Nailhead in 50s Jalopy --- What is it?
Discussion in 'The Hokey Ass Message Board' started by Southfork, Oct 4, 2008.
  1. Southfork
    Southfork
    I've been trying to ID the nailhead in a recently acquired jalopy built in '57 or '58 in San Diego. The old guy who built it and raced it in the San Diego area in the late 50s can't remember what year or displacement the nailhead is. He said that he put the nailhead in the buggy in about '59 after deciding that neither the original flatty nor a short-lived Corvette SBC could produce the kind of torque that he wanted.
    I understand that there is probably a serial number on a machined surface between the middle branches of the exhaust manifold on the left side of the nailhead, but removing the header to access the side of the block where the serial number should be will be quite a chore. The builder had attached the nailhead header flanges with allen head bolts and I can't get enough torque on them to loosen them up after 50 years. Eventually, with heat, I can probably loosen them, but I'm trying to get a quick ID on the engine (planning a winter rebuild).
    The old nailhead has a Cragar trans adapter connecting it to a top-shift Ford 3-speed ******, and the Cragar number on the trans adapter is 309.
    I measured the distance between the front two intake bolts and it looked to be about 8 3/8 inches center to center. This tells me that the engine is probably a 322 or a 264, but I'm not even sure about that. Even if it is, how would i tell which one?
    There is a casting number centered on the back of the block right next to the Cragar trans adapter that looks to be 1165185.
    Is anybody familiar enough with these older nailheads that they can tell how to ID them without knowing the serial number?
  2. 55 dude
    55 dude
    pic's would help.
  3. R Pope
    R Pope
    264's and 322's were the only Buicks with spark plug covers. If yours has, or has the threaded bosses for the covers, that narrows it down a bit.
  4. striper
    striper
    I can't find that casting No. How sure are you of it?
    The only one that I can find that looks close is 1185485. It's a 401.
    Pete
  5. striper
    striper
    Do you have casting numbers off any other parts? Might help to narrow it down.
  6. TagMan
    TagMan
    "I measured the distance between the front two intake bolts and it looked to be about 8 3/8 inches center to center. This tells me that the engine is probably a 322 or a 264, but I'm not even sure about that. Even if it is, how would i tell which one?"
    The distance between the right & left manifold bolts on a 264/322 should be 7-7/8". A 364 should be 8-3/4" and 401/425'should be 9" even.
    On the engine block (I believe these numbers are in all the nailheads, not just the bigger ones which I'm familiar with) , just in front of the valley cover should be two sets of stamped numbers. One set set of numbers is stamped upside-down, as you view it. Let us know what those numbers are.
  7. Southfork
    Southfork
    Took a couple of pics and verified some casting numbers on the old nailhead. The casting number on the heads is 49840-2.
    The intake manifold casting number is 70617-2.
    The casting number on the back of the block above the transmission is 1165185.
    There are no stamped or cast numbers on the machined edge in front of the valley cover. Any buick nailhead experts out there?
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    From the looks of the bolt pattern on that transmission adapter, it's got to be a '53-'56 block. The '57-'66 blocks didn't use the two top bolts that are shown in the pix.
  9. Southfork
    Southfork
    Another pic.
  10. zman
    zman
    from Garner, NC
  11. Ace Brown
    Ace Brown
    from OH
    remember too that only 264s and 322s had round exhaust ports, if you ever take the manifolds off. also, looking at the block casting of 1165165 (?) appears to be a 322/264 casting number. according to here:http://www.buicks.net/shop/reference/nailhead_casting_numbers.html
    the numbers with 116 beginnings are 322s or 264s. that's most likely what it is plus all the other info. these guys gave already. Any pics of the jalopy??? :D
  12. Southfork
    Southfork
    Yes, if I could get the left header flange unbolted, then i could access the serial number, but since I cant loosen the header flange bolts (in a hurry anyway), I was hoping there would be another way to tell a 322 from a 264, etc. 'Thot maybe the casting numbers would tell the story???
  13. Ace Brown
    Ace Brown
    from OH
    do you have a harmonic balancer?
  14. Big Dan
    Big Dan
    Pull a head...... A 322 cylinder hole is 4.00 in. anything smaller is a 264... I know cause I thought I was sending a 322 to be bored .30 over and the guy from the machine shop called and told me what I sent him was something smaller then a 322 cause a 322 is 4.00 in. It ended up being a 264
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    264s have a bore size of 3.625. I see that someone mentioned the presence of a harmonic balancer; all 264s had a simple lower pulley, with no balancing ring.
  16. Judd
    Judd
    Valley pan with the oil fill is from a 53 to early 55 Motor they would be 264 or 322. You can see the motor stamp# between the exhaust manifolds on the opposite side of the oil dip stick on block deck with the manifolds on.
  17. Brad54
    Brad54
    from Atl Ga
    How about taking some pics of the engine a little farther away? Let us get a good overall view of as much of it as possible.
    It's looking like a 264/322 engine, but seeing the exhaust manifolds would help. '53 322s didn't have a harmonic balancer.
    The surest way is to measure the bolt holes on the intake, and compare to the numbers TagMan gave.
    -Brad
