Technical Nailhead- ford clutch
Discussion in 'The Hokey Ass Message Board' started by shonky, Feb 12, 2017.
  1. shonky
    shonky
    from Norfolk UK
    Hello
    Can anyone tell me what clutch & adapters I need to mate a 264 nailhead to a 47 column shift 3 speed Ford box ?
    I have a Cragar 309 adapter + a new flywheel which I think is for an 11" Chevy clutch
    All help much appreciated
  2. swifty
    swifty
    I've got a similar problem to you. 401 Nailhead, Offy Nailhead to Flathead adapter then MEC Flathead to T-5 adapter. 11" GM clutch fouls in the Offy adapter. Local Commodore (read GM) 10 1/2" pressure plate bolts to Buick flywheel but diaphragm fingers have too small a diameter to mate with the early Ford throw-out bearing.
    kiwi4d on here had the same problem with his Flathead/T-5 combo and found the solution but when I asked for the info he never replied on his thread and ignored the PM I sent.
    Where did your new flywheel come from as if it came from Bendtsen or Russ Martin like mine it is drilled for both 11" and 10 1/2" GM pressure plates.
    Also do you have the pilot bearing adapter which is required with that engine adapter? It is Cragar part # 10-3091
    shonky likes this.
  3. wbrw32
    wbrw32
    A 49-51 Merc pressure plate (borg & beck) will do what you need...will bolt to flywheel and has fingers for 1 3/8 T O Brg. Do not use a diaphragm PP
    shonky likes this.
  4. shonky
    shonky
    from Norfolk UK
    New flywheel came with the motor but has not been fitted , so not sure of its origin,
    & no I do not have a bearing adaptor !
  5. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I have a rebuilt 49-51 Merc clutch(10 inch) in Borg and Beck for sale. The bolt pattern has 6 evenly spaced holes in the pressure plate. $40 plus ship to your door. Thanks flatheadjohn47 Texas 979-595-7324 cell.
    shonky likes this.
