Nailhead Guru's.......Lend me your ears.....
Discussion in 'The Hokey Ass Message Board' started by stealthcruiser, May 17, 2011.
  1. stealthcruiser
    stealthcruiser
    66 model, 401 cu.in..........My buddy has one, with a cracked stock, 4bbl. intake, and major vacuum leak.
    His questions:Will his stock Carter 4bbl, work on an aftermarket aluminum intake?
    Any one in particular?
    I think, ideally, he would like to keep it stock, but has driving it on his mind as well, with the nice weather here..................
    Z Man.....................any recommendations?.....................It's just a driver, not Hot Rodded at all.
    Anyone, have any intakes available, ( stock or other 4bbl.type)?
    P.M. me, and I'll forward the info to him.
    Many thanks!:D
  2. Jmos4
    Jmos4
    Hi,
    66 nailhead would be a 401 or 425 and if it has a carter it should be a 401
    intakes are only avialable stock cast iron either carter or 1 year only q-jet 4 bbl as no aftermarket one on the market plenty of dual quad manifolds along with a few tripowers
    from what I have seen stay away from the Offenhouser dual quad as it flows worse than stock 4 bbl, if you get another stock intake check out V8 buick and Doc's dual plane manifold
    http://www.v8buick.com/showthread.php?t=225437
    if you are interested I have a stock intake from my 64 and I do have a 66 q-jet with carb that I might be interested in parting with
    good luck
    Jim
  3. hisel76
    hisel76
    sometimes the vacuum leaks are caused by the freeze plug under the intake. i actually have 401/425 intake with the freeze plug in the bottom that needs replacement and a stock 4bbl carb also. pm me if interested
  4. stealthcruiser
    stealthcruiser
    He's got a visible crack in this one, ( he says), and I have not seen it.
    P.M. sent.
  5. stealthcruiser
    stealthcruiser
    Thanks.
    P.M. sent.
