Technical nailhead pistons
Discussion in 'Traditional Hot Rods' started by ruben solis, Nov 27, 2020.
  1. ruben solis
    ruben solis
    I’m looking for someone that either makes pistons for a 401 nailhead. I’m looking for 40 over stock pistons
  2. bchctybob
    bchctybob
    Speedway, Kanter or Egge for cast stock replacement, Ross Racing Engines or maybe Centerville Auto for Hypereutectic or forged. After that I think you're into custom Ross, Venolia, Arias racing piston territory.
    SS327 and Deuces like this.
  3. jimmy six
    jimmy six
    Arias is now CP Carillo but have all of Nicks specs. Ross has a good turn around time or at least they have had for me. KB is also an option.
    UEM silvolite lists the 401 Buick under GM. 401 std up thru .100” over
    Deuces and triumph 1 like this.
  4. 56sedandelivery
    56sedandelivery
    There's a TON of Buick 401 pistons on that auction site we all know and love. I am Butch/56sedandelivery.
    Deuces likes this.
  5. DigDugMd
    DigDugMd
    Tom Telesco, AKA "telriv" at V8Buick.com has the best drop in forged pistons available for Nailheads. If you want cast call Russ at Centerville Auto, Speedway Motors or TA Performance.
    Deuces likes this.
  6. COCONUTS
    COCONUTS
    Get this, I was given a 55 264 complete Buick engine, completely taken apart, sent to a machine shop for a hot tank, polish the crank and bore it out thirty thousands. The owner was ready to put it together when he notice that the new pistons were missing. Someone took them. I help him install a SBC and he gave me the engine for my labor (this happen on base at the auto craft shop). So now, I am waiting for the guy who took the pistons, to show up, could be in for a long wait.
    SS327 and Texas Webb like this.
  7. 5window
    5window
    Life is short. Buy new pistons.
  8. bchctybob
    bchctybob
  9. I'm not sure what you've done to the block so far, but you'd be wise to have the machinist do a proper sonic testing before buying pistons and overboring. .040" over can be pushing it on a 401 block depending on core shift. Better to spend a couple hundred for sonic testing now than to waste a cylinder or have an eternally overheating mess later.
    As for pistons, stay away from Egge and verify with Kanter. Egge's 401/425 piston specs are out of wack and will set the piston down in the hole approx. .100". That'll kill your quench and lower compression. Kanter sells Rebuilders Choice parts for some nailhead stuff, and Rebuilders Choice nailhead pistons are pretty terrible castings. Verify who builds Kanter's pistons if you go that route.
    Quality pistons are readily available through major suppliers and manufacturers. I'd go with Sealed Power/Federal Mogul (Jegs, Summit, Speedway) or Badger (TA Performance) for cast. I think Speedway Motors' are Sealed Power. It looks like Jegs has .040" Sealed Power on sale right now for $290 for the set with pins; good luck beating that price with free shipping and a solid return policy. If you want performance forged pistons, I second DigDugMD's recommendation of Telesco. He has the CAD drawings and forging company to design and forge whatever 401 piston you want along with a hookup on rings. You can get the pistons from smaller shops, but they'll be Sealed Power, Badger, Egge, or Rebuilders Choice with a ridiculous markup.
  10. COCONUTS
    COCONUTS
    Alllllll, you are right, I will be sending the boys over tonight to pick them up.
  11. Flo_Berlin
    Flo_Berlin
    from Germany
    Did anybody have any luck getting in touch with Tom Telesco recetnly? Need a set of forged pistons for a 401, but his phone seems disconnected and he does not answer to emails.
    Greets
    Florian
  12. AHotRod
    AHotRod
    Tom Telesco
    (Formally of Cl***ic & Muscle Automotive)
    12 Cook St.
    Norwalk, Ct. 06853-1601
    Try this number, 203-866-4954
    kadillackid likes this.
  13. Flo_Berlin
    Flo_Berlin
    from Germany
    Tried the -4954 number some days ago.... He just gave me a call back.
    AHotRod likes this.
  14. rockabilly53
    rockabilly53
    from Appleton
    Did you have luck getting pistons? I'm also on the hunt for 401 +.030 forged pistons. I tried calling and leaving a message a few weeks ago.
  15. Panther Sales puts Silv-o-Lite 1717 pistons for the 401 in .030 over on E-Bay frequently, priced under $300 a set. Has the highest CR for cast pistons that I found. Used a set from them when I put my 401 together. The pistons weighed within a gram of each other when I had the ***embly balanced. With .025 cut off of the deck and using the steel head gaskets, my CR measured out to 9.95 to 1.
    If looking for strictly forged, Ross will make you a set.
