !!!!!
  6. carbking
    carbking
    Ditto Mart3406's comments.
    Pontiac was working on a "6-barrel" carb. The throttle bodies in the pictures certainly resemble tripower end carb throttle bodies. Check the thick throttle plates, and the throttle return spring wrapped around the throttle shaft bearing area.
    Jon.
  7. ACACG
    ACACG
    from TX
    The Fuel injection set up now Belongs to Pat Lobb. I currently work on some of his Projects. And its been an awesome expireance working on Such unique stuff like this. We are currently working on it and hopefully will have it in running condition soon.
    As i was searching for some random parts i ran into this board and saw the pics of the FI setup... awesome pics.
  8. GaryB
    GaryB
    from Reno,nv
  9. ACACG
    ACACG
    from TX
    We got it running. Just some more fine tuning. but ir runs! :D Will post a video of it soon!
  10. wrench409
    wrench409
    from Here
    Congrats!
    Looking forward to it!
  11. wrench409
    wrench409
    from Here
  12. Max Gearhead
    Max Gearhead
    from Wisconsin
    Cool beans!:cool: Thanks much.
  13. heath brinkley
    heath brinkley
    looks like the backside (where they mount to the intake) of merc (outboard)carbs. Mercury v-6's use 3 2 bbl carbs. It looks like someone ditched the rest of the carb and jammed the three together to use for the air inlet.
  14. heath brinkley
    heath brinkley
    After looking at the pictures close, I'm nearly certain thaat's what it is. Get some better pictures of the linkage and I could tell you fer sher. Even the springs and the linkage look mercury. If so get the linkage from a v-6 merc, you just need to cut down the linkage because the carbs are futher apart.
  15. saltracer219
    saltracer219
    Possible military?
  16. wrench409
    wrench409
    from Here
  17. ACACG
    ACACG
    from TX
