Technical Nailhead Buick
Discussion in 'Traditional Hot Rods' started by iafraser39, Jan 16, 2014.
  1. iafraser39
    iafraser39
    from Warmland
    Can anyone out there tell me if the outside
    diamensions on a 425 cu.in. nailhead are the same as
    a 401 cu.in . nailhead.
    Also are the exhaust and intake manifold interchngeable?
    I have a 401 in my model A and want to step up to a 425.
    Thanks
  2. Mike Moreau
    Mike Moreau
    The exterior dimensions are the same. The intake and exhaust manifolds will fit on the new motor. Your swap will be a "remove and replace" deal. The appeal of being able to say you have a 425 over a 401 is obvious. You my want to do some research and determine whether the incremental increase in performance is worth the cost and effort. Please indulge my unsolicited advice. Good luck with your project.
  3. iafraser39
    iafraser39
    from Warmland
    Thsnkd for the info.
    I believe that the LX series 425 has 360 HP,
    wheras my 401 has 325 H.P.
    I may be wrong though.
  4. Check the flange on the crankshfts, make sure they are the same.
  5. Mike Moreau
    Mike Moreau
    Mctim,thanks for pointing out my omission. I completely forgot about the change from the Dynaflow crank pilot to the 400. The 63 and earlier had the Dynaflow, the 64 & later had the 400. A little research on prefixes willl give the years and compatibility. The old rule of modifications applies: "changing one thing changes two more." Iafraser, what is the car used for? What is your objective? A 401 in a Model A primarily used on the street is a pretty neat ride. If you mostly race it, that is a different deal.
  6. robertsregal
    robertsregal
    401 + 425 intake interchangable
    Exhaust manifold 364-401-425 interchangable
    A good information site teambuick.com
    Good luck would love to have had a 425 in our special but found a good 401. Good Luck
  7. 12amrider
    12amrider
    from tacoma wa.
    there is also two starters up to 65 and mid 65 to 67. the turbo takes the 63-67 along with the flex-plate not that triangle looking thing.
  8. What state is Warmland in?
  9. iafraser39
    iafraser39
    from Warmland
    Warmland is on Vancouver Island, British Columbia
  10. iafraser39
    iafraser39
    from Warmland
    I'm Running ST 400 ****** behind the engine. I have one of elesco's mini starters.
    Everything works fine. I will need to rebuild the 401 I have, but would prefer a 425
    now that I see everything is interchangeable. The car is a street machine only.
  11. What car is this going in?
  12. iafraser39
    iafraser39
    from Warmland
    Its going in a full fendered 1928 Model A roadster P.U. to replace
    a tired 401 .
  13. Ol Dawg
    Ol Dawg
    While you are at it why not go for a Grand Sport intake. Two 4BBLs would be nice.
  14. iafraser39
    iafraser39
    from Warmland
    Right now I'm running an Elerbrock 750 and its too much for the 401.
    I guesse 2 fours with progressive linkage would be OK. I'm really
    tight for space though as I run a full hood.
  15. If you are going to go fast with your Nailhead, 401 is by far better. I have built a lot of Nailheads, 425's are great, but do have ring seal issues if you don't partially fill the block and once you go .040 on the bore, it's pretty much done short of a miracle block with extra iron in it. 401's are bulletproof and all the power in a Nailhead is in the heads/valvetrain. Your Edelbrock 750 should be just fine, but did you port the intake to match? You cannot just throw a 750cfm on a stock intake and go, the stock venture holes in the intake are sized for a 625cfm and that may be your issue. Also, the stock 64-66 single 4brl distributors are limiting once you go bigger on the carb. They can be recurved to a dual quad timing curve and work great. Believe it or not, a stock 401/425 actually likes an Edelbrock 800cfm carb once the distributor is recurved and the intake ported. Cam and heads like it even more!
    DQD
    Bam.inc likes this.
