Nailhead questions
Discussion in 'The Hokey Ass Message Board' started by Revhead, Nov 12, 2003.
  1. Revhead
    Revhead
    from Dallas, TX
    I found this '63 wildcat and I'm gonna try to grab the engine for a future project. Do the old (like '53) manual trans bellhousings fit later blocks. Also were all wildcats 401s in '63? It's a 4dr sedan, so it's probably the lower performance engine. I looked around on the web and found that there were the 425 and 445 engines in them. Any way to make sure before I pull it out?
  2. Bigcheese327
    Bigcheese327
    Yeah, just check the air cleaner decal. [​IMG]
  3. 38Chevy454
    38Chevy454
    The bellhousing pattern is different, I think the break point is 57-65 are similar, and 53-56 are similar.
    Buick rated their engines by torque, so the 445 is the engine ft-lbs of torque. If the engine is a 2 barrel, it would be the lower torque rating 425, and the single four barrel is the 445 version.
    Any 401-425 (cubic inch size) intake will interchange, so you can put whatever intake type you want on that 63 401.
    That 63 will have a dynaslow, the turbo 400 trans came out in 64 until 66 with the nailheads. There was a post a couple days ago that discussed this in detail.
  4. Revhead
    Revhead
    from Dallas, TX
    So, how hard is it to have a manual transmission on the back of a '63 or so 401? I can't imagine there'd be too many buicks made past '57 that didn't have an automatic.
  5. kustombuilder
    kustombuilder
    from Novi, MI
    your right there. the manual trans bellhousings are hard to find and general a bit pricey. there were aftermarket ones at one time though. i have an alluminum one for my 62 401 (going in my model A) that adaptes an AMC manual trans to the Nailhead engine. i will likely modify it (ie, CUT IT UP!!) so i can bolt a Tremec 6 speed behind my mill. stil looking at just making a steel one from scratch too though. i'll attach a pic of my aluminum adapter/bellhousing...
    Mike Brimm
