Nailhead ????????? Interchangability?
Discussion in 'The Hokey Ass Message Board' started by bobbleed, Jun 9, 2004.
  1. bobbleed
    bobbleed
    from Awesome
    Will a flywheel from a 364 bolt to a 401?
    I know the bell is the same, but is the flange on the crank the same?
    Thanks, Bob
  2. suedesled
    suedesled
    NO the 401 has a smaller crank hub than the 364. You can turn the center on the 401 to fit the 364. I have an aluminum 364 I would trade for a 401 if you like.
  3. Fraz
    Fraz
    from Dixon, MO
    401's from 1959 to 1963 WILL INTERCHANGE. 64-66 will require machining to enlarge the center hole. Switched from Dynaflow to the ST400 in 64, the pilot hole in the crank was smaller, that's why the machining is necessary.
    Duh, re-read your post. The 364 flywheel will bolt up to the 401's just fine. Make sure you line up the little hole in the flywheel with the dimple on the crank. If you don't, it'll be out of balance and that's not a good thing.
  4. bobbleed
    bobbleed
    from Awesome
    Wait, I'm confused now.
    I have a flywheel from a 1957 364, and I have a 1964 401 with the ST 400.
    Can I bolt the 1957 Flywheel to the 1964 motor? Or do I need to find a pre 1963 motor?
    Thanks, Bob
  5. Fraz
    Fraz
    from Dixon, MO
    Read your post wrong. I thought you wanted to put a 401 flywheel on a 364. I read it backwards.
    You can bolt your 57 flywheel up to the 64 motor just fine. As I mentioned before, there's a small hole in the flywheel that needs to be lined up with a dimple in the crank, otherwise it'll be off balance and vibrate itself to death.
  6. zman
    zman
    from Garner, NC
    The balance is different between the 364 and the 401 so unless you plan on rebalancing the point is moot,
  7. bobbleed
    bobbleed
    from Awesome
    So is this gonna work or not?
    Seems to me if it bolts up it will work?
    Thanks, Bob
  8. Bass
    Bass
    from Dallas, TX
    I believe that nailheads are externally balanced. I'm pretty sure the flywheel will bolt up, but you'll have to have the rotating ***embly re-balanced.
  9. suedesled
    suedesled
    The 57 flywheel will work on the 401 but you will need to have an adapter ring machined to fit the 64 401 crank hub. If not it will vibrate since the bolts will not center it. I have the same set-up on my car now. But as was posted before you need to line up the locating hole.
  10. leadsleadolds
    leadsleadolds
  11. Bob
    If you do need balancing..., Dan Whittmore in Dousman can do it for you..., But I don't think you want to get that involved on that project. [​IMG]
    Mark
  12. bobbleed
    bobbleed
    from Awesome
    Thanks. I'm starting to hate hot rods.
    Does anyone know of a cheap 364?
  13. skyspop
    skyspop
    I found another 61 lesabre up here that I am thinking about buying for my other four door,its complete,the guy says the motor did run,but not now,auto trans,I mainly wanted the body and trim,He wants 300 for the car.about a 1-1/2 hour haul for me.I dont know if your interested in that 364 or not,I would deal it as I have two now.Patrick..
  14. Rodshop
    Rodshop
    Poston's (Buick parts guys) have a 401 flywheel avialible. they have a company in California that machines one and ships it to you directly. It is I think a little over two bills but you can run that up pretty quick modifying things that you buy, or picking up a differnt motor. rodshop
  15. bobbleed
    bobbleed
    from Awesome
    Skypop, I may be interested in that motor, if nothing else turns up. I'd like to find one that is a good runner as I already have a messed up one. I'll let you know.....
    Rodshop, do you have contact info for them?
    Thanks, Bob
  16. titus
    titus
    i had to read it bunch of times to figure out what the heck was going on!
  17. topdeadcenter
    topdeadcenter
    Bob,
    Call this guy. I called him about an ad that he placed on autotrader about 2 (two) 1958 Buicks. One was a runner. He only wanted $500 for BOTH cars. (I don't have the room) it sounded like a good deal. The guy is like a hundred years old, so you will have to talk slow...
    608-582-2263 He is in Gailsville. Near LaCrosse, WI. I don't remember his name, though [​IMG] But call him! It is a deal.
    Mike
  18. Rodshop
    Rodshop
    Yeah. They are in Atmore, Alabama. (334)368-8577 or the Order Line (800)635-9781. they don't seem to have a web site, but searches fine lots of references to them.
  19. atch
    atch
    http://www.postonbuick.com/
    they really don't get into nailheads on their website, though. however, their address & phone numbers are there.
  20. CaseyK
    CaseyK
  21. zman
    zman
    from Garner, NC
    TA performance also sells brand new flywheels for the 401/425... http://taperformance.com/ it's $249 but a very quality piece. and the correct balance..
  22. bobbleed
    bobbleed
    from Awesome
    Thanks alot guys, I'll start making calls.......
    This hot rod stuff is hard. I just want to put a damn motor in it and do some doughnuts. HaHa
  23. repoguy
    repoguy
    Hey bob,
    Ray (ironhunter) has (or had) one of the hot 364's (300 horse 4 barrel) out of a 57 roadmaster or something.
    I was talking about buying it at one time, but now I'm buried in other ****. He's probably still got it sitting around & would make you a deal (especially if you told him what it would be used for). You should get in touch with him, he's a solid dude. And he can answer just about any nailhead question you could possibly have.
