Nailhead mecanhic
Discussion in 'The Hokey Ass Message Board' started by texasred, May 26, 2010.
  1. texasred
    texasred
    from Houston
    Ok boys i'll try this again ..anyone know a good nailhead mecanhic in the houston area
  2. zman
    zman
    from Garner, NC
    and again we will ask what is the problem? It makes a difference. If it's something that needs to be fixed versus a full rebuild.
  3. Maybe he has no tools, time, or interest in fixing it himself?
  4. zman
    zman
    from Garner, NC
    Wether he wants or can do it himself is irrelevant. He wants a recommendation. But won't tell us for what. The actual work to be done makes a difference on that. If it's an actual full rebuild could get a different one than chasing down a cooling issue.
  5. I gotcha.
    I met a guy named Red at the Burnout Houston, I have the gray/gray primer '65 Rivi, that you?
  6. texasred
    texasred
    from Houston
    im working out of town i need someone to swap a 401/400 into my 55 special ..i don't have time to do it myself
  7. texasred
    texasred
    from Houston
    no not me
  8. zman
    zman
    from Garner, NC
    Has it already been converted to open driveline?
    What transmission?
    Wiring?
    If it's a fresh or good engine then I'd say you need more of a hot rod fabrication shop. If we sent you to a Nailhead builder he couldn't/wouldn't do this work.
  9. texasred
    texasred
    from Houston
    motor , trans rebuilt..400sp 65 riviera rear end 4 bar ..ok a shop that has worked on buicks
  10. woodenbuick
    woodenbuick
    from Austin TX
    Give Javier a call at Javier's Auto Unlimited. He has helped me with all my Buick's.
  11. nailheadroadster
    nailheadroadster
    Why the hell do you need a nailhead "mecanHic" for an engine swap? LOL
    All kidding aside...
    texasred : You may wanna ask better questions or learn how to answer the questions asked before gettin your panties in a wad and starting a new thread because things don't happen to be going as you planned. Why you ask? Because the work you are asking about does not involve a "nailhead wrench" (regardless of how standard it is... versus metric) or a nailhead "mecanHic". A reputable shop with knowledge of closed to open drive conversions or rear end swaps and suspension work should be able to accomplish the desired result you mentioned.
    Also, just a hint for ya... Zman and Tagman are 2 guys you should be really nice to if ya wanna learn something about Buicks... especially since one of the aforementioned gentleman have done the exact swap you are seeking information about. Good luck.
    Oh and one more thing... it's spelled "mechanic". I'm here to help. :)
  12. zman
    zman
    from Garner, NC
    I believe Bruce's is close to Houston.
    BRUCE'S ROD SHOP
    SPRING,TX.
    (281) 376-5932
    WWW.BRUCESRODSHOP.COM
    They do outstanding work. I believe they could handle what you are after.
